<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Flick Hat, Skywriter, IR, HC-SR04, or other Gesture Controllers that work out of the box(ish).]]></title><description><![CDATA[<p dir="auto">I’ve been reading through the forums here for the past few days. I cannot get a consensus whether either of these work with myriad MMM-<em>gesture</em> modules available for my RasPi 3B+ without requiring an Arduino or PC such as is required with the Leap Motion.</p>
<p dir="auto">I have found posts regarding the Flick Hat, Flick Large, and Skywriter hat, maybe a camera?, and the MMM-Swipe module that uses two 2 HC-SR04 ultrasonic sensors, and perhaps the Grove Gesture. Which seems to work best at this time? As it stands right now, the Flick Large seems to be the best candidate.</p>
<p dir="auto">We’d need swipe left, right, up, down and some mouse-like touch capability would be an added bonus. We’d need the gesture board against the wall below the magic mirror so which one allows for a ribbon cable connection to the raspi which will be mounted behind the mirror?</p>
<p dir="auto">I can’t seem to determine whether these worked without requiring much technical insight which I don’t possess. I don’t have much programming experience at all and consider myself a novice.</p>
]]></description><link>https://forum.magicmirror.builders/topic/10764/flick-hat-skywriter-ir-hc-sr04-or-other-gesture-controllers-that-work-out-of-the-box-ish</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 14:08:54 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10764.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 11 Jul 2019 13:32:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Flick Hat, Skywriter, IR, HC-SR04, or other Gesture Controllers that work out of the box(ish). on Thu, 30 Dec 2021 20:43:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/billycarlson" aria-label="Profile: billycarlson">@<bdi>billycarlson</bdi></a> what is a skywriter?</p>
]]></description><link>https://forum.magicmirror.builders/post/97899</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97899</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 30 Dec 2021 20:43:46 GMT</pubDate></item><item><title><![CDATA[Reply to Flick Hat, Skywriter, IR, HC-SR04, or other Gesture Controllers that work out of the box(ish). on Thu, 30 Dec 2021 19:25:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/melonball" aria-label="Profile: melonball">@<bdi>melonball</bdi></a> Is there anything new here on how to use a skywriter to interact with MM?</p>
]]></description><link>https://forum.magicmirror.builders/post/97897</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97897</guid><dc:creator><![CDATA[billycarlson]]></dc:creator><pubDate>Thu, 30 Dec 2021 19:25:01 GMT</pubDate></item></channel></rss>
