<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Failed at the magicmirror@2.8.0 start script]]></title><description><![CDATA[<p dir="auto">When I restart the Raspberry (PRI3B+) I get this error in the pm2 log:</p>
<pre><code>npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! magicmirror@2.8.0 start: `sh run-start.sh`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the magicmirror@2.8.0 start script.
npm ERR!     /home/pi/.npm/_logs/2019-07-12T19_29_14_310Z-debug.log
ATTENTION: default value of option force_s3tc_enable overridden by environment.
npm ERR! errno 1
npm ERR!
npm ERR!     /home/pi/.npm/_logs/2019-07-12T19_59_43_770Z-debug.log
<p dir="auto">And this is the output of the npm log:</p>
<pre><code>0 info it worked if it ends with ok
1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
2 info using npm@6.9.0
3 info using node@v10.16.0
5 info lifecycle magicmirror@2.8.0~prestart: magicmirror@2.8.0
6 info lifecycle magicmirror@2.8.0~start: magicmirror@2.8.0
7 verbose lifecycle magicmirror@2.8.0~start: unsafe-perm in lifecycle true
8 verbose lifecycle magicmirror@2.8.0~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
9 verbose lifecycle magicmirror@2.8.0~start: CWD: /home/pi/MagicMirror
10 silly lifecycle magicmirror@2.8.0~start: Args: [ '-c', 'sh run-start.sh' ]
11 silly lifecycle magicmirror@2.8.0~start: Returned: code: 1  signal: null
12 info lifecycle magicmirror@2.8.0~start: Failed to exec start script
13 verbose stack Error: magicmirror@2.8.0 start: `sh run-start.sh`
13 verbose stack Exit status 1
13 verbose stack     at EventEmitter.&lt;anonymous&gt; (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:301:16)
13 verbose stack     at EventEmitter.emit (events.js:198:13)
13 verbose stack     at ChildProcess.&lt;anonymous&gt; (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
13 verbose stack     at ChildProcess.emit (events.js:198:13)
13 verbose stack     at maybeClose (internal/child_process.js:982:16)
13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
14 verbose pkgid magicmirror@2.8.0
15 verbose cwd /home/pi/MagicMirror
16 verbose Linux 4.19.42-v7+
17 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
18 verbose node v10.16.0
19 verbose npm  v6.9.0
20 error code ELIFECYCLE
21 error errno 1
22 error magicmirror@2.8.0 start: `sh run-start.sh`
22 error Exit status 1
23 error Failed at the magicmirror@2.8.0 start script.
23 error This is probably not a problem with npm. There is likely additional logging output above.
24 verbose exit [ 1, true ]
<p dir="auto">The MagicMirror script starts though … and the modules are loaded …<br />
How can I fix this?</p>
]]></description><link>https://forum.magicmirror.builders/topic/10772/failed-at-the-magicmirror-2-8-0-start-script</link><generator>RSS for Node</generator><lastBuildDate>Sat, 08 Aug 2026 16:33:31 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10772.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 12 Jul 2019 20:09:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Failed at the magicmirror@2.8.0 start script on Fri, 06 Sep 2019 18:12:32 GMT]]></title><description><![CDATA[<p dir="auto">My mistake was that I had chossen to auto-start Desktop but not Autologin, after I changed to Autologin with Desktop everything was fine again.</p>
]]></description><link>https://forum.magicmirror.builders/post/60979</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/60979</guid><dc:creator><![CDATA[flopp]]></dc:creator><pubDate>Fri, 06 Sep 2019 18:12:32 GMT</pubDate></item><item><title><![CDATA[Reply to Failed at the magicmirror@2.8.0 start script on Fri, 06 Sep 2019 18:11:41 GMT]]></title><description><![CDATA[<p dir="auto">I got this after I set the Pi to not auto-start Desktop, reboot my Pi to implement my change. After reboot it starts in CLI, then I got the above message.<br />
I changed back so Desktop will auto-start, reboot but still same message as above.<br />
Was working perfect before.<br />
RPi 3B<br />
Raspbian Buster</p>
]]></description><link>https://forum.magicmirror.builders/post/60978</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/60978</guid><dc:creator><![CDATA[flopp]]></dc:creator><pubDate>Fri, 06 Sep 2019 18:11:41 GMT</pubDate></item></channel></rss>
