<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[config.js help]]></title><description><![CDATA[<p dir="auto">Guys and Girls can you help my config has gone to Well you know, can you help me sort this as i just cant see whats up i have removed the code for all the keys so its just empty “” thanks in advance</p>
 * MIT Licensed.
var config = {
	port: 8080,
	language: "en",
	timeFormat: 24,
	units: "metric",
                        module: "MMM-Remote-Control-Repository",
                        module: "alert",
                        module: "MMM-Remote-Control",
                        position: "center",
                        module: "clock",
                        position: "top_left"
                       module: "mmm-hue-lights",
                       position: "bottom_right",
                       bridgeIp: "192.168.1.23",
                       user: "",
                       updateInterval: "1000",
                       hideOff: "false",
                       displayMode: "groups",
                       displayType: "list",
                       minimalList: "true",
                       coloredList: "true",
                       hideFilter: ["home-away"],
                       alignment: "right",
                      module: "compliments",
                      position: "lower_third",
                      module: "MMM-NOAA3",
                      provider: "darksky",
                      apiKey: "",
                      airKey: "",
                      css: "NOAA3",
                      updateInterval: 15,
                      userlat: "51.806460",
                      userlon: "-0.778230"
                     header: "Calendar",
                     timeFormat:"absolute",
                     titleReplace: {"United Kingdom:" : ""},
                     urgency: 0,
                     getRelative: 6,
                     fullDayEventDateFormat: "D MMMM",
                     dateFormat: "D MMMM - H:mm:ss",
                     fetchInterval: 4000000,
                     colored: true,
                     coloredSymbolOnly: true,
                     maximumEntries: 9,
                     showEnd: false,
                     Calendars: [
                     symbol: "calendar-check-o ",
                     url: "https://www.officeholidays.com/ics/ics_country_code.php?iso=GB",
                    module: "mmm-nest-status",
                    position: "bottom_left", // pick whichever position you want
                    token: "",
                    displayMode: "all",
                    thermostatsToShow: "all",
                    units: "metric",
                    updateInterval: "50000",
                    thermostatSize: "small",
                    alignment: "left",
             // ... and whatever else configuration options you want to use
                    module: "MMM-SystemStats",
                    position: "Top_Center",
                    updateInterval: 5000,
                    align: "right",
                    units: "metric",
                    label: "text"
                    module: "newsfeed",
                    position: "bottom_bar",
                    feeds: [
                    title: "BBC NEWS UK",
                    url: "http://feeds.bbci.co.uk/news/uk/rss.xml"
                   showSourceTitle: true,
                   showPublishDate: true
]]></description><link>https://forum.magicmirror.builders/topic/10773/config-js-help</link><generator>RSS for Node</generator><lastBuildDate>Wed, 09 Sep 2026 00:35:28 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10773.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 12 Jul 2019 20:12:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to config.js help on Fri, 12 Jul 2019 20:42:13 GMT]]></title><description><![CDATA[<p dir="auto">Try this, but you really need to clean up ;) :P</p>
 * MIT Licensed.
var config = {
	port: 8080,
	language: "en",
	timeFormat: 24,
	units: "metric",
                        module: "alert",
                        position: "center",
                        module: "clock",
                       user: "",
                       hideOff: "false",
                       alignment: "right"
                      apiKey: "",
                      airKey: "",
                      css: "NOAA3",
                      updateInterval: 15,
                     header: "Calendar",
                     urgency: 0,
                     getRelative: 6,
                     colored: true,
                     maximumEntries: 9,
                     showEnd: false,
                     Calendars: [
                    token: "",
                    displayMode: "all",
                    units: "metric",
                    alignment: "left",
                    align: "right",
                    units: "metric",
                    label: "text"
                    module: "newsfeed",
                    feeds: [
<p dir="auto">For the future u can put in your code here: <a href="https://jshint.com" target="_blank" rel="noopener noreferrer nofollow ugc">https://jshint.com</a></p>
<p dir="auto">Just to analyze what maybe went wrong</p>
]]></description><link>https://forum.magicmirror.builders/post/58851</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58851</guid><dc:creator><![CDATA[cruunnerr]]></dc:creator><pubDate>Fri, 12 Jul 2019 20:42:13 GMT</pubDate></item><item><title><![CDATA[Reply to config.js help on Fri, 12 Jul 2019 20:18:34 GMT]]></title><description><![CDATA[<p dir="auto">You are missing config lines and have to many <code>}</code>-brackets</p>
<p dir="auto">I would just suggest that you rename that config.js file to config.js.bak and start over from scratch.</p>
]]></description><link>https://forum.magicmirror.builders/post/58850</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58850</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Fri, 12 Jul 2019 20:18:34 GMT</pubDate></item></channel></rss>
