<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-PIR or MMM-PIR-Sensor issues...]]></title><description><![CDATA[<p dir="auto">Hi all, I’ve been building in the background for some time now but I’ve come across a problem trying to install a PIR.</p>
<p dir="auto">My MM project all set up and running great, but I wanted to turn off the display with either of the above PIR modules and I’ve come across some issues.</p>
<p dir="auto">When I add this code to my config.js after installing MMM-PIR-Sensor</p>
<pre><code>        {
	module: 'MMM-PIR-Sensor',
		     sensorPin: 14,
		     powerSaving: true,
	             powerSavingDelay: 40,
<p dir="auto">My MM won’t load, I get a white screen which says;</p>
<p dir="auto">“localhost refused to connect”</p>
<p dir="auto">ERR_CONNECTION_REFUSED</p>
<p dir="auto">I’ve followed the install exactly and can’t see what’s going wrong!</p>
<p dir="auto">cheers onis</p>
]]></description><link>https://forum.magicmirror.builders/topic/10777/mmm-pir-or-mmm-pir-sensor-issues</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Jul 2026 21:53:25 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10777.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 13 Jul 2019 11:12:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-PIR or MMM-PIR-Sensor issues... on Tue, 25 Jan 2022 00:32:37 GMT]]></title><description><![CDATA[<p dir="auto">Gee,  I’ve missed this place.</p>
<p dir="auto">No, really.</p>
]]></description><link>https://forum.magicmirror.builders/post/98979</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/98979</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Tue, 25 Jan 2022 00:32:37 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR or MMM-PIR-Sensor issues... on Sun, 12 Dec 2021 11:33:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fozi" aria-label="Profile: fozi">@<bdi>fozi</bdi></a> I know… and I don’t know how code something and blah blah blah …</p>
]]></description><link>https://forum.magicmirror.builders/post/97430</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97430</guid><dc:creator><![CDATA[bugsounet]]></dc:creator><pubDate>Sun, 12 Dec 2021 11:33:27 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR or MMM-PIR-Sensor issues... on Sun, 12 Dec 2021 11:11:01 GMT]]></title><description><![CDATA[<blockquote>
<ul>
<li><strong>I’m a VERY BAD guys in this forum</strong></li>
</ul>
<p dir="auto">…and in <a href="http://forum.bugsounet.fr/topic/529/mmm-tools-is-not-being-displayed-after-update-to-mm-2-17-1/10?lang=de&amp;loggedin=true" target="_blank" rel="noopener noreferrer nofollow ugc">your own forum, too</a>.</p>
]]></description><link>https://forum.magicmirror.builders/post/97428</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97428</guid><dc:creator><![CDATA[Fozi]]></dc:creator><pubDate>Sun, 12 Dec 2021 11:11:01 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR or MMM-PIR-Sensor issues... on Sat, 11 Dec 2021 19:42:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> sure and i assume it :)<br />
[and i will continue… on this way there]</p>
]]></description><link>https://forum.magicmirror.builders/post/97415</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97415</guid><dc:creator><![CDATA[bugsounet]]></dc:creator><pubDate>Sat, 11 Dec 2021 19:42:43 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR or MMM-PIR-Sensor issues... on Sat, 11 Dec 2021 19:18:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a> said in <a href="/post/97411">MMM-PIR or MMM-PIR-Sensor issues...</a>:</p>
<p dir="auto">I am not a reference in this forum</p>
<p dir="auto">only because you choose it to be that way.</p>
]]></description><link>https://forum.magicmirror.builders/post/97413</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97413</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 11 Dec 2021 19:18:42 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR or MMM-PIR-Sensor issues... on Sat, 11 Dec 2021 18:55:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a></p>
<ul>
<li>Thanks to <strong>don’t</strong> to advertise <strong>any</strong> of my modules on this forum</li>
<li>Thanks to <strong>not</strong> offer <strong>any</strong> support of my modules on this forum</li>
</ul>
<p dir="auto">I repeat again (again, again ?):</p>
<ul>
<li>I am not a reference in this forum</li>
<li>That’s why any of my modules is <strong>not</strong> on the <strong>3rd party modules</strong></li>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/97411</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97411</guid><dc:creator><![CDATA[bugsounet]]></dc:creator><pubDate>Sat, 11 Dec 2021 18:55:37 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR or MMM-PIR-Sensor issues... on Sat, 11 Dec 2021 12:06:11 GMT]]></title><description><![CDATA[<p dir="auto">IN case anyone is still looking for a way to do this since they updated the PI4 it’s easier:</p>
<p dir="auto">You can use 1 of 2 methods here:</p>
<p dir="auto"><a href="https://github.com/cowboysdude/Pir-Sensor" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/cowboysdude/Pir-Sensor</a></p>
<p dir="auto">or [even better solution IMO]</p>
<p dir="auto"><a href="https://github.com/bugsounet/MMM-NewPIR" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/bugsounet/MMM-NewPIR</a></p>
]]></description><link>https://forum.magicmirror.builders/post/97386</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97386</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Sat, 11 Dec 2021 12:06:11 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR or MMM-PIR-Sensor issues... on Mon, 27 Apr 2020 01:22:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> if u ssh in do the two commands work?</p>
]]></description><link>https://forum.magicmirror.builders/post/73637</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73637</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 27 Apr 2020 01:22:19 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR or MMM-PIR-Sensor issues... on Mon, 27 Apr 2020 01:20:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> eh?</p>
]]></description><link>https://forum.magicmirror.builders/post/73636</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73636</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 27 Apr 2020 01:20:53 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR or MMM-PIR-Sensor issues... on Mon, 27 Apr 2020 01:12:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> My old Pir Sensor does not work at all on Buster.</p>
]]></description><link>https://forum.magicmirror.builders/post/73635</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73635</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Mon, 27 Apr 2020 01:12:15 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR or MMM-PIR-Sensor issues... on Mon, 27 Apr 2020 00:08:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thank you!! Been looking all day… gonna try this right now!</p>
]]></description><link>https://forum.magicmirror.builders/post/73630</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73630</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Mon, 27 Apr 2020 00:08:52 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR or MMM-PIR-Sensor issues... on Sun, 26 Apr 2020 23:37:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> someone had to add a parm to the command</p>
<pre><code>Either way, i found another way which is using the command 'vcgencmd display_power 0 2' and
'vcgencmd display_power 1 2'
where the 0 stands for Off and 1 stands for On and the 2 stands for my display ID.
]]></description><link>https://forum.magicmirror.builders/post/73629</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73629</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 26 Apr 2020 23:37:42 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR or MMM-PIR-Sensor issues... on Sun, 26 Apr 2020 23:34:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/onis_uk" aria-label="Profile: onis_uk">@<bdi>onis_uk</bdi></a> what’s funny is that I cannot get it work any longer… since Buster came out and I upgraded it turns off but not back on…LOL</p>
]]></description><link>https://forum.magicmirror.builders/post/73628</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73628</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Sun, 26 Apr 2020 23:34:40 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR or MMM-PIR-Sensor issues... on Sun, 18 Aug 2019 14:17:50 GMT]]></title><description><![CDATA[<p dir="auto">Hi Onis, I got the module running without a script. Did you add the user to the GPIO group and executed the command for turning the HDMI on/off?</p>
]]></description><link>https://forum.magicmirror.builders/post/60205</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/60205</guid><dc:creator><![CDATA[MacMirror]]></dc:creator><pubDate>Sun, 18 Aug 2019 14:17:50 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR or MMM-PIR-Sensor issues... on Mon, 15 Jul 2019 17:49:30 GMT]]></title><description><![CDATA[<p dir="auto">Fixed it by running a script outside the modules using this method!</p>
<p dir="auto">cheers<br />
onis</p>
]]></description><link>https://forum.magicmirror.builders/post/58963</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58963</guid><dc:creator><![CDATA[onis_uk]]></dc:creator><pubDate>Mon, 15 Jul 2019 17:49:30 GMT</pubDate></item></channel></rss>
