<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Unable to Install MagicMirror dependencies - npm error]]></title><description><![CDATA[<p dir="auto">Platform: Raspberry Pi 3B</p>
<p dir="auto">Node Version: 10.15.2</p>
<p dir="auto">MagicMirror Version: V2</p>
<p dir="auto">Description: For some reason I am not able to install MagicMirror on my Raspi 3B. This is straight after loading a brand new NOOBS setup (3.1.1.1) and then using the Automatic install url to install npm and MagicMirror. It Installs npm but when installing the MagicMirror depencies I get an error saying ‘npm ERR! cb()never called!’ followed by ‘Unable to install dependencies’ .<br />
Strange thing is that I used the same NOOBS installation on a Raspi 2 last Wednesday and it installed MagicMirror without any issues. Did anyone else experience the same issue when trying to install it on Raspi 3B with the lastest Raspbian Buster (June 2019 release)?</p>
<p dir="auto">Steps to Reproduce: See description above</p>
<p dir="auto">Expected Results: Smooth installation of MagicMirror</p>
<p dir="auto">Actual Results: Errors during installation, not able to install dependencies.</p>
<p dir="auto">Configuration: N/A<br />
2019-07-15T06_14_28_892Z-debug.log</p>
<p dir="auto">Additional Notes: I’ve tried checking for a later version of npm and reinstalling node.Js without any success.</p>
<p dir="auto">Help would be appreciated. Thanks</p>
<p dir="auto">Terminal response below:</p>
<pre><code>npm installation Done!
Cloning MagicMirror ...
Cloning into 'MagicMirror'...
remote: Enumerating objects: 315, done.
remote: Counting objects: 100% (315/315), done.
remote: Compressing objects: 100% (282/282), done.
remote: Total 315 (delta 39), reused 192 (delta 21), pack-reused 0
Receiving objects: 100% (315/315), 655.07 KiB | 412.00 KiB/s, done.
Resolving deltas: 100% (39/39), done.
Cloning MagicMirror Done!
Installing dependencies ...
npm WARN npm npm does not support Node.js v10.15.2
npm WARN npm You should probably upgrade to a newer version of node as we
npm WARN npm can't make any promises that npm will work with this version.
npm WARN npm Supported releases of Node.js are the latest release of 4, 6, 7, 8, 9.
npm WARN npm You can find the latest version at https://nodejs.org/
npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically un maintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
npm WARN tar write after end
npm ERR! cb() never called!
npm ERR! This is an error with npm itself. Please report this error at:
npm ERR! https://github.com/npm/npm/issues
npm ERR! /home/pi/.npm/_logs/2019-07-15T06_14_28_892Z-debug.log
]]></description><link>https://forum.magicmirror.builders/topic/10788/unable-to-install-magicmirror-dependencies-npm-error</link><generator>RSS for Node</generator><lastBuildDate>Tue, 16 Jun 2026 21:51:27 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10788.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 15 Jul 2019 10:20:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Unable to Install MagicMirror dependencies - npm error on Tue, 16 Jul 2019 16:52:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/qtin" aria-label="Profile: qtin">@<bdi>qtin</bdi></a> cool. All kinds of changes get made everyday to libraries we use and they use…</p>
]]></description><link>https://forum.magicmirror.builders/post/59024</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59024</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 16 Jul 2019 16:52:53 GMT</pubDate></item><item><title><![CDATA[Reply to Unable to Install MagicMirror dependencies - npm error on Tue, 16 Jul 2019 15:57:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> , It worked!</p>
<p dir="auto">Thank you for the recommendation.</p>
<p dir="auto">Still doesn’t make sense why it stopped working, unless there’s been an updated repository in the last week.</p>
<p dir="auto">Thanks again and keep well.</p>
]]></description><link>https://forum.magicmirror.builders/post/59021</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59021</guid><dc:creator><![CDATA[qtin]]></dc:creator><pubDate>Tue, 16 Jul 2019 15:57:29 GMT</pubDate></item><item><title><![CDATA[Reply to Unable to Install MagicMirror dependencies - npm error on Mon, 15 Jul 2019 20:08:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/qtin" aria-label="Profile: qtin">@<bdi>qtin</bdi></a> yes</p>
]]></description><link>https://forum.magicmirror.builders/post/58974</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58974</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 15 Jul 2019 20:08:03 GMT</pubDate></item><item><title><![CDATA[Reply to Unable to Install MagicMirror dependencies - npm error on Mon, 15 Jul 2019 19:50:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Hi Sam</p>
<p dir="auto">Thank you, I will give it another go and feed back. Just going to reload Raspbian again and try the above.</p>
<p dir="auto">Would you recommend using the following command to clear the node modules inside the MagicMirror folder?</p>
<pre><code>rm -rf node_modules/
]]></description><link>https://forum.magicmirror.builders/post/58973</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58973</guid><dc:creator><![CDATA[qtin]]></dc:creator><pubDate>Mon, 15 Jul 2019 19:50:02 GMT</pubDate></item><item><title><![CDATA[Reply to Unable to Install MagicMirror dependencies - npm error on Mon, 15 Jul 2019 15:20:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/qtin" aria-label="Profile: qtin">@<bdi>qtin</bdi></a> try to update npm</p>
<pre><code>sudo npm i -g npm
<p dir="auto">Then delete MagicMirror/node_modules<br />
And then npm install from MagicMirror folder again</p>
]]></description><link>https://forum.magicmirror.builders/post/58956</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58956</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 15 Jul 2019 15:20:11 GMT</pubDate></item></channel></rss>
