This forum was moved to another machine and updated to a recent version. If you are unable to login please delete your browser cookies and cache and restart your browser.A New Chapter for MagicMirror: The Community Takes the Lead
MMM-UKNationalRail - Header for module doesn't show
Re: MMM-UKNationalRail - Rail departure info for specific UK Railway stations
I have looked everywhere and tried reinstalling the module and the header does not show.
Any ideas would be great.
Thanks,
Vince -
Can you post your config entry for that module?
Normally, the beginning of every module is the same. Example:
module: "MMM-UKNationalRail", position: "bottom_bar", header: "testing", config: {
This should work with any module unless some css rules are disabling the header
I seem to recall that the author no longer has a MagicMirror and so the module is not being updated. It broke for me at the last MM update, so it could very well be an issue with the base JS code.
