<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-PIR-Sensor with Radar sensor( RCWL-0516)]]></title><description><![CDATA[<p dir="auto">Hi all,<br />
I think I’ve read somewhere that MMM-PIR-Sensor works as well with a radar seonsor (RCWL-0516) behind glass.<br />
Now for me it currently gives very odd behaviour.<br />
I get a USER_PRESENCE notification and a “refresh” of the monitor (turn off shortly and turn it on again) every few seconds even if noone is in front of the mirror.<br />
No other messages, no errors.</p>
<p dir="auto">I have the radar sensor installed without any resistor in between.<br />
Nothing special in the config.</p>
<pre><code>        //disabled: true,
        module: 'MMM-PIR-Sensor',
            sensorPin: 17,
            powerSavingDelay: 20,
<p dir="auto">Can anyone confirm that this module works with a radar sensor and possibly help me out?</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/topic/10793/mmm-pir-sensor-with-radar-sensor-rcwl-0516</link><generator>RSS for Node</generator><lastBuildDate>Sun, 10 May 2026 08:36:50 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10793.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 15 Jul 2019 18:52:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-PIR-Sensor with Radar sensor( RCWL-0516) on Mon, 14 Oct 2024 08:58:17 GMT]]></title><description><![CDATA[<p dir="auto">Does anyone have a nice housing for the sensor RCWL-0516? Mounting on a wooden frame, such as this one from the PIR</p>
<p dir="auto"><img src="/assets/uploads/files/1728896274142-pir-geh%C3%A4use.png" alt="PIR-Gehäuse.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Thank you</p>
]]></description><link>https://forum.magicmirror.builders/post/120583</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120583</guid><dc:creator><![CDATA[Babene1]]></dc:creator><pubDate>Mon, 14 Oct 2024 08:58:17 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR-Sensor with Radar sensor( RCWL-0516) on Mon, 19 Aug 2019 09:08:24 GMT]]></title><description><![CDATA[<p dir="auto">The sensor is connected directly.</p>
<p dir="auto">Did you wired the Vin to 5V on the Raspi? Don’t use the 3v3-Pin!</p>
]]></description><link>https://forum.magicmirror.builders/post/60234</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/60234</guid><dc:creator><![CDATA[MacMirror]]></dc:creator><pubDate>Mon, 19 Aug 2019 09:08:24 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR-Sensor with Radar sensor( RCWL-0516) on Sun, 18 Aug 2019 22:21:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/macmirror" aria-label="Profile: MacMirror">@<bdi>MacMirror</bdi></a></p>
<p dir="auto">Checked the pins several times.<br />
Are you using a resistor or anything in between? Or is it wired directly?</p>
]]></description><link>https://forum.magicmirror.builders/post/60219</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/60219</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Sun, 18 Aug 2019 22:21:58 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR-Sensor with Radar sensor( RCWL-0516) on Sun, 18 Aug 2019 14:25:30 GMT]]></title><description><![CDATA[<p dir="auto">I am using the same sensor even on the same GPIO pin with the module. First it didn’t worked, but after doing an update of the module everything is running like expected.<br />
Did you connected the sensor correct?</p>
]]></description><link>https://forum.magicmirror.builders/post/60206</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/60206</guid><dc:creator><![CDATA[MacMirror]]></dc:creator><pubDate>Sun, 18 Aug 2019 14:25:30 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR-Sensor with Radar sensor( RCWL-0516) on Mon, 15 Jul 2019 20:22:24 GMT]]></title><description><![CDATA[<p dir="auto">I tweaked the module logging a bit to include the time and there’s obviously something systematic happening. This is what I get after some time (as said, messages included with console.log.:</p>
<p dir="auto"><img src="/assets/uploads/files/1563220295811-bc9c404c-3600-4d22-998b-de4c3602babc-image.png" alt="0_1563220295659_bc9c404c-3600-4d22-998b-de4c3602babc-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">It’s always turning on after 1-2 minutes and turning off after 3 seconds immediately.</p>
<p dir="auto">After some googling I’m getting the feeling that the radar sensor is not the best way to go…</p>
]]></description><link>https://forum.magicmirror.builders/post/58975</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58975</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Mon, 15 Jul 2019 20:22:24 GMT</pubDate></item></channel></rss>
