<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Third party modules causing blank screen]]></title><description><![CDATA[<p dir="auto">Hey guys, quick question</p>
<p dir="auto">Has anyone had a problem editing their config.js files for the third party modules?  I had my mirror working great with the default modules but wanted to add airquality and traffic. I downloaded the modules just fine but when I edit my config file to include them it boots up as a blank screen, removal of the few lines of code for the respective modules and it goes back to normal working order. Thanks for the help!</p>
]]></description><link>https://forum.magicmirror.builders/topic/108/third-party-modules-causing-blank-screen</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Jul 2026 00:58:57 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/108.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 17 May 2016 16:52:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Third party modules causing blank screen on Thu, 09 Jun 2016 05:13:39 GMT]]></title><description><![CDATA[<p dir="auto">I faced the issue when I was working under MagicMirror folder and then installing the 3rd party modules.</p>
<p dir="auto">I corrected it by going into <code>/MagicMirror/Modules</code> folder and then installing the module using the git command.</p>
<p dir="auto">Hope this helps</p>
]]></description><link>https://forum.magicmirror.builders/post/1514</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1514</guid><dc:creator><![CDATA[sameershah23]]></dc:creator><pubDate>Thu, 09 Jun 2016 05:13:39 GMT</pubDate></item><item><title><![CDATA[Reply to Third party modules causing blank screen on Tue, 17 May 2016 19:32:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/aubcar" aria-label="Profile: aubcar">@<bdi>aubcar</bdi></a> did you check your web inspector?</p>
]]></description><link>https://forum.magicmirror.builders/post/757</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/757</guid><dc:creator><![CDATA[paviro]]></dc:creator><pubDate>Tue, 17 May 2016 19:32:57 GMT</pubDate></item><item><title><![CDATA[Reply to Third party modules causing blank screen on Tue, 17 May 2016 18:49:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/paviro" aria-label="Profile: paviro">@<bdi>paviro</bdi></a> Seems to be formatted ok, only yells at me to use spaces not tabs haha. Might try a fresh install of rasbian+MM incase I messed something up along the way.</p>
]]></description><link>https://forum.magicmirror.builders/post/753</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/753</guid><dc:creator><![CDATA[aubcar]]></dc:creator><pubDate>Tue, 17 May 2016 18:49:21 GMT</pubDate></item><item><title><![CDATA[Reply to Third party modules causing blank screen on Tue, 17 May 2016 18:27:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/aubcar" aria-label="Profile: aubcar">@<bdi>aubcar</bdi></a> check your formating! You probably did something wrong adding the modules. You can check by using a javascript validator (Google it :))</p>
]]></description><link>https://forum.magicmirror.builders/post/750</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/750</guid><dc:creator><![CDATA[paviro]]></dc:creator><pubDate>Tue, 17 May 2016 18:27:08 GMT</pubDate></item><item><title><![CDATA[Reply to Third party modules causing blank screen on Tue, 17 May 2016 18:13:29 GMT]]></title><description><![CDATA[<p dir="auto">Ok then try starting your mirror in server mode (‘node serveronly’ from your Mirror directory), goto your raspi´s ipaddr on port 8080 and check your browser console.</p>
]]></description><link>https://forum.magicmirror.builders/post/749</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/749</guid><dc:creator><![CDATA[PtrBld]]></dc:creator><pubDate>Tue, 17 May 2016 18:13:29 GMT</pubDate></item><item><title><![CDATA[Reply to Third party modules causing blank screen on Tue, 17 May 2016 17:44:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ptrbld" aria-label="Profile: PtrBld">@<bdi>PtrBld</bdi></a> I attached my config file, I’m not getting any errors, just a blank screen.</p>
]]></description><link>https://forum.magicmirror.builders/post/748</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/748</guid><dc:creator><![CDATA[aubcar]]></dc:creator><pubDate>Tue, 17 May 2016 17:44:18 GMT</pubDate></item><item><title><![CDATA[Reply to Third party modules causing blank screen on Tue, 17 May 2016 17:41:54 GMT]]></title><description><![CDATA[<p dir="auto"><a href="/uploads/files/1463506905849-config.js">0_1463506896422_config.js</a></p>
]]></description><link>https://forum.magicmirror.builders/post/747</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/747</guid><dc:creator><![CDATA[aubcar]]></dc:creator><pubDate>Tue, 17 May 2016 17:41:54 GMT</pubDate></item><item><title><![CDATA[Reply to Third party modules causing blank screen on Tue, 17 May 2016 17:19:57 GMT]]></title><description><![CDATA[<p dir="auto">Could you share your not working config and  the error log with us?</p>
]]></description><link>https://forum.magicmirror.builders/post/745</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/745</guid><dc:creator><![CDATA[PtrBld]]></dc:creator><pubDate>Tue, 17 May 2016 17:19:57 GMT</pubDate></item></channel></rss>
