<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Spotify module newbi]]></title><description><![CDATA[<p dir="auto">I just start my own bulding of a magic mirror, i am totley new to rpi, and alla codes and stuff. but i need son help, i am trying to install <a href="https://github.com/raywo/MMM-NowPlayingOnSpotify" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/raywo/MMM-NowPlayingOnSpotify</a>…</p>
<p dir="auto">but when i write cd moduel i get: cant find any files or folders</p>
<p dir="auto">i guess i have more deep in:S</p>
<p dir="auto">home/pi/MagicMirror/modules/defalut is what i have…</p>
<p dir="auto">so i sholde i write it to get it to work:/</p>
]]></description><link>https://forum.magicmirror.builders/topic/10806/spotify-module-newbi</link><generator>RSS for Node</generator><lastBuildDate>Wed, 15 Apr 2026 21:59:21 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10806.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 18 Jul 2019 11:06:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Spotify module newbi on Thu, 18 Jul 2019 16:59:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/59129">Spotify module newbi</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/berne" aria-label="Profile: berne">@<bdi>berne</bdi></a> can u show us what you added to config… seems a missing comma probably</p>
<p dir="auto">yes, u have done some thing i Home assistent, but this semms alot harder, when pasteing code, i did a new intall, Think i will do the spotify to morrow</p>
]]></description><link>https://forum.magicmirror.builders/post/59133</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59133</guid><dc:creator><![CDATA[berne]]></dc:creator><pubDate>Thu, 18 Jul 2019 16:59:31 GMT</pubDate></item><item><title><![CDATA[Reply to Spotify module newbi on Thu, 18 Jul 2019 15:44:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/berne" aria-label="Profile: berne">@<bdi>berne</bdi></a> can u show us what you added to config… seems a missing comma probably</p>
]]></description><link>https://forum.magicmirror.builders/post/59129</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59129</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 18 Jul 2019 15:44:19 GMT</pubDate></item><item><title><![CDATA[Reply to Spotify module newbi on Thu, 18 Jul 2019 14:29:54 GMT]]></title><description><![CDATA[<pre><code>98:11 error Parsing error: Unexpected token, expected ";" 96 | { 97 | module: "MMM-NowPlayingOnSpotify", &gt; 98 | position: "top_left", | ^ 99 | 100 | config: { 101 | clientID: "431313e344ta464erfef3c0812323235c9232äå"
<p dir="auto">When i now trying to boot MM , i cant find any config, if i have use the java liner to chek it, got this?</p>
]]></description><link>https://forum.magicmirror.builders/post/59127</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59127</guid><dc:creator><![CDATA[berne]]></dc:creator><pubDate>Thu, 18 Jul 2019 14:29:54 GMT</pubDate></item><item><title><![CDATA[Reply to Spotify module newbi on Thu, 18 Jul 2019 12:10:58 GMT]]></title><description><![CDATA[<p dir="auto">i@raspberrypi:~/MagicMirror/modules/MMM-NowPlayingonSpotify $ npm install<br />
npm WARN deprecated socks@1.1.10: If using 2.x branch, please upgrade to at least 2.1.6 to avoid a serious bug with socket data flow and an import issue introduced in 2.1.0<br />
npm notice created a lockfile as package-lock.json. You should commit this file.<br />
added 675 packages from 771 contributors and audited 4894 packages in 216.211s<br />
found 27 vulnerabilities (2 low, 5 moderate, 20 high)<br />
run <code>npm audit fix</code> to fix them, or <code>npm audit</code> for details</p>
]]></description><link>https://forum.magicmirror.builders/post/59122</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59122</guid><dc:creator><![CDATA[berne]]></dc:creator><pubDate>Thu, 18 Jul 2019 12:10:58 GMT</pubDate></item><item><title><![CDATA[Reply to Spotify module newbi on Thu, 18 Jul 2019 12:05:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/59120">Spotify module newbi</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/berne" aria-label="Profile: berne">@<bdi>berne</bdi></a> said in <a href="/post/59119">Spotify module newbi</a>:</p>
<p dir="auto">MMM-NowPlayingOnSpotify</p>
<p dir="auto">ok, from the MagicMirror/modules folder do</p>
<pre><code>ls
<p dir="auto">it will list the folders and files…</p>
<p dir="auto">linux is case sensitive</p>
<p dir="auto">$ cd  /home/pi/MagicMirror/modules<br />
pi@raspberrypi:~/MagicMirror/modules $ ls<br />
default  MMM-NowPlayingonSpotify  node_modules  package-lock.json  <a href="http://README.md" target="_blank" rel="noopener noreferrer nofollow ugc">README.md</a><br />
pi@raspberrypi:~/MagicMirror/modules $</p>
<p dir="auto">EDIT: i can see all the files in /home/pi/MagicMirror/Moduels/MMM-NowPlayingSpotify</p>
<p dir="auto">EDIT2 pi@raspberrypi:~/MagicMirror/modules/MMM-NowPlayingonSpotify $<br />
get the same result</p>
<p dir="auto">EDIT3<br />
i went to pi@raspberrypi:~/MagicMirror/modules/MMM-NowPlayingonSpotify  and then write npm install. i think thaht works:S</p>
]]></description><link>https://forum.magicmirror.builders/post/59121</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59121</guid><dc:creator><![CDATA[berne]]></dc:creator><pubDate>Thu, 18 Jul 2019 12:05:04 GMT</pubDate></item><item><title><![CDATA[Reply to Spotify module newbi on Thu, 18 Jul 2019 11:53:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/berne" aria-label="Profile: berne">@<bdi>berne</bdi></a> said in <a href="/post/59119">Spotify module newbi</a>:</p>
<pre><code>ls
]]></description><link>https://forum.magicmirror.builders/post/59120</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59120</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 18 Jul 2019 11:53:55 GMT</pubDate></item><item><title><![CDATA[Reply to Spotify module newbi on Thu, 18 Jul 2019 11:29:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/59117">Spotify module newbi</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/berne" aria-label="Profile: berne">@<bdi>berne</bdi></a> said in <a href="/post/59116">Spotify module newbi</a>:<br />
you should</p>
<pre><code>cd  /home/pi/MagicMirror/modules
<p dir="auto">then</p>
<pre><code>git clone https://github.com/raywo/MMM-NowPlayingOnSpotify
<pre><code>cd MMM-NowPlayingOnSpotify
<p dir="auto">does that work?</p>
<p dir="auto">i works to the last part, it saying the same, no file or folder</p>
]]></description><link>https://forum.magicmirror.builders/post/59119</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59119</guid><dc:creator><![CDATA[berne]]></dc:creator><pubDate>Thu, 18 Jul 2019 11:29:09 GMT</pubDate></item><item><title><![CDATA[Reply to Spotify module newbi on Thu, 18 Jul 2019 11:18:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/berne" aria-label="Profile: berne">@<bdi>berne</bdi></a> said in <a href="/post/59116">Spotify module newbi</a>:<br />
you should</p>
]]></description><link>https://forum.magicmirror.builders/post/59117</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59117</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 18 Jul 2019 11:18:57 GMT</pubDate></item></channel></rss>
