<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can You use a round lcd display with the magic mirror software?]]></title><description><![CDATA[<p dir="auto">Hi, I was wondering if it’s possible to use a round lcd display with magic mirror and properly use and take up the full dimensions of the display.</p>
<p dir="auto">Here’s the link of the display i’m thinking of using: <a href="https://das-tek.en.alibaba.com/product/60777676369-803264848/HDMI_to_MIPI_convert_board_3_4_inch_round_lcd_display_with_touch_panel.html" target="_blank" rel="noopener noreferrer nofollow ugc">HDMI to MIPI convert board 3.4 inch round lcd display with touch panel </a></p>
]]></description><link>https://forum.magicmirror.builders/topic/10808/can-you-use-a-round-lcd-display-with-the-magic-mirror-software</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Jul 2026 18:12:04 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10808.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 18 Jul 2019 16:30:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can You use a round lcd display with the magic mirror software? on Thu, 18 Jul 2019 21:55:20 GMT]]></title><description><![CDATA[<p dir="auto">I guess the keywords are <code>css</code> <code>canvas</code> <code>circle</code>.<br />
Something for the make-up artists on the forum.</p>
]]></description><link>https://forum.magicmirror.builders/post/59147</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59147</guid><dc:creator><![CDATA[evroom]]></dc:creator><pubDate>Thu, 18 Jul 2019 21:55:20 GMT</pubDate></item><item><title><![CDATA[Reply to Can You use a round lcd display with the magic mirror software? on Thu, 18 Jul 2019 21:45:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/idoodler" aria-label="Profile: idoodler">@<bdi>idoodler</bdi></a> Ok, I appreciate the help.</p>
]]></description><link>https://forum.magicmirror.builders/post/59146</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59146</guid><dc:creator><![CDATA[Timboats]]></dc:creator><pubDate>Thu, 18 Jul 2019 21:45:37 GMT</pubDate></item><item><title><![CDATA[Reply to Can You use a round lcd display with the magic mirror software? on Thu, 18 Jul 2019 21:17:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/timboats" aria-label="Profile: Timboats">@<bdi>Timboats</bdi></a> Everyting outside the circle will obviously be cropped. You would to heavily modify the CSS of MagicMirror (and maybe even of some of your used modules) to make this work.</p>
]]></description><link>https://forum.magicmirror.builders/post/59144</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59144</guid><dc:creator><![CDATA[idoodler]]></dc:creator><pubDate>Thu, 18 Jul 2019 21:17:10 GMT</pubDate></item><item><title><![CDATA[Reply to Can You use a round lcd display with the magic mirror software? on Thu, 18 Jul 2019 19:58:04 GMT]]></title><description><![CDATA[<p dir="auto">@Sean Yes, it is a 3.4 inch display if I understood properly.</p>
]]></description><link>https://forum.magicmirror.builders/post/59139</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59139</guid><dc:creator><![CDATA[Timboats]]></dc:creator><pubDate>Thu, 18 Jul 2019 19:58:04 GMT</pubDate></item><item><title><![CDATA[Reply to Can You use a round lcd display with the magic mirror software? on Thu, 18 Jul 2019 18:34:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/timboats" aria-label="Profile: Timboats">@<bdi>Timboats</bdi></a><br />
3.4"… too small to see?</p>
]]></description><link>https://forum.magicmirror.builders/post/59135</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59135</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Thu, 18 Jul 2019 18:34:18 GMT</pubDate></item></channel></rss>
