<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-meteoblueCurrent: Loading weather....???]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/19/meteoblue-current-weather-module">Meteoblue Current Weather Module</a></p>
<p dir="auto">I have implemented your Module, the MM2 is starting and then nothing happens.</p>
<p dir="auto">Loading weather…</p>
<p dir="auto">Can you tell me what is wrong in my config?<br />
It doesn’t work with your location and nor with my location lon, lat and asl values!</p>
<pre><code>                {
                        module: 'MMM-meteoblueCurrent',
                        position: 'top_right',
                                apikey: 'xxxxxxxxxxxx', // my personal api key is new and has 12 numbers or letters
                                city: 'Oberrieden',
                                lat: '47.2744',
                                lon: '8.5784',
                                asl: '464'
<pre><code>the log of mm2 tell me nothing is wrong. All other forecast modules are working:
0|mm       | No helper found for module: currentweather.
0|mm       | Initializing new module helper ...
0|mm       | No helper found for module: weatherforecast.
0|mm       | No helper found for module: wuforecast.
0|mm       | No helper found for module: mmm-weatherchart.
0|mm       | No helper found for module: MMM-forecast-io.
0|mm       | No helper found for module: MMM-meteoblueCurrent.
0|mm       | No helper found for module: netatmo.
0|mm       | No helper found for module: airquality.
]]></description><link>https://forum.magicmirror.builders/topic/1084/mmm-meteobluecurrent-loading-weather</link><generator>RSS for Node</generator><lastBuildDate>Sat, 12 Sep 2026 01:39:27 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1084.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 29 Nov 2016 20:18:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-meteoblueCurrent: Loading weather....??? on Wed, 21 Feb 2018 08:12:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ace0024" aria-label="Profile: ace0024">@<bdi>ace0024</bdi></a> said in <a href="/post/22462">MMM-meteoblueCurrent: Loading weather....???</a>:</p>
<p dir="auto">Hi,</p>
<p dir="auto">the problem is this:</p>
<p dir="auto">{<br />
“error_message”: “MB_REQUEST::DISPATCH: This datafeed is not authorized for your api key”,<br />
“info”: “Need help? Please contact <a href="mailto:info@meteoblue.com" target="_blank" rel="noopener noreferrer nofollow ugc">info@meteoblue.com</a> and provide this information”,<br />
“servertime”: 1496747976<br />
}</p>
<p dir="auto">I wrote meteo blue and here is the answer:</p>
<p dir="auto">Your URL query is an outdated JSON feed, which is no longer offered and supported by us. For non-commercial purposes we offer the Data package basic-day.</p>
<p dir="auto">I talked to the developer from MMM-meteoblueCurrent…answer:</p>
<p dir="auto">he will update this soon! Maybe next week!</p>
<p dir="auto">Is still no updated right?</p>
]]></description><link>https://forum.magicmirror.builders/post/36044</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/36044</guid><dc:creator><![CDATA[Ogret]]></dc:creator><pubDate>Wed, 21 Feb 2018 08:12:41 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-meteoblueCurrent: Loading weather....??? on Wed, 07 Jun 2017 19:10:13 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
}</p>
]]></description><link>https://forum.magicmirror.builders/post/22462</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/22462</guid><dc:creator><![CDATA[ace0024]]></dc:creator><pubDate>Wed, 07 Jun 2017 19:10:13 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-meteoblueCurrent: Loading weather....??? on Wed, 03 May 2017 08:51:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lolobyte" aria-label="Profile: lolobyte">@<bdi>lolobyte</bdi></a> can you start your mirror with <code>npm start dev</code> and check for errors there</p>
]]></description><link>https://forum.magicmirror.builders/post/21051</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21051</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Wed, 03 May 2017 08:51:07 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-meteoblueCurrent: Loading weather....??? on Mon, 01 May 2017 18:57:17 GMT]]></title><description><![CDATA[<p dir="auto">no, no help from the developer.</p>
]]></description><link>https://forum.magicmirror.builders/post/20918</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/20918</guid><dc:creator><![CDATA[lolobyte]]></dc:creator><pubDate>Mon, 01 May 2017 18:57:17 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-meteoblueCurrent: Loading weather....??? on Thu, 27 Apr 2017 19:55:46 GMT]]></title><description><![CDATA[<p dir="auto">Same Problem! Any Solution?</p>
]]></description><link>https://forum.magicmirror.builders/post/20629</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/20629</guid><dc:creator><![CDATA[ace0024]]></dc:creator><pubDate>Thu, 27 Apr 2017 19:55:46 GMT</pubDate></item></channel></rss>
