<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[overheating Pi &#x2F;freezing up and not responding]]></title><description><![CDATA[<p dir="auto">this is my first project ever using a pi<br />
so i’ve been trying to get my pi working for a while with both <a href="http://Hass.io" target="_blank" rel="noopener noreferrer nofollow ugc">Hass.io</a> using Docker CE and Magicmirror with the following modules</p>
<p dir="auto">default weather + weather forcast + news + compliments + clock<br />
MMM-GoogleTasks<br />
MMM-NowPlayingOnSpotify<br />
MMM-PublicTransportHafas</p>
<p dir="auto">but temps are getting really high above 60° and it’s freezing up when i edit or use any other app<br />
i have black heat sinks installed and Raspbee getaway install directly on gpio</p>
<p dir="auto">right now with magicmirror not working my temps are stable at 47° and my room temp is 20°<br />
i tried turning on open gl G1 but it was pretty much useless</p>
<p dir="auto">is it normal temps, should i get a better heatsinks with a fan?</p>
]]></description><link>https://forum.magicmirror.builders/topic/10849/overheating-pi-freezing-up-and-not-responding</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 11:28:40 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10849.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 26 Jul 2019 05:45:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to overheating Pi &#x2F;freezing up and not responding on Fri, 26 Jul 2019 06:39:19 GMT]]></title><description><![CDATA[<p dir="auto">Think you’ll find your shooting through the memory on the pi the only one that I’ve managed to have running for two days is the pi 4 with 4Gb of memory that seem to be ok on memory, but needs a big heatsink and an active fan, temps on min have been 61c but that’s not with the fan active my fan only activates when the tv is on then again the nest has recorded temps of 38/39c in the house so it’s not doing bad, the Pi4 is the hottest of the bunch.<br />
You say it’s not running it the screen off or the pi just running raspbian normally pm2 is running all the time so regardless of it being on a different screen or the screen turned off MagicMirror is running, you would have to pm2 stop MagicMirror in terminal but 47c looks like normal temps</p>
]]></description><link>https://forum.magicmirror.builders/post/59392</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59392</guid><dc:creator><![CDATA[dazza120]]></dc:creator><pubDate>Fri, 26 Jul 2019 06:39:19 GMT</pubDate></item></channel></rss>
