<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Firewall settings]]></title><description><![CDATA[<p dir="auto">Hello everyone,</p>
<p dir="auto">i have a MM2 up and running everything is fine, but there where it should work it will be behind a Firewall.<br />
So I need to now which ports and/or URLs the Mirror must comunicate to.<br />
I have asked google and just tested it with the ports for icals in the calendar but it doesn´t work.</p>
<p dir="auto">Modules:<br />
Calendar<br />
RSS<br />
Wheather<br />
and maybe all other things the Mirror need to comunicate to.</p>
<p dir="auto">Greeting Scrober</p>
]]></description><link>https://forum.magicmirror.builders/topic/1091/firewall-settings</link><generator>RSS for Node</generator><lastBuildDate>Fri, 10 Apr 2026 22:30:05 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1091.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 30 Nov 2016 15:35:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Firewall settings on Thu, 01 Dec 2016 14:17:10 GMT]]></title><description><![CDATA[<p dir="auto">Okay now i´ve fixed the RSS feed and the Calendar partly.<br />
When i worked it out i will declare it here.</p>
]]></description><link>https://forum.magicmirror.builders/post/8766</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8766</guid><dc:creator><![CDATA[Scrober]]></dc:creator><pubDate>Thu, 01 Dec 2016 14:17:10 GMT</pubDate></item><item><title><![CDATA[Reply to Firewall settings on Thu, 01 Dec 2016 13:06:56 GMT]]></title><description><![CDATA[<p dir="auto">I´ve tested it with free port 80(http) and 8080(alt-http) but it still don´t get any information out of the internet.<br />
For Calendar if opened up port 8008(ical) and 443(ssl) but still no Module loads it´s Data.</p>
]]></description><link>https://forum.magicmirror.builders/post/8765</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8765</guid><dc:creator><![CDATA[Scrober]]></dc:creator><pubDate>Thu, 01 Dec 2016 13:06:56 GMT</pubDate></item><item><title><![CDATA[Reply to Firewall settings on Wed, 30 Nov 2016 19:52:15 GMT]]></title><description><![CDATA[<p dir="auto">Normally, RSS Feeds and the Mirror as itsself should run on Port 80 and 8080 with default settings.<br />
I Think the Weather and Calendar will work on the same ports as they get the info from the web page api.</p>
]]></description><link>https://forum.magicmirror.builders/post/8739</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8739</guid><dc:creator><![CDATA[chrisyy]]></dc:creator><pubDate>Wed, 30 Nov 2016 19:52:15 GMT</pubDate></item></channel></rss>
