<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Problem if i want change the folder name]]></title><description><![CDATA[<p dir="auto">Hello everyone,</p>
<p dir="auto">here I am modifying a module and I would like to change the name of the folder in which the file js and the file node-helper.js are stored except that if I modify the file the console tells me node helper not found can u help me please? I can not find any solution to this problem. Thanks !</p>
]]></description><link>https://forum.magicmirror.builders/topic/10931/problem-if-i-want-change-the-folder-name</link><generator>RSS for Node</generator><lastBuildDate>Sun, 09 Aug 2026 02:06:27 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10931.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 08 Aug 2019 14:11:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Problem if i want change the folder name on Thu, 08 Aug 2019 14:57:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tsplinter" aria-label="Profile: TSplinter">@<bdi>TSplinter</bdi></a> no worries… glad u are working</p>
]]></description><link>https://forum.magicmirror.builders/post/59925</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59925</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 08 Aug 2019 14:57:10 GMT</pubDate></item><item><title><![CDATA[Reply to Problem if i want change the folder name on Thu, 08 Aug 2019 14:53:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Yeah now its ok sorry  :)</p>
]]></description><link>https://forum.magicmirror.builders/post/59923</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59923</guid><dc:creator><![CDATA[TSplinter]]></dc:creator><pubDate>Thu, 08 Aug 2019 14:53:54 GMT</pubDate></item><item><title><![CDATA[Reply to Problem if i want change the folder name on Thu, 08 Aug 2019 14:50:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tsplinter" aria-label="Profile: TSplinter">@<bdi>TSplinter</bdi></a> great!.. can u mark your issue resolved…</p>
]]></description><link>https://forum.magicmirror.builders/post/59921</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59921</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 08 Aug 2019 14:50:07 GMT</pubDate></item><item><title><![CDATA[Reply to Problem if i want change the folder name on Thu, 08 Aug 2019 14:37:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thanks dude its ok now ;)</p>
]]></description><link>https://forum.magicmirror.builders/post/59920</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59920</guid><dc:creator><![CDATA[TSplinter]]></dc:creator><pubDate>Thu, 08 Aug 2019 14:37:08 GMT</pubDate></item><item><title><![CDATA[Reply to Problem if i want change the folder name on Thu, 08 Aug 2019 14:26:23 GMT]]></title><description><![CDATA[<p dir="auto">Thanks to you now I do not have the message node-helper not found but the module does not show anyway I do not even have the loading of the message ^^" <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
]]></description><link>https://forum.magicmirror.builders/post/59918</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59918</guid><dc:creator><![CDATA[TSplinter]]></dc:creator><pubDate>Thu, 08 Aug 2019 14:26:23 GMT</pubDate></item><item><title><![CDATA[Reply to Problem if i want change the folder name on Thu, 08 Aug 2019 14:17:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tsplinter" aria-label="Profile: TSplinter">@<bdi>TSplinter</bdi></a> u need to change the name at the top of the module.js file to match the folder name, AND change the module name in config.js to match the folder name</p>
]]></description><link>https://forum.magicmirror.builders/post/59917</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59917</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 08 Aug 2019 14:17:58 GMT</pubDate></item></channel></rss>
