<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[EADDRINUSE assistant not working]]></title><description><![CDATA[<p dir="auto">Starting MagicMirror: v2.8.0<br />
Loading config …<br />
Loading module helpers …<br />
No helper found for module: alert.<br />
No helper found for module: compliments.<br />
Initializing new module helper …<br />
Module helper loaded: updatenotification<br />
No helper found for module: clock.<br />
Module helper loaded: calendar<br />
No helper found for module: currentweather.<br />
No helper found for module: weatherforecast.<br />
Module helper loaded: newsfeed<br />
Module helper loaded: MMM-AlexaPi<br />
Module helper loaded: MMM-NetworkConnection<br />
No helper found for module: MMM-iFrame.<br />
No helper found for module: MMM-page-indicator.<br />
Module helper loaded: MMM-MusicOnDemand<br />
Module helper loaded: MMM-AssistantMk2<br />
Module helper loaded: MMM-Hotword<br />
Module helper loaded: MMM-NotificationTrigger<br />
No helper found for module: MMM-pages.<br />
All module helpers loaded.<br />
Starting server on port 8080 …<br />
Server started …<br />
Connecting socket for: updatenotification<br />
Connecting socket for: calendar<br />
Starting node helper for: calendar<br />
Connecting socket for: newsfeed<br />
Starting module: newsfeed<br />
Connecting socket for: MMM-AlexaPi<br />
Starting node helper for: MMM-AlexaPi<br />
Connecting socket for: MMM-NetworkConnection<br />
MMM-NetworkConnection helper started …<br />
Connecting socket for: MMM-MusicOnDemand<br />
Connecting socket for: MMM-AssistantMk2<br />
Connecting socket for: MMM-Hotword<br />
[HOTWORD] MMM-Hotword starts<br />
Connecting socket for: MMM-NotificationTrigger<br />
Sockets connected &amp; modules started …<br />
Whoops! There was an uncaught exception…<br />
{ Error: listen EADDRINUSE 0.0.0.0:8080<br />
at Server.setupListenHandle [as _listen2] (net.js:1330:14)<br />
at listenInCluster (net.js:1378:12)<br />
at doListen (net.js:1492:7)<br />
at process._tickCallback (internal/process/next_tick.js:63:19)<br />
at Function.Module.runMain (internal/modules/cjs/loader.js:755:11)<br />
at startup (internal/bootstrap/node.js:241:19)<br />
at bootstrapNodeJSCore (internal/bootstrap/node.js:579:3)<br />
errno: ‘EADDRINUSE’,<br />
code: ‘EADDRINUSE’,<br />
syscall: ‘listen’,<br />
address: ‘0.0.0.0’,<br />
port: 8080 }<br />
MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?<br />
If you think this really is an issue, please open an issue on GitHub: <a href="https://github.com/MichMich/MagicMirror/issues" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/issues</a><br />
Launching application.<br />
n^CShutting down server…<br />
Stopping module helper: updatenotification<br />
Stopping module helper: calendar<br />
Stopping module helper: newsfeed<br />
Stopping module helper: MMM-AlexaPi<br />
Stopping module helper: MMM-NetworkConnection</p>
]]></description><link>https://forum.magicmirror.builders/topic/10934/eaddrinuse-assistant-not-working</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Jul 2026 23:27:29 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10934.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 08 Aug 2019 19:04:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to EADDRINUSE assistant not working on Thu, 08 Aug 2019 20:51:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/siddhartha" aria-label="Profile: siddhartha">@<bdi>siddhartha</bdi></a> while you think nothing is running do</p>
<pre><code>ps -ef | grep node
<p dir="auto">Does that produce more than 1 line of output?</p>
]]></description><link>https://forum.magicmirror.builders/post/59945</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59945</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 08 Aug 2019 20:51:00 GMT</pubDate></item><item><title><![CDATA[Reply to EADDRINUSE assistant not working on Thu, 08 Aug 2019 19:30:41 GMT]]></title><description><![CDATA[<p dir="auto">nope just one.</p>
]]></description><link>https://forum.magicmirror.builders/post/59942</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59942</guid><dc:creator><![CDATA[siddhartha]]></dc:creator><pubDate>Thu, 08 Aug 2019 19:30:41 GMT</pubDate></item><item><title><![CDATA[Reply to EADDRINUSE assistant not working on Thu, 08 Aug 2019 19:30:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/siddhartha" aria-label="Profile: siddhartha">@<bdi>siddhartha</bdi></a> they should be using the MagicMirror port, so not a problem</p>
<p dir="auto">Are two MagicMirrors trying to run at the same time?</p>
<p dir="auto">pm2 list</p>
]]></description><link>https://forum.magicmirror.builders/post/59941</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59941</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 08 Aug 2019 19:30:03 GMT</pubDate></item><item><title><![CDATA[Reply to EADDRINUSE assistant not working on Thu, 08 Aug 2019 19:12:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/siddhartha" aria-label="Profile: siddhartha">@<bdi>siddhartha</bdi></a> said in <a href="/post/59937">EADDRINUSE assistant not working</a>:</p>
<p dir="auto">Connecting socket for: MMM-MusicOnDemand<br />
Connecting socket for: MMM-NotificationTrigger</p>
<p dir="auto">these 4 module wants to connect to 8080 port but its already being used by remote control so what can i do now?</p>
]]></description><link>https://forum.magicmirror.builders/post/59940</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59940</guid><dc:creator><![CDATA[siddhartha]]></dc:creator><pubDate>Thu, 08 Aug 2019 19:12:08 GMT</pubDate></item><item><title><![CDATA[Reply to EADDRINUSE assistant not working on Thu, 08 Aug 2019 19:09:57 GMT]]></title><description><![CDATA[<p dir="auto">yes i am using pm2 .</p>
<p dir="auto">any idea how can i make assistantmk2 to use some other port ??</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/59939</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59939</guid><dc:creator><![CDATA[siddhartha]]></dc:creator><pubDate>Thu, 08 Aug 2019 19:09:57 GMT</pubDate></item><item><title><![CDATA[Reply to EADDRINUSE assistant not working on Thu, 08 Aug 2019 19:07:44 GMT]]></title><description><![CDATA[<p dir="auto">Something else is using port 8080.  Are u using pm2?</p>
<p dir="auto">pm2 stop 0 ( or it’s name from the list)</p>
]]></description><link>https://forum.magicmirror.builders/post/59938</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59938</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 08 Aug 2019 19:07:44 GMT</pubDate></item></channel></rss>
