<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[New project in mind]]></title><description><![CDATA[<p dir="auto">Greetings and my apologies if this is not the right forum where to post this.<br />
I understand that this is some sort of DIY initiative but I have a project in mind where MagicMirror fits perfectly.<br />
The final product would look like many of the different ones that you guys have been sharing on the Show Your Mirror sub-forum but the background would change every week, ideally updating over the internet.<br />
Is that feasible?<br />
Also, if the project finally goes ahead, can anyone recommend a website for contractors?<br />
Thanks,<br />
AG</p>
]]></description><link>https://forum.magicmirror.builders/topic/10959/new-project-in-mind</link><generator>RSS for Node</generator><lastBuildDate>Fri, 05 Jun 2026 21:50:30 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10959.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 12 Aug 2019 21:40:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to New project in mind on Sat, 17 Aug 2019 10:44:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/betialai" aria-label="Profile: Betialai">@<bdi>Betialai</bdi></a></p>
<p dir="auto">I suppose you must change the slideInterval parameter on the module config.</p>
<p dir="auto">By default it’s configured to change every 5 minutes:</p>
<pre><code>slideInterval 	5 * 60 * 1000
<p dir="auto">If you change that value for this one:</p>
<pre><code>slideInterval 	10080 * 60 * 1000
<p dir="auto">It must be change every 7 days.</p>
<p dir="auto">7 x 24 = 168 hours a week.<br />
168 x 60 = 10080 minutes a week.</p>
<p dir="auto">Hope it helps</p>
]]></description><link>https://forum.magicmirror.builders/post/60167</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/60167</guid><dc:creator><![CDATA[qu1que]]></dc:creator><pubDate>Sat, 17 Aug 2019 10:44:24 GMT</pubDate></item><item><title><![CDATA[Reply to New project in mind on Sat, 17 Aug 2019 09:38:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/qu1que" aria-label="Profile: qu1que">@<bdi>qu1que</bdi></a> Cheers, that would do the trick. However, the idea is to change the background every week. That is, old background gets deleted, new background shows up.<br />
Or else, new background available and shows up, with user/customer having access to the previous backgrounds.</p>
]]></description><link>https://forum.magicmirror.builders/post/60166</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/60166</guid><dc:creator><![CDATA[Betialai]]></dc:creator><pubDate>Sat, 17 Aug 2019 09:38:04 GMT</pubDate></item><item><title><![CDATA[Reply to New project in mind on Tue, 13 Aug 2019 11:02:27 GMT]]></title><description><![CDATA[<p dir="auto">thanks for asking this question as i were also looking for answers</p>
]]></description><link>https://forum.magicmirror.builders/post/60053</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/60053</guid><dc:creator><![CDATA[spotytomp3]]></dc:creator><pubDate>Tue, 13 Aug 2019 11:02:27 GMT</pubDate></item><item><title><![CDATA[Reply to New project in mind on Mon, 12 Aug 2019 23:17:46 GMT]]></title><description><![CDATA[<p dir="auto">I also use one of the image display modules, to display a background image.   I do it every 15 minutes, but it could be longer</p>
]]></description><link>https://forum.magicmirror.builders/post/60046</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/60046</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 12 Aug 2019 23:17:46 GMT</pubDate></item><item><title><![CDATA[Reply to New project in mind on Mon, 12 Aug 2019 21:47:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/betialai" aria-label="Profile: Betialai">@<bdi>Betialai</bdi></a></p>
<p dir="auto">Take a look at this module:</p>
<p dir="auto"><a href="https://github.com/kolbyjack/MMM-Wallpaper" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/kolbyjack/MMM-Wallpaper</a></p>
<p dir="auto">I think what you propose already exists</p>
]]></description><link>https://forum.magicmirror.builders/post/60043</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/60043</guid><dc:creator><![CDATA[qu1que]]></dc:creator><pubDate>Mon, 12 Aug 2019 21:47:16 GMT</pubDate></item></channel></rss>
