<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[&quot;Error: Cannot find module &#x27;ping&#x27; &quot; and black screen on startup (Beginner)]]></title><description><![CDATA[<p dir="auto">Not sure entirely what’s happening, as I’m super new to Raspberry Pi and everything involved with it. At first, I thought it was an issue with the module (MMM-network-signal) so I removed it from my config.js but I’m still getting the error. I’ve installed all the dependencies as well.</p>
<p dir="auto">Any help would be appriciated!</p>
<p dir="auto">config (sorry for the messy code):</p>
 * MIT Licensed.
var config = {
	port: 8080,
	language: "en",
	timeFormat: 12,
	units: "imperial",
			module: "alert",
			module: "updatenotification",
			position: "top_bar"
			module: "clock",
			position: "top_left"
			header: "US Holidays",
						symbol: "calendar-check",
						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
			module: "MMM-network-signal",
			module: "currentweather",
				locationID: "5819347",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
				appid: "d78a6e9838b2fa659664f139495fda91",
			module: "weatherforecast",
			header: "Weather Forecast",
			module: 'MMM-OnScreenMenu',
			position: 'bottom_right',
			/* Valid positions: 'top_right', 'top_left', 'bottom_right', 'bottom_left' */
				touchMode: true,
				enableKeyboard: true,
				// ... see more options below
        module: 'MMM-Events',
        position: 'bottom_left',
		city: "Boulder",              // Your City
		eventType: "music_dance,music_pop,music_easy_listening,music_folk,music_rock,music_alternative,performing_arts_musical,performing_arts_comedy,comedy,movies_film,movies_film_filmfestival",            // See Events List in ReadMe
		when: "Next Week",             // "All", "Future", "Past", "Today", "Last Week", "This Week", "Next week", and months by name, e.g. "October"
       		mode: "noFrame",               // Frame or noFrame (around picture)
       		apikey: "SJw8XkCWk7qj8cC3",
		rotateInterval: 5 * 60 * 1000, // New Event Appears
		useHeader: true,
        	header: "Events",
		maxWidth: "195px",             // adjust to your liking
		animationSpeed: 3000,          // Event fades in and out
        	initialLoadDelay: 4250,
        	retryDelay: 2500,
		updateInterval: 60 * 60 * 1000, // 60 minutes. No need to change!
		picture: false,                  // true, false = no picture
        module: 'MMM-Strava',
        position: 'lower_third',
            strava_id: '11175670',
            access_token: '225112bc74d27f282bfcb445393f1205d1440d8b'
        module: 'MMM-MovieListings',
    		apiKey: 'c5e8b03ed6966b680e8addc68f87afd3',
		region: 'US',
    		language: 'en-US',
    		interface: 'poster', //'list', 'poster', 'detailed'
    		includeMoviePlot: true,
    		maxPlotLength: 198,
    		header: 'Movies',
    		moviesPerPage: 1,
    		refreshInterval: 1000 * 60 * 60 * 24, //Once a day
    		baseUrl: 'https://api.themoviedb.org/3/movie/now_playing',
    		animationSpeed: 2.5 * 1000,
    		pageChangeInterval: 30 * 1000
  		module: "MMM-NowPlayingOnSpotify",
  		position: "bottom_left",
    			clientID: "a60da971b5884399a581d132c221ce27",
    			clientSecret: "d064d24a94ca4fbb9e3efeeea6767da7",
    			accessToken: "BQDC5F33IPjzt_ksr2t1mLFtTUBOXzlq5FBDu5gKSqwxshbuM9geAGVh9y8fNqQYmN_8W9f36SdorRo6zRRX98pK8UuI62pOoJOCbeGkqKKW8x4XzY4Ol040kHIyotIS7wKMjTWTfUVbpzppP4zVw-ZL",
    			refreshToken: "AQAxiQB-7To8nb3Rv6ICfFT4mFxLGiTWS2XnKeJUi5KHatnMaMpwMvyq5ULtBKz_MEjxh5uBeyaF2cRWmOVgz3SqItqpii54rmEsHeh3Ubcl63p_y3St1skXeqx4iPOCGuj8jA",
			showCoverArt: false
			module: "newsfeed",
			position: "bottom_bar",
				feeds: [
						title: "New York Times",
				showSourceTitle: true,
				showPublishDate: true,
				broadcastNewsFeeds: true,
				broadcastNewsUpdates: true
]]></description><link>https://forum.magicmirror.builders/topic/10974/error-cannot-find-module-ping-and-black-screen-on-startup-beginner</link><generator>RSS for Node</generator><lastBuildDate>Tue, 19 May 2026 13:14:22 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10974.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 16 Aug 2019 02:01:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to &quot;Error: Cannot find module &#x27;ping&#x27; &quot; and black screen on startup (Beginner) on Fri, 16 Aug 2019 17:01:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/keyk123" aria-label="Profile: keyk123">@<bdi>keyk123</bdi></a> said in <a href="/post/60134">"Error: Cannot find module 'ping' " and black screen on startup (Beginner)</a>:</p>
<p dir="auto">npm WARN npm npm does not support Node.js v10.15.2</p>
<p dir="auto">Update npm:</p>
<pre><code>pi@raspberrypi:~ $ npm -v
5.8.0
pi@raspberrypi:~ $ cd
pi@raspberrypi:~ $ sudo npm install npm@latest -g
[ pi@raspberrypi:~ $ sudo reboot ]
6.10.3
<p dir="auto">When in doubt if you’re config.js is okay, always run:</p>
<pre><code>pi@raspberrypi:~ $ cd ~/MagicMirror; npm run config:check
]]></description><link>https://forum.magicmirror.builders/post/60153</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/60153</guid><dc:creator><![CDATA[evroom]]></dc:creator><pubDate>Fri, 16 Aug 2019 17:01:36 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;Error: Cannot find module &#x27;ping&#x27; &quot; and black screen on startup (Beginner) on Fri, 16 Aug 2019 16:33:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/keyk123" aria-label="Profile: keyk123">@<bdi>keyk123</bdi></a> Can you cd into the MMM-network-signal module folder, <code>cd ~/MagicMirror/modules/MMM-network-signal</code> and run <code>npm install</code>? It requires you to run the command so that it can install all the dependencies. Try that and let us know if it solved your problem.</p>
]]></description><link>https://forum.magicmirror.builders/post/60152</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/60152</guid><dc:creator><![CDATA[mumblebaj]]></dc:creator><pubDate>Fri, 16 Aug 2019 16:33:24 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;Error: Cannot find module &#x27;ping&#x27; &quot; and black screen on startup (Beginner) on Fri, 16 Aug 2019 16:22:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/keyk123" aria-label="Profile: keyk123">@<bdi>keyk123</bdi></a> Can you edit your post and remove your keys etc?</p>
]]></description><link>https://forum.magicmirror.builders/post/60151</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/60151</guid><dc:creator><![CDATA[mumblebaj]]></dc:creator><pubDate>Fri, 16 Aug 2019 16:22:36 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;Error: Cannot find module &#x27;ping&#x27; &quot; and black screen on startup (Beginner) on Fri, 16 Aug 2019 02:15:12 GMT]]></title><description><![CDATA[<p dir="auto">If it helps, here’s what the terminal spits out</p>
<pre><code>pi@raspberrypi:~/MagicMirror $ npm start
npm WARN npm You should probably upgrade to a newer version of node as we
npm WARN npm can't make any promises that npm will work with this version.
npm WARN npm Supported releases of Node.js are the latest release of 4, 6, 7, 8, 9.
npm WARN npm You can find the latest version at https://nodejs.org/
&gt; magicmirror@2.8.0 start /home/pi/MagicMirror
&gt; sh run-start.sh
Starting MagicMirror: v2.8.0
Loading config ...
Loading module helpers ...
WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'ping'
App threw an error during load
    at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
    at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
    at Function.Module._load (internal/modules/cjs/loader.js:528:25)
    at Module.require (internal/modules/cjs/loader.js:658:17)
    at require (internal/modules/cjs/helpers.js:20:18)
    at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/modules/MMM-network-signal/node_helper.js:2:14)
    at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/modules/MMM-network-signal/node_helper.js:35:3)
    at Module._compile (internal/modules/cjs/loader.js:711:30)
    at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
    at Module.load (internal/modules/cjs/loader.js:620:32)
{ Error: Cannot find module 'ping'
    at Module.load (internal/modules/cjs/loader.js:620:32) code: 'MODULE_NOT_FOUND' }
Launching application.
]]></description><link>https://forum.magicmirror.builders/post/60134</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/60134</guid><dc:creator><![CDATA[keyk123]]></dc:creator><pubDate>Fri, 16 Aug 2019 02:15:12 GMT</pubDate></item></channel></rss>
