<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[readFileSync]]></title><description><![CDATA[<p dir="auto">I’ll preface this by saying I’m fairly new at nodejs, so maybe I’m doing something totally stupid. I’ve been beating my head on this for a while now…  Not making any sense to me whatsoever, googling like crazy and still totally stuck.</p>
<p dir="auto">I have bigger plans (reading a locally updated JSON file and displaying frequently updated data to the screen), but as nothing seemed to work I kept paring and paring the project back to where I’m now simply trying to display static contents of a local file to the screen. I altered helloworld to try to do this simple task.  Note that the file ‘/home/pi/test.txt’ is simply the word “test”, and has permissions set to where anyone can read it.  I’m also loading other modules just so I know something’s working.</p>
<p dir="auto">The following code locks up the mirror, displaying simply a black screen. Note that I am not even attempting to display the file at this point, I’m simply trying to load it into the variable ‘file’.</p>
<pre><code>Module.register("helloworld",{
        getDom: function() {
                var file = require('fs').readFileSync('/home/pi/test.txt', 'utf8');
                wrapper.innerHTML = "Hello";
                return wrapper;
<p dir="auto">I can tell that the issue is my loading line because I can comment it out thusly and all the modules display, including the “Hello” text:</p>
//              var file = require('fs').readFileSync('/home/pi/test.txt', 'utf8');
                return wrapper;
<p dir="auto">OK, so maybe there’s a problem with my loading statement.  Easy to check, copy/past the line into a js file and run it:</p>
<p dir="auto">test.js:</p>
<pre><code>var file = require('fs').readFileSync('/home/pi/test.txt', 'utf8');
console.log(file);
<p dir="auto">And here’s what happens:</p>
<pre><code>pi@lugarpi:~ $ nodejs test.js
test
<p dir="auto">Works perfectly fine in nodejs but if I put that line of code into the module it locks up the mirror.  Am I missing something here?  Also, I’m launching mirror through pm2. I understood any errors should show up in ~/.pm2/logs but the error log doesn’t show anything.</p>
]]></description><link>https://forum.magicmirror.builders/topic/110/readfilesync</link><generator>RSS for Node</generator><lastBuildDate>Sun, 10 May 2026 14:25:31 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/110.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 17 May 2016 20:43:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to readFileSync on Thu, 19 May 2016 19:04:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kirash4" aria-label="Profile: KirAsh4">@<bdi>KirAsh4</bdi></a> Yeah, it is working for me as I want it.  I figured it wouldn’t be overly useful to others anyhow since there was a lot of back-end work to do (namely setting up json streams that match the module code from the weather station, uploading to an appropriate location).</p>
<p dir="auto">Screenshot of my current display is below.  It updates every 5 seconds using data from my local Davis weather station running Cumulus software.  The rain information (total daily rain on top left, current rain rate at bottom left) only display if there has been rain today or it is currently raining respectively.  It will also display winds like  “12 G23” if the winds hit gust criteria (over 18MPH gusts and more than 10MPH over the wind speed). It is pretty trivial to put any information you can get into the json file to display.</p>
<p dir="auto">I’d be happy to try to properly modularize this if there is some interest, there’s just so many options and variations of stations/json exports/etc that I’m not sure I’d know where to start.</p>
<p dir="auto"><img src="http://s32.postimg.org/mvdih2g79/Capture.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/829</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/829</guid><dc:creator><![CDATA[mattlugar]]></dc:creator><pubDate>Thu, 19 May 2016 19:04:48 GMT</pubDate></item><item><title><![CDATA[Reply to readFileSync on Thu, 19 May 2016 18:43:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/michmich" aria-label="Profile: MichMich">@<bdi>MichMich</bdi></a> said in <a href="/topic/110/readfilesync/15">readFileSync</a>:</p>
<p dir="auto">The root argument refers to the root directory from which the static assets are to be served.</p>
<p dir="auto">That’s part of the answer I was looking for. Specifically, <code>'from which the static assets are to be served'</code>. Now to figure out where those are, or where they are allowed to be rather. Basically I’m looking at it from a security stand point. Where is this thing going to allow a user to get to, to fetch a file.</p>
]]></description><link>https://forum.magicmirror.builders/post/828</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/828</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Thu, 19 May 2016 18:43:05 GMT</pubDate></item><item><title><![CDATA[Reply to readFileSync on Thu, 19 May 2016 18:37:04 GMT]]></title><description><![CDATA[<p dir="auto">I’ve got the feeling we’re talking about something different.</p>
<p dir="auto">The example:</p>
<pre><code>this.expressApp.get('/foobar', function (req, res) {
        res.send('GET request to /foobar');
<p dir="auto">does not serve any file. So talking about file location doesn’t make any sense in this case. In this example It just serves the text string <code>GET request to /foobar</code></p>
<p dir="auto">In the second example:</p>
<pre><code>this.expressApp.use("/foobar" + this.name, this.expressApp.static(this.path + "/foobar"));
<p dir="auto">only the <code>express.static(root, [options])</code> part refers to a file or folder. The root argument refers to the root directory from which the static assets are to be served.</p>
<p dir="auto">More info about express.static can be found here: <a href="http://expressjs.com/en/api.html#express.static" target="_blank" rel="noopener noreferrer nofollow ugc">http://expressjs.com/en/api.html#express.static</a></p>
]]></description><link>https://forum.magicmirror.builders/post/827</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/827</guid><dc:creator><![CDATA[MichMich]]></dc:creator><pubDate>Thu, 19 May 2016 18:37:04 GMT</pubDate></item><item><title><![CDATA[Reply to readFileSync on Thu, 19 May 2016 18:18:11 GMT]]></title><description><![CDATA[<p dir="auto">No, it doesn’t have anything to do with the contents. It has to do with where that file resides on the physical system. For example, a request to a default Apache installation will look for a file in <code>'/var/www/html/'</code> or <code>'$USER/public_html'</code> or whatever the system admin has configured it as. In this case, this is a specific request through the Node.js system, being called by MM, so where does it look for that file? Within the user’s folder? Within MM’s installation folder? Within the actual module’s folder? Or does Node.js allow access to the entire file system? So that if I do a call such as:</p>
<pre><code>this.expressAp.use("/etc/passwd")
<p dir="auto">will I actually get the contents of the system’s <code>'/etc/passwd'</code> file, or is going to try to read <code>'/path/to/MM-install/etc/passwd'</code> or some other path?</p>
]]></description><link>https://forum.magicmirror.builders/post/826</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/826</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Thu, 19 May 2016 18:18:11 GMT</pubDate></item><item><title><![CDATA[Reply to readFileSync on Thu, 19 May 2016 18:39:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kirash4" aria-label="Profile: KirAsh4">@<bdi>KirAsh4</bdi></a> it hasnt got anything to do with a file. It’s just a request, if you want to respond with the contents of a file, you need to do that yourself or use the following method if you want to feed a full folder:</p>
]]></description><link>https://forum.magicmirror.builders/post/825</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/825</guid><dc:creator><![CDATA[MichMich]]></dc:creator><pubDate>Thu, 19 May 2016 18:39:15 GMT</pubDate></item><item><title><![CDATA[Reply to readFileSync on Thu, 19 May 2016 17:44:02 GMT]]></title><description><![CDATA[<p dir="auto">So then the question is still, where is that <code>'/foobar'</code> ? What’s that in relation to? The MM install? The module’s folder?</p>
]]></description><link>https://forum.magicmirror.builders/post/822</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/822</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Thu, 19 May 2016 17:44:02 GMT</pubDate></item><item><title><![CDATA[Reply to readFileSync on Thu, 19 May 2016 17:41:11 GMT]]></title><description><![CDATA[<p dir="auto">Exactly.</p>
]]></description><link>https://forum.magicmirror.builders/post/821</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/821</guid><dc:creator><![CDATA[MichMich]]></dc:creator><pubDate>Thu, 19 May 2016 17:41:11 GMT</pubDate></item><item><title><![CDATA[Reply to readFileSync on Thu, 19 May 2016 17:30:42 GMT]]></title><description><![CDATA[<p dir="auto">Ah, so it’s still an HTTP call then, not a simple fileread from disk.</p>
]]></description><link>https://forum.magicmirror.builders/post/819</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/819</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Thu, 19 May 2016 17:30:42 GMT</pubDate></item><item><title><![CDATA[Reply to readFileSync on Thu, 19 May 2016 17:22:16 GMT]]></title><description><![CDATA[<p dir="auto">If you are referring to this snippet:</p>
<pre><code>start: function() {
<p dir="auto">The <code>/foobar</code> is referring to the url:  <code>http://localhost:8080/foobar</code></p>
]]></description><link>https://forum.magicmirror.builders/post/815</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/815</guid><dc:creator><![CDATA[MichMich]]></dc:creator><pubDate>Thu, 19 May 2016 17:22:16 GMT</pubDate></item><item><title><![CDATA[Reply to readFileSync on Thu, 19 May 2016 17:11:49 GMT]]></title><description><![CDATA[<p dir="auto">I saw that when I was fiddling with some other stuff, but never actually tested it. Is that path relative to the actual module location? Or MM’s installation? Or the user that’s running MM? So if <code>'/foo/bar/baz'</code> is defined, where does it start?</p>
<pre><code>/foo/bar/baz? (OH PLEASE SAY NO, for the love of all that is sacred, tell me Node.js does NOT allow system reads like that!)
$HOME/foo/bar/baz ?
$HOME/MagicMirror/foo/bar/baz?
$HOME/MagicMirror/modules/foo/bar/baz?
$HOME/MagicMirror/modules/&lt;MODULE&gt;/foo/bar/baz?
]]></description><link>https://forum.magicmirror.builders/post/813</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/813</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Thu, 19 May 2016 17:11:49 GMT</pubDate></item><item><title><![CDATA[Reply to readFileSync on Thu, 19 May 2016 17:04:51 GMT]]></title><description><![CDATA[<p dir="auto">Just so you know, the node_helper can serve files as well: <a href="https://github.com/MichMich/MagicMirror/tree/master/modules#thisexpressapp" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/tree/master/modules#thisexpressapp</a></p>
]]></description><link>https://forum.magicmirror.builders/post/807</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/807</guid><dc:creator><![CDATA[MichMich]]></dc:creator><pubDate>Thu, 19 May 2016 17:04:51 GMT</pubDate></item><item><title><![CDATA[Reply to readFileSync on Thu, 19 May 2016 15:55:02 GMT]]></title><description><![CDATA[<p dir="auto">I suppose that’s one way to do that … doesn’t make it very portable or sharable to others. It’s no longer contained within only MM and Node.js … But, if it’s working for you and does what you want, that’s the only thing that matters.</p>
]]></description><link>https://forum.magicmirror.builders/post/802</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/802</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Thu, 19 May 2016 15:55:02 GMT</pubDate></item><item><title><![CDATA[Reply to readFileSync on Thu, 19 May 2016 00:54:13 GMT]]></title><description><![CDATA[<p dir="auto">Yeah, I went about it differently than I wanted to. I ended up porting everything to an apache directory so it serves itself as a webapp.  Had a few bugs to work out (it was locking up if the json was in the middle of writing when it was retrieved) but I have it working and bug free now best I can tell :)</p>
]]></description><link>https://forum.magicmirror.builders/post/784</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/784</guid><dc:creator><![CDATA[mattlugar]]></dc:creator><pubDate>Thu, 19 May 2016 00:54:13 GMT</pubDate></item><item><title><![CDATA[Reply to readFileSync on Wed, 18 May 2016 18:18:02 GMT]]></title><description><![CDATA[<p dir="auto">That’s because <code>require</code> isn’t part of JavaScript. It’s part of node.js to load modules. There are potentially other ways of doing what you’re trying to do. You may want to check out <a href="http://stackoverflow.com/questions/9901082/what-is-this-javascript-require" target="_blank" rel="noopener noreferrer nofollow ugc">this post on Stack Overflow</a>.</p>
]]></description><link>https://forum.magicmirror.builders/post/775</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/775</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Wed, 18 May 2016 18:18:02 GMT</pubDate></item><item><title><![CDATA[Reply to readFileSync on Wed, 18 May 2016 14:26:37 GMT]]></title><description><![CDATA[<p dir="auto">That’s where my lack of knowledge on how to debug in this new environment was hurting me.  Was able to figure out a better way to debug and now have something to work with.</p>
<pre><code>Uncaught ReferenceError: require is not defined
<p dir="auto">Off to roll up my sleeves and do some mad google-fu.</p>
<p dir="auto">Thank you!  :)</p>
]]></description><link>https://forum.magicmirror.builders/post/771</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/771</guid><dc:creator><![CDATA[mattlugar]]></dc:creator><pubDate>Wed, 18 May 2016 14:26:37 GMT</pubDate></item><item><title><![CDATA[Reply to readFileSync on Wed, 18 May 2016 08:53:55 GMT]]></title><description><![CDATA[<p dir="auto">What does it lockup? The fronted? Or the backend?</p>
<p dir="auto">If it’s just the frontend, check your webinspector/console to see what’s going on.</p>
]]></description><link>https://forum.magicmirror.builders/post/765</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/765</guid><dc:creator><![CDATA[MichMich]]></dc:creator><pubDate>Wed, 18 May 2016 08:53:55 GMT</pubDate></item></channel></rss>
