<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Running npm Start - stuck White Screen]]></title><description><![CDATA[<p dir="auto">I am seeing the samething. One minute the magic mirror was great, so rebooted and now it just loads a white screen.<br />
the Only changes i have made to the MM code is the custom Weather api, and ical.</p>
<p dir="auto">I was thinking maybe unclutter was causing the screen to white out so i removed it. no changes. any help would be awesome! :)</p>
<p dir="auto">Debug logs<br />
0 info it worked if it ends with ok<br />
1 verbose cli [ ‘/usr/bin/nodejs’, ‘/usr/bin/npm’, ‘start’ ]<br />
2 info using npm@3.10.8<br />
3 info using node@v6.9.1<br />
4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]<br />
5 info lifecycle magicmirror@2.0.0~prestart: magicmirror@2.0.0<br />
6 silly lifecycle magicmirror@2.0.0~prestart: no script for prestart, continuing<br />
7 info lifecycle magicmirror@2.0.0~start: magicmirror@2.0.0<br />
8 verbose lifecycle magicmirror@2.0.0~start: unsafe-perm in lifecycle true<br />
9 verbose lifecycle magicmirror@2.0.0~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/root/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin<br />
10 verbose lifecycle magicmirror@2.0.0~start: CWD: /root/MagicMirror<br />
11 silly lifecycle magicmirror@2.0.0~start: Args: [ ‘-c’, ‘electron js/electron.js’ ]<br />
12 info lifecycle magicmirror@2.0.0~start: Failed to exec start script<br />
13 verbose stack Error: magicmirror@2.0.0 start: <code>electron js/electron.js</code><br />
13 verbose stack spawn ENOENT<br />
13 verbose stack     at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:33:16)<br />
13 verbose stack     at emitTwo (events.js:106:13)<br />
13 verbose stack     at ChildProcess.emit (events.js:191:7)<br />
13 verbose stack     at maybeClose (internal/child_process.js:877:16)<br />
13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)<br />
14 verbose pkgid magicmirror@2.0.0<br />
15 verbose cwd /root/MagicMirror<br />
16 error Linux 4.4.30-v7+<br />
17 error argv “/usr/bin/nodejs” “/usr/bin/npm” “start”<br />
18 error node v6.9.1<br />
19 error npm  v3.10.8<br />
20 error file sh<br />
21 error code ELIFECYCLE<br />
22 error errno ENOENT<br />
23 error syscall spawn<br />
24 error magicmirror@2.0.0 start: <code>electron js/electron.js</code><br />
24 error spawn ENOENT<br />
25 error Failed at the magicmirror@2.0.0 start script ‘electron js/electron.js’.<br />
25 error Make sure you have the latest version of node.js and npm installed.<br />
25 error If you do, this is most likely a problem with the magicmirror package,<br />
25 error not with npm itself.<br />
25 error Tell the author that this fails on your system:<br />
25 error     electron js/electron.js<br />
25 error You can get information on how to open an issue for this project with:<br />
25 error     npm bugs magicmirror<br />
25 error Or if that isn’t available, you can get their info via:<br />
25 error     npm owner ls magicmirror<br />
25 error There is likely additional logging output above.<br />
26 verbose exit [ 1, true ]</p>
]]></description><link>https://forum.magicmirror.builders/topic/1103/running-npm-start-stuck-white-screen</link><generator>RSS for Node</generator><lastBuildDate>Wed, 09 Sep 2026 16:04:09 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1103.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 01 Dec 2016 22:15:17 GMT</pubDate><ttl>60</ttl></channel></rss>
