<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Sample config not working with MMM-CalendarExt2]]></title><description><![CDATA[<p dir="auto">I only see the daily view in the top left of the screen. Everything else is dark.</p>
 * MIT Licensed.
var config = {
	port: 8080,
	language: "en",
	timeFormat: 24,
	units: "metric",
			module: 'MMM-CalendarExt2',
				calendars : [
					url: "https://www.google.com/calendar/ical/ovb564thnod82u5c4njut98728%40group.calendar.google.com/public/basic.ics",
				views: [
					mode: "daily",
				scenes: [
]]></description><link>https://forum.magicmirror.builders/topic/11031/sample-config-not-working-with-mmm-calendarext2</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Jul 2026 05:44:46 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11031.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 23 Aug 2019 19:11:41 GMT</pubDate><ttl>60</ttl></channel></rss>
