<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[I am givning up.. new install]]></title><description><![CDATA[<p dir="auto">I can’t get any mic to work on my MM, so I am think of doing a new install.<br />
But I wonder if I can save, my confi.js and the module folder, and swap them after the new install, so I don’t need to do it all over again.<br />
I have token, Alexa token and so on.<br />
So that files should’ve making copy’s of before, I wipe the sd card<br />
And what system should I install to get it right the right start:</p>
<p dir="auto">Raspbian Buster with desktop and recommended software<br />
Or</p>
<p dir="auto">Raspbian Buster with desktop<br />
Or<br />
Raspbian Buster Lite</p>
]]></description><link>https://forum.magicmirror.builders/topic/11039/i-am-givning-up-new-install</link><generator>RSS for Node</generator><lastBuildDate>Tue, 08 Sep 2026 04:02:16 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11039.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 24 Aug 2019 22:23:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to I am givning up.. new install on Tue, 27 Aug 2019 03:14:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/otto" aria-label="Profile: otto">@<bdi>otto</bdi></a> said in <a href="/post/60397">I am givning up.. new install</a>:</p>
<p dir="auto">cannot load mixer controls: Ogiltigt argument</p>
<p dir="auto">Did you tried the command I gave you? Thoses a just to validate that your mic is working, after you can work on alsamixer.  The basic command are great tools to make sure stuff is working as you want.</p>
<p dir="auto">Maybe a long shot but did you tried the following solution provided here?<br />
<a href="https://askubuntu.com/questions/765396/alsamixer-cannot-open-mixer-invalid-argument" target="_blank" rel="noopener noreferrer nofollow ugc">https://askubuntu.com/questions/765396/alsamixer-cannot-open-mixer-invalid-argument</a></p>
<p dir="auto">It seems alsamixer can be tricky to config and some files need to be created manually (sound is muted by default at install).</p>
]]></description><link>https://forum.magicmirror.builders/post/60427</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/60427</guid><dc:creator><![CDATA[smassy]]></dc:creator><pubDate>Tue, 27 Aug 2019 03:14:43 GMT</pubDate></item><item><title><![CDATA[Reply to I am givning up.. new install on Sun, 25 Aug 2019 18:42:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/smassy" aria-label="Profile: smassy">@<bdi>smassy</bdi></a> the problem is when i go to alsamixe, and F6 and selcet the usb i whnat to use, i get this:</p>
<p dir="auto">pi@raspberrypi:~ $ alsamixer<br />
<p dir="auto">and if go the settings i selcet the usb, it mutes the sound, cant use my spekars… is so stanges… i have been trying to fix this for over 4week now, and cant find any solution to it,</p>
]]></description><link>https://forum.magicmirror.builders/post/60397</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/60397</guid><dc:creator><![CDATA[otto]]></dc:creator><pubDate>Sun, 25 Aug 2019 18:42:30 GMT</pubDate></item><item><title><![CDATA[Reply to I am givning up.. new install on Sun, 25 Aug 2019 00:41:43 GMT]]></title><description><![CDATA[<p dir="auto">Before doing any reinstall check where is your mic with <strong>lsusb</strong></p>
<p dir="auto">Mine is a webcam so I got the following:<br />
Bus 001 Device 012: ID 046d:0826 Logitech, Inc. HD Webcam C525</p>
<p dir="auto">Then I confirmed it was seeing my mic with <strong>arecord -l</strong><br />
pi@raspberrypi:~/MagicMirror/config $ arecord -l<br />
**** List of CAPTURE Hardware Devices ****<br />
card 1: C525 [HD Webcam C525], device 0: USB Audio [USB Audio]<br />
Subdevices: 1/1<br />
Subdevice #0: subdevice #0</p>
<p dir="auto">So my device is plughw:1,0</p>
<p dir="auto">Try this to record 3 seconds and play it<br />
<strong>arecord -D plughw:1,0 -d 3 test.wav &amp;&amp; aplay test.wav</strong></p>
<p dir="auto">If sound is faint you can adjust the ‘gain’ by doing the following</p>
<p dir="auto">Open the Audio Device Settings :<br />
Open the Menu in the top left corner-&gt;Preferences -&gt; Audio Device Settings</p>
<p dir="auto">I also tried with a 9$ amazon mic but the sound and recording was really crappy.</p>
<p dir="auto">Good luck!</p>
]]></description><link>https://forum.magicmirror.builders/post/60390</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/60390</guid><dc:creator><![CDATA[smassy]]></dc:creator><pubDate>Sun, 25 Aug 2019 00:41:43 GMT</pubDate></item><item><title><![CDATA[Reply to I am givning up.. new install on Sun, 25 Aug 2019 00:19:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/otto" aria-label="Profile: otto">@<bdi>otto</bdi></a> rename the MagicMirror folder to something else.</p>
<p dir="auto">Install again, copy stuff from old folder as needed</p>
]]></description><link>https://forum.magicmirror.builders/post/60389</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/60389</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 25 Aug 2019 00:19:49 GMT</pubDate></item></channel></rss>
