<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Two questions regarding MMM-CalendarExt2]]></title><description><![CDATA[<p dir="auto">I’m sure the answer is in the documentation somewhere. Anyway, local community center wants to display upcoming Gym rental and free times. So the two things I need (which I can’t figure out) is to display the next 4 weeks showing days the way they appear in the month view, and how to include the ending time or the duration. Thanks in advance.</p>
 * MIT Licensed.
var config = {
	port: 8080,
	language: "en",
	timeFormat: 24,
	units: "metric",
			module: 'MMM-CalendarExt2',
				calendars : [
					name: "BNC Rentals",
					url: "https://calendar.google.com/calendar/ical/bncrentals185%40gmail.com/public/basic.ics",
				views: [
					title: "Gym Rentals",
					mode: "month",
					position: "fullscreen_above",
					calendars: ["BNC Rentals"],
					dateformat: "HH:mm",
					timeformat: "HH:mm",
				scenes: [
					views: [],
]]></description><link>https://forum.magicmirror.builders/topic/11048/two-questions-regarding-mmm-calendarext2</link><generator>RSS for Node</generator><lastBuildDate>Fri, 11 Sep 2026 05:01:07 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11048.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 27 Aug 2019 01:35:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Two questions regarding MMM-CalendarExt2 on Wed, 28 Aug 2019 02:52:33 GMT]]></title><description><![CDATA[<p dir="auto">@Sean  Thanks! I could suggest to staff to make duration part of the description. That will work.</p>
<p dir="auto">I can display ‘Gym Rentals’ on the left side of the calendar. Is there anyway to display the month of the current week on the right side?</p>
<p dir="auto"><a href="https://imgur.com/kcPfvub" target="_blank" rel="noopener noreferrer nofollow ugc">https://imgur.com/kcPfvub</a></p>
]]></description><link>https://forum.magicmirror.builders/post/60452</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/60452</guid><dc:creator><![CDATA[CliffordW]]></dc:creator><pubDate>Wed, 28 Aug 2019 02:52:33 GMT</pubDate></item><item><title><![CDATA[Reply to Two questions regarding MMM-CalendarExt2 on Tue, 27 Aug 2019 22:06:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cliffordw" aria-label="Profile: CliffordW">@<bdi>CliffordW</bdi></a></p>
<ol>
<li><code>mode:"week",</code></li>
<li>events of week/month views are too narrow to display end-time or duration. (informations themselves are hidden in event elements but not revealed. I don’t recommend show them.)</li>
</ol>
]]></description><link>https://forum.magicmirror.builders/post/60447</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/60447</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 27 Aug 2019 22:06:16 GMT</pubDate></item></channel></rss>
