<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Autoplay different module not working]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I m using different modules with mmm-pages…when i use Mmm-embedyoutube and mmm-iframereload only one video (one module) can be launching (not the same page)…is there a solution to have a delay to start a module or is there a delay to start video when i lauch mm?  Sorry for english and have a good day</p>
]]></description><link>https://forum.magicmirror.builders/topic/11055/autoplay-different-module-not-working</link><generator>RSS for Node</generator><lastBuildDate>Tue, 06 Oct 2026 02:39:37 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11055.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 28 Aug 2019 09:08:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Autoplay different module not working on Fri, 30 Aug 2019 19:21:35 GMT]]></title><description><![CDATA[<p dir="auto">pm2 logs</p>
<p dir="auto">Failed to create permanent mapping for memfd region with ID = 207878710<br />
0|mm       | Failed to regester memfd mempool. Reason: could not attach memfd SHM ID to pipe<br />
0|mm       | mmap() failed: Cannot allocate memory<br />
0|mm       | Failed to create permanent mapping for memfd region with ID = 1648210477<br />
0|mm       | Failed to create permanent mapping for memfd region with ID = 1088771516<br />
0|mm       | Ignoring received block reference with non-registered memfd ID = 1088771516<br />
0|mm       | Failed to create permanent mapping for memfd region with ID = 3067665855<br />
0|mm       | Failed to create permanent mapping for memfd region with ID = 3337011850<br />
0|mm       | Ignoring received block reference with non-registered memfd ID = 3337011850</p>
]]></description><link>https://forum.magicmirror.builders/post/60571</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/60571</guid><dc:creator><![CDATA[chassain 0]]></dc:creator><pubDate>Fri, 30 Aug 2019 19:21:35 GMT</pubDate></item><item><title><![CDATA[Reply to Autoplay different module not working on Fri, 30 Aug 2019 17:44:43 GMT]]></title><description><![CDATA[<p dir="auto">last news : sometimes it works after a “pm2 restart mm”</p>
<p dir="auto">have a good day</p>
]]></description><link>https://forum.magicmirror.builders/post/60570</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/60570</guid><dc:creator><![CDATA[chassain 0]]></dc:creator><pubDate>Fri, 30 Aug 2019 17:44:43 GMT</pubDate></item><item><title><![CDATA[Reply to Autoplay different module not working on Fri, 30 Aug 2019 17:27:49 GMT]]></title><description><![CDATA[<p dir="auto">you’re right !<br />
i’m going continue my research…thank a lot sdetweil</p>
]]></description><link>https://forum.magicmirror.builders/post/60569</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/60569</guid><dc:creator><![CDATA[chassain 0]]></dc:creator><pubDate>Fri, 30 Aug 2019 17:27:49 GMT</pubDate></item><item><title><![CDATA[Reply to Autoplay different module not working on Fri, 30 Aug 2019 17:26:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chassain-0" aria-label="Profile: chassain-0">@<bdi>chassain-0</bdi></a> pages just hides and shows modules, doesn’t mean a module is not active in the background…</p>
<p dir="auto">i don’t know how these modules work… but usually they have some startup that acquires resources. once acquired, they don’t let go</p>
]]></description><link>https://forum.magicmirror.builders/post/60568</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/60568</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 30 Aug 2019 17:26:19 GMT</pubDate></item><item><title><![CDATA[Reply to Autoplay different module not working on Fri, 30 Aug 2019 17:23:38 GMT]]></title><description><![CDATA[<p dir="auto">a another life…lol…no, a update and upgrade…not a rpi update…<br />
I don’t know if someone have differents modules for video . I’m using MMM-pages to scroll many modules and so 2 videos (not on the same page)</p>
]]></description><link>https://forum.magicmirror.builders/post/60567</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/60567</guid><dc:creator><![CDATA[chassain 0]]></dc:creator><pubDate>Fri, 30 Aug 2019 17:23:38 GMT</pubDate></item><item><title><![CDATA[Reply to Autoplay different module not working on Fri, 30 Aug 2019 17:19:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chassain-0" aria-label="Profile: chassain-0">@<bdi>chassain-0</bdi></a> said in <a href="/post/60565">Autoplay different module not working</a>:</p>
<p dir="auto">but it was ok before</p>
<p dir="auto">before when?</p>
]]></description><link>https://forum.magicmirror.builders/post/60566</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/60566</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 30 Aug 2019 17:19:41 GMT</pubDate></item><item><title><![CDATA[Reply to Autoplay different module not working on Fri, 30 Aug 2019 17:18:56 GMT]]></title><description><![CDATA[<p dir="auto">thank for your answer<br />
probably…but it was ok before…and it mention an error about audio but i have no video…</p>
]]></description><link>https://forum.magicmirror.builders/post/60565</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/60565</guid><dc:creator><![CDATA[chassain 0]]></dc:creator><pubDate>Fri, 30 Aug 2019 17:18:56 GMT</pubDate></item><item><title><![CDATA[Reply to Autoplay different module not working on Fri, 30 Aug 2019 17:14:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chassain-0" aria-label="Profile: chassain-0">@<bdi>chassain-0</bdi></a> the modules probably don’t support sharing the audio device.</p>
]]></description><link>https://forum.magicmirror.builders/post/60564</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/60564</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 30 Aug 2019 17:14:40 GMT</pubDate></item><item><title><![CDATA[Reply to Autoplay different module not working on Fri, 30 Aug 2019 17:12:38 GMT]]></title><description><![CDATA[<p dir="auto">Hello again,</p>
<p dir="auto">i can 't display two videos (with same module or two different modules like MMM-iFrameReload and MMM-SmartWebDisplay …i have always the error about audio render for one video from youtube…</p>
]]></description><link>https://forum.magicmirror.builders/post/60563</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/60563</guid><dc:creator><![CDATA[chassain 0]]></dc:creator><pubDate>Fri, 30 Aug 2019 17:12:38 GMT</pubDate></item><item><title><![CDATA[Reply to Autoplay different module not working on Wed, 28 Aug 2019 20:47:33 GMT]]></title><description><![CDATA[<p dir="auto">I have now (after new version mm) : audio render error !!!<br />
An idea !?</p>
]]></description><link>https://forum.magicmirror.builders/post/60473</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/60473</guid><dc:creator><![CDATA[chassain 0]]></dc:creator><pubDate>Wed, 28 Aug 2019 20:47:33 GMT</pubDate></item></channel></rss>
