<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[After adding MMM-CalendarExt to a class (MMM-ProfileSwitcher) it doesn&#x27;t show up on the mirror]]></title><description><![CDATA[<p dir="auto">Hi!</p>
<p dir="auto">It’s all in the title…</p>
<p dir="auto">Here’s my config:</p>
 * MIT Licensed.
var config = {
	port: 8080,
	language: "de",
	timeFormat: 24,
	units: "metric",
			module: "alert",
    			classes: "default everyone"
			module: "updatenotification",
			position: "top_bar",
			module: "clock",
			module: "newsfeed",
			position: "bottom_bar",
			classes: "default everyone",
				feeds: [
						title: "Neue Zürcher Zeitung",
						url: "https://www.nzz.ch/recent.rss"
				showSourceTitle: true,
				showPublishDate: true,
				broadcastNewsFeeds: true,
				broadcastNewsUpdates: true
      			module: "MMM-CalendarExt",
        		system: {
          				show: ["daily"],
          				locale: 'de',
          				redrawInterval:60000,
        			views: {
          				daily: {
            						position:'lower_third',
            						counts:7,
        			defaultCalendar: {
          						maxEntries:50,
          						maxDays:180,
          						interval: 1000*60*5,
        			calendars :[
            						url: "https://calendar.google.com/calendar/ical/123/basic.ics",
							profiles: ['Tom'],
            						url: "https://www.ferienwiki.ch/exports/ferien/2019/ch/basel-stadt",
							profiles: ['default'],
        		module: 'MMM-ProfileSwitcher',
		            module: "currentweather",
				classes: "default",
		              locationID: "6458763",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
		              appid: "1234"
	            module: "weatherforecast",
	            header: "Weather Forecast",
	              appid: "12345"
		   	module: 'MMM-GPIO-Notifications',
			        '17': {
			          gpio_state: 1,
			          gpio_debounce: 10,
			          notifications: [
					// see https://github.com/tosti007/MMM-ProfileSwitcher
					// Switching Profiles
					// this.sendNotification('CURRENT_PROFILE', 'DESIRED_PROFILE_NAME_HERE');
			              notification: 'CURRENT_PROFILE',
			              payload:  'Tom'
<p dir="auto">Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/topic/11183/after-adding-mmm-calendarext-to-a-class-mmm-profileswitcher-it-doesn-t-show-up-on-the-mirror</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Apr 2026 13:15:26 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11183.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 17 Sep 2019 16:30:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to After adding MMM-CalendarExt to a class (MMM-ProfileSwitcher) it doesn&#x27;t show up on the mirror on Tue, 17 Sep 2019 19:34:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tomxgames" aria-label="Profile: tomXGames">@<bdi>tomXGames</bdi></a> you can see the notifications happening in the developers console…</p>
<p dir="auto">ctrl-shift-i, then selec tthe tab labeled ‘console’… then scroll up to see in the past…</p>
<p dir="auto">u can also filter by module , by putting part of the module name in the filter field</p>
]]></description><link>https://forum.magicmirror.builders/post/61426</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61426</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 17 Sep 2019 19:34:52 GMT</pubDate></item><item><title><![CDATA[Reply to After adding MMM-CalendarExt to a class (MMM-ProfileSwitcher) it doesn&#x27;t show up on the mirror on Tue, 17 Sep 2019 19:01:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tomxgames" aria-label="Profile: tomXGames">@<bdi>tomXGames</bdi></a><br />
Inside of module, <code>notificationReceived(noti, payload, sender)</code> will be called when a notification arrives.</p>
]]></description><link>https://forum.magicmirror.builders/post/61425</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61425</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 17 Sep 2019 19:01:57 GMT</pubDate></item><item><title><![CDATA[Reply to After adding MMM-CalendarExt to a class (MMM-ProfileSwitcher) it doesn&#x27;t show up on the mirror on Tue, 17 Sep 2019 18:46:33 GMT]]></title><description><![CDATA[<p dir="auto">@Sean The ones sent with this.sendNotification()</p>
]]></description><link>https://forum.magicmirror.builders/post/61424</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61424</guid><dc:creator><![CDATA[tomXGames]]></dc:creator><pubDate>Tue, 17 Sep 2019 18:46:33 GMT</pubDate></item><item><title><![CDATA[Reply to After adding MMM-CalendarExt to a class (MMM-ProfileSwitcher) it doesn&#x27;t show up on the mirror on Tue, 17 Sep 2019 18:45:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tomxgames" aria-label="Profile: tomXGames">@<bdi>tomXGames</bdi></a><br />
What notification??? more detail, please.</p>
]]></description><link>https://forum.magicmirror.builders/post/61423</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61423</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 17 Sep 2019 18:45:14 GMT</pubDate></item><item><title><![CDATA[Reply to After adding MMM-CalendarExt to a class (MMM-ProfileSwitcher) it doesn&#x27;t show up on the mirror on Tue, 17 Sep 2019 18:44:16 GMT]]></title><description><![CDATA[<p dir="auto">@Sean I have another question… Where can I see the notifications?</p>
]]></description><link>https://forum.magicmirror.builders/post/61422</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61422</guid><dc:creator><![CDATA[tomXGames]]></dc:creator><pubDate>Tue, 17 Sep 2019 18:44:16 GMT</pubDate></item><item><title><![CDATA[Reply to After adding MMM-CalendarExt to a class (MMM-ProfileSwitcher) it doesn&#x27;t show up on the mirror on Tue, 17 Sep 2019 18:29:25 GMT]]></title><description><![CDATA[<p dir="auto">@Sean Ok, thanks anyways for the help!</p>
]]></description><link>https://forum.magicmirror.builders/post/61421</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61421</guid><dc:creator><![CDATA[tomXGames]]></dc:creator><pubDate>Tue, 17 Sep 2019 18:29:25 GMT</pubDate></item><item><title><![CDATA[Reply to After adding MMM-CalendarExt to a class (MMM-ProfileSwitcher) it doesn&#x27;t show up on the mirror on Tue, 17 Sep 2019 17:47:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tomxgames" aria-label="Profile: tomXGames">@<bdi>tomXGames</bdi></a><br />
Sorry those(Button and ProfileSwitcher) are not mine. You’d better ask the creator about it on their github issue board.</p>
]]></description><link>https://forum.magicmirror.builders/post/61418</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61418</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 17 Sep 2019 17:47:44 GMT</pubDate></item><item><title><![CDATA[Reply to After adding MMM-CalendarExt to a class (MMM-ProfileSwitcher) it doesn&#x27;t show up on the mirror on Tue, 17 Sep 2019 17:46:53 GMT]]></title><description><![CDATA[<p dir="auto">@Sean Thanks!</p>
<p dir="auto">I have another problem with MMM-Buttons… When I connect the two pins (pin 9 and pin 11 / Ground &amp;  GPIO 17) it doesn’t change the profile…<br />
Can you help out here? That would be great!</p>
 * MIT Licensed.
var config = {
	port: 8080,
	language: "de",
	timeFormat: 24,
	units: "metric",
			module: "alert",
			module: "clock",
			module: "newsfeed",
			classes: "default",
				feeds: [
        		system: {
          				show: ["daily"],
          				locale: 'de',
        			views: {
          				daily: {
            						counts:7,
        			defaultCalendar: {
          						maxEntries:50,
          						maxDays:180,
        			calendars :[
            						url: "https://calendar.google.com/calendar/ical/tommaso.peduzzi%40gmx.ch/private-088063fff967db8474e57b3a7cdf176a/basic.ics",
							profiles: ['Tom'],
				classes: "default",
		              appid: "4a58442ce61f6ae3de20fcfdecdb0327"
			        '17': {
			          gpio_state: 1,
			          gpio_debounce: 10,
			          notifications: [
			              payload:  'Tom'
			    module: 'MMM-Buttons',
			        buttons: [
			                pin: 17,
			                shortPress: {
			                    notification: "CURRENT_PROFILE",
			                    payload: "Tom"
]]></description><link>https://forum.magicmirror.builders/post/61417</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61417</guid><dc:creator><![CDATA[tomXGames]]></dc:creator><pubDate>Tue, 17 Sep 2019 17:46:53 GMT</pubDate></item><item><title><![CDATA[Reply to After adding MMM-CalendarExt to a class (MMM-ProfileSwitcher) it doesn&#x27;t show up on the mirror on Tue, 17 Sep 2019 17:20:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tomxgames" aria-label="Profile: tomXGames">@<bdi>tomXGames</bdi></a><br />
Go to MMM-CalendarExt directory then <code>git pull</code></p>
]]></description><link>https://forum.magicmirror.builders/post/61414</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61414</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 17 Sep 2019 17:20:29 GMT</pubDate></item><item><title><![CDATA[Reply to After adding MMM-CalendarExt to a class (MMM-ProfileSwitcher) it doesn&#x27;t show up on the mirror on Tue, 17 Sep 2019 17:19:10 GMT]]></title><description><![CDATA[<p dir="auto">@Sean Thanks! How can I update it?</p>
]]></description><link>https://forum.magicmirror.builders/post/61413</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61413</guid><dc:creator><![CDATA[tomXGames]]></dc:creator><pubDate>Tue, 17 Sep 2019 17:19:10 GMT</pubDate></item><item><title><![CDATA[Reply to After adding MMM-CalendarExt to a class (MMM-ProfileSwitcher) it doesn&#x27;t show up on the mirror on Tue, 17 Sep 2019 17:14:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tomxgames" aria-label="Profile: tomXGames">@<bdi>tomXGames</bdi></a><br />
Sorry, there was a bug hidden. So I patched it now.</p>
]]></description><link>https://forum.magicmirror.builders/post/61412</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61412</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 17 Sep 2019 17:14:51 GMT</pubDate></item></channel></rss>
