<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[USB IR touch screen frames on a Pi 4]]></title><description><![CDATA[<p dir="auto">Does anyone have experience using USB IR touch screen frames on a Pi 4?<br />
I’ve attached the one I’m looking at as a link.<br />
<a href="http://keetouch.eu/en/touchscreen/wkmi-0400" target="_blank" rel="noopener noreferrer nofollow ugc">http://keetouch.eu/en/touchscreen/wkmi-0400</a></p>
]]></description><link>https://forum.magicmirror.builders/topic/11186/usb-ir-touch-screen-frames-on-a-pi-4</link><generator>RSS for Node</generator><lastBuildDate>Thu, 13 Aug 2026 00:05:59 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11186.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 19 Sep 2019 07:31:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to USB IR touch screen frames on a Pi 4 on Mon, 23 Sep 2019 19:31:33 GMT]]></title><description><![CDATA[<p dir="auto">thanks for all your feed back</p>
]]></description><link>https://forum.magicmirror.builders/post/61584</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61584</guid><dc:creator><![CDATA[Rahmberg]]></dc:creator><pubDate>Mon, 23 Sep 2019 19:31:33 GMT</pubDate></item><item><title><![CDATA[Reply to USB IR touch screen frames on a Pi 4 on Sat, 21 Sep 2019 01:33:00 GMT]]></title><description><![CDATA[<p dir="auto">Since it doesn’t need a ‘driver’ to work it’s just plug and play … it’ll work.</p>
]]></description><link>https://forum.magicmirror.builders/post/61507</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61507</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Sat, 21 Sep 2019 01:33:00 GMT</pubDate></item><item><title><![CDATA[Reply to USB IR touch screen frames on a Pi 4 on Fri, 20 Sep 2019 16:22:42 GMT]]></title><description><![CDATA[<p dir="auto">Right now my biggest issue is that I have to run a command to rotate the touch frame…and once the monitor goes to sleep and comes back on, those settings are lost. So I may have to just use it in landscape mode</p>
]]></description><link>https://forum.magicmirror.builders/post/61488</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61488</guid><dc:creator><![CDATA[cyberphox]]></dc:creator><pubDate>Fri, 20 Sep 2019 16:22:42 GMT</pubDate></item><item><title><![CDATA[Reply to USB IR touch screen frames on a Pi 4 on Fri, 20 Sep 2019 10:14:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cyberphox" aria-label="Profile: cyberphox">@<bdi>cyberphox</bdi></a> Great then there should be no problem using it on a Pi 4.<br />
What obstacles and restrictions have you experienced?<br />
Can it use multiple touches or just single touches?</p>
]]></description><link>https://forum.magicmirror.builders/post/61477</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61477</guid><dc:creator><![CDATA[Rahmberg]]></dc:creator><pubDate>Fri, 20 Sep 2019 10:14:40 GMT</pubDate></item><item><title><![CDATA[Reply to USB IR touch screen frames on a Pi 4 on Fri, 20 Sep 2019 10:11:13 GMT]]></title><description><![CDATA[<p dir="auto">@Sean The frame will sit on top of the mirror which will be a 30/70 dielectric mirror is not a spyglass.<br />
I’m pretty sure that part will work, where my concerns are is software.<br />
Is it possible to control the mirror and make inputs with this product?</p>
]]></description><link>https://forum.magicmirror.builders/post/61476</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61476</guid><dc:creator><![CDATA[Rahmberg]]></dc:creator><pubDate>Fri, 20 Sep 2019 10:11:13 GMT</pubDate></item><item><title><![CDATA[Reply to USB IR touch screen frames on a Pi 4 on Thu, 19 Sep 2019 17:35:27 GMT]]></title><description><![CDATA[<p dir="auto">I have one working on a Pi 3b+</p>
]]></description><link>https://forum.magicmirror.builders/post/61467</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61467</guid><dc:creator><![CDATA[cyberphox]]></dc:creator><pubDate>Thu, 19 Sep 2019 17:35:27 GMT</pubDate></item><item><title><![CDATA[Reply to USB IR touch screen frames on a Pi 4 on Thu, 19 Sep 2019 09:34:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rahmberg" aria-label="Profile: Rahmberg">@<bdi>Rahmberg</bdi></a> Is it working under the spyglass? Or you put it on the spyglass?</p>
]]></description><link>https://forum.magicmirror.builders/post/61462</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61462</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Thu, 19 Sep 2019 09:34:12 GMT</pubDate></item></channel></rss>
