<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[V2.0.X Updates]]></title><description><![CDATA[<p dir="auto">I’ve just pushed V2.0.1 to stable.<br />
<a href="https://github.com/MichMich/MagicMirror/releases/tag/v2.0.1" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/releases/tag/v2.0.1</a></p>
<h2>[2.0.1] - 2016-05-18</h2>
<h3>Added</h3>
<ul>
<li>Changelog</li>
<li>Italian Translation</li>
</ul>
<h3>Changed</h3>
<ul>
<li>Improve the installer by fetching the latest Node.js without any 3rd party interferences.</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/topic/112/v2-0-x-updates</link><generator>RSS for Node</generator><lastBuildDate>Thu, 13 Aug 2026 00:38:53 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/112.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 18 May 2016 09:07:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to V2.0.X Updates on Tue, 20 Sep 2016 14:43:36 GMT]]></title><description><![CDATA[<p dir="auto">Wait no longer. The next update is here: v2.0.5<br />
<a href="https://github.com/MichMich/MagicMirror/releases/tag/v2.0.5" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/releases/tag/v2.0.5</a></p>
<h2>[2.0.5] - 2016-09-20</h2>
<h3>Added</h3>
<ul>
<li>Added ability to remove tags from the beginning or end of newsfeed items in ‘newsfeed.js’.</li>
<li>Added ability to define “the day after tomorrow” for calendar events (Definition for German and Dutch already included).</li>
<li>Added CII Badge (we are compliant with the CII Best Practices)</li>
<li>Add support for doing http basic auth when loading calendars</li>
<li>Add the abilty to turn off and on the date display in the Clock Module</li>
</ul>
<h3>Fixed</h3>
<ul>
<li>Fix typo in installer.</li>
<li>Add message to unsupported Pi error to mention that Pi Zeros must use server only mode, as ARMv6 is unsupported. Closes #374.</li>
<li>Fix API url for weather API.</li>
</ul>
<h3>Updated</h3>
<ul>
<li>Force fullscreen when kioskmode is active.</li>
<li>Update the .github templates and information with more modern information.</li>
<li>Update the Gruntfile with a more functional StyleLint implementation.</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/5086</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/5086</guid><dc:creator><![CDATA[MichMich]]></dc:creator><pubDate>Tue, 20 Sep 2016 14:43:36 GMT</pubDate></item><item><title><![CDATA[Reply to V2.0.X Updates on Sun, 07 Aug 2016 14:06:03 GMT]]></title><description><![CDATA[<p dir="auto">There it is, the next release: v2.0.4<br />
<a href="https://github.com/MichMich/MagicMirror/releases/tag/v2.0.4" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/releases/tag/v2.0.4</a></p>
<h2>[2.0.4] - 2016-08-07</h2>
<h3>Added</h3>
<ul>
<li>Brazilian Portuguese Translation.</li>
<li>Option to enable Kios mode.</li>
<li>Added ability to start the app with Dev Tools.</li>
<li>Added ability to turn off the date display in <code>clock.js</code> when in analog mode.</li>
<li>Greek Translation</li>
</ul>
<h3>Fixed</h3>
<ul>
<li>Prevent <code>getModules()</code> selectors from returning duplicate entries.</li>
<li>Append endpoints of weather modules with <code>/</code> to retreive the correct data. (Issue <a href="https://github.com/MichMich/MagicMirror/issues/337" target="_blank" rel="noopener noreferrer nofollow ugc">#337</a>)</li>
<li>Corrected grammer in <code>module.js</code> from ‘suspend’ to ‘suspended’.</li>
<li>Fixed <a href="http://openweathermap.org" target="_blank" rel="noopener noreferrer nofollow ugc">openweathermap.org</a> URL in config sample.</li>
<li>Prevent currentweather module from crashing when received data object is incorrect.</li>
<li>Fix issue where translation loading prevented the UI start-up when the language was set to ‘en’. (Issue <a href="https://github.com/MichMich/MagicMirror/issues/388" target="_blank" rel="noopener noreferrer nofollow ugc">#388</a>)</li>
</ul>
<h3>Updated</h3>
<ul>
<li>Updated package.json to fix possible vulnerabilities. (Using Snyk)</li>
<li>Updated weathericons</li>
<li>Updated default weatherforecast to work with the new icons.</li>
<li>More detailed error message in case config file couldn’t be loaded.</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/3472</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3472</guid><dc:creator><![CDATA[MichMich]]></dc:creator><pubDate>Sun, 07 Aug 2016 14:06:03 GMT</pubDate></item><item><title><![CDATA[Reply to V2.0.X Updates on Tue, 12 Jul 2016 14:03:08 GMT]]></title><description><![CDATA[<p dir="auto">A new version just rolled of the press … v2.0.3<br />
<a href="https://github.com/MichMich/MagicMirror/releases/tag/v2.0.3" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/releases/tag/v2.0.3</a></p>
<h2>[2.0.3] - 2016-07-12</h2>
<h3>Added</h3>
<ul>
<li>Add max newsitems parameter to the newsfeed module.</li>
<li>Translations for Simplified Chinese, Traditional Chinese and Japanese.</li>
<li>Polish Translation</li>
<li>Add an analog clock in addition to the digital one.</li>
</ul>
<h3>Fixed</h3>
<ul>
<li>Edit Alert Module to display title &amp; message if they are provided in the notification (Issue #300)</li>
<li>Removed ‘null’ reference from updateModuleContent(). This fixes recent Edge and Internet Explorer browser displays (Issue #319)</li>
</ul>
<h3>Changed</h3>
<ul>
<li>Added default string to calendar titleReplace.</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/2469</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2469</guid><dc:creator><![CDATA[MichMich]]></dc:creator><pubDate>Tue, 12 Jul 2016 14:03:08 GMT</pubDate></item><item><title><![CDATA[Reply to V2.0.X Updates on Sun, 05 Jun 2016 10:10:49 GMT]]></title><description><![CDATA[<p dir="auto">I’ve just pushed V2.0.2 to stable.<br />
<a href="https://github.com/MichMich/MagicMirror/releases/tag/v2.0.2" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/releases/tag/v2.0.2</a></p>
<h2>[2.0.2] - 2016-06-05</h2>
<h3>Added</h3>
<ul>
<li>Norwegian Translations (nb and nn)</li>
<li>Portuguese Translation</li>
<li>Swedish Translation</li>
</ul>
<h3>Fixed</h3>
<ul>
<li>Added reference to Italian Translation.</li>
<li>Added the missing NE translation to all languages. <a href="https://github.com/MichMich/MagicMirror/issues/344" target="_blank" rel="noopener noreferrer nofollow ugc">#334</a></li>
<li>Added proper User-Agent string to calendar call.</li>
</ul>
<h3>Changed</h3>
<ul>
<li>Add option to use locationID in weather modules.</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/1323</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1323</guid><dc:creator><![CDATA[MichMich]]></dc:creator><pubDate>Sun, 05 Jun 2016 10:10:49 GMT</pubDate></item></channel></rss>
