<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Magic Mirror wont start]]></title><description><![CDATA[<p dir="auto">I cant get Magic Mirror to start…I am a novice. Im running 2019-07-10<br />
Raspbian Buster with desktop and recommended software.  I am using this guide <a href="https://forum.magicmirror.builders/topic/236/complete-setup-tutorial/6">https://forum.magicmirror.builders/topic/236/complete-setup-tutorial/6</a><br />
Any help is greatly aprecciated!</p>
<p dir="auto">pi@raspberrypi:~/MagicMirror $ npm start</p>
<p dir="auto">magicmirror@2.8.0 start /home/pi/MagicMirror</p>
<p dir="auto">sh <a href="http://run-start.sh" target="_blank" rel="noopener noreferrer nofollow ugc">run-start.sh</a></p>
<p dir="auto">/home/pi/MagicMirror/node_modules/electron/index.js:14</p>
<p dir="auto">throw new Error(‘Electron failed to install correctly, please delete node_modules/electron and try installing again’)</p>
<p dir="auto">^</p>
<p dir="auto">Error: Electron failed to install correctly, please delete node_modules/electron and try installing again</p>
<p dir="auto">at getElectronPath (/home/pi/MagicMirror/node_modules/electron/index.js:14:11)</p>
<p dir="auto">at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:18:18)</p>
<p dir="auto">at Module._compile (internal/modules/cjs/loader.js:778:30)</p>
<p dir="auto">at Object.Module._extensions…js (internal/modules/cjs/loader.js:789:10)</p>
<p dir="auto">at Module.load (internal/modules/cjs/loader.js:653:32)</p>
<p dir="auto">at tryModuleLoad (internal/modules/cjs/loader.js:593:12)</p>
<p dir="auto">at Function.Module._load (internal/modules/cjs/loader.js:585:3)</p>
<p dir="auto">at Module.require (internal/modules/cjs/loader.js:692:17)</p>
<p dir="auto">at require (internal/modules/cjs/helpers.js:25:18)</p>
<p dir="auto">at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)</p>
<p dir="auto">npm ERR! code ELIFECYCLE</p>
<p dir="auto">npm ERR! errno 1</p>
<p dir="auto">npm ERR! magicmirror@2.8.0 start: <code>sh run-start.sh</code></p>
<p dir="auto">npm ERR! Exit status 1</p>
<p dir="auto">npm ERR!</p>
<p dir="auto">npm ERR! Failed at the magicmirror@2.8.0 start script.</p>
<p dir="auto">npm ERR! This is probably not a problem with npm. There is likely additional logging output above.</p>
<p dir="auto">npm ERR! A complete log of this run can be found in:</p>
<p dir="auto">npm ERR!     /home/pi/.npm/_logs/2019-09-24T01_02_05_382Z-debug.log</p>
<p dir="auto">r $ sudo npm start</p>
<p dir="auto">^</p>
<p dir="auto">npm ERR!     /root/.npm/_logs/2019-09-24T00_41_40_033Z-debug.log</p>
<p dir="auto">pi@raspberrypi:~/MagicMirror $ DISPLAY=:0 npm start</p>
<p dir="auto">^</p>
<p dir="auto">npm ERR!     /home/pi/.npm/_logs/2019-09-24T00_50_26_474Z-debug.log</p>
]]></description><link>https://forum.magicmirror.builders/topic/11210/magic-mirror-wont-start</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 12:30:51 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11210.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 24 Sep 2019 01:07:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Magic Mirror wont start on Tue, 24 Sep 2019 02:10:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/everybodyfloats" aria-label="Profile: everybodyfloats">@<bdi>everybodyfloats</bdi></a> try my updated installer.</p>
<p dir="auto">Rename the MagicMirror folder out of the way first</p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer">https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer</a></p>
]]></description><link>https://forum.magicmirror.builders/post/61589</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61589</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 24 Sep 2019 02:10:16 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror wont start on Wed, 25 Sep 2019 23:42:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/everybodyfloats" aria-label="Profile: everybodyfloats">@<bdi>everybodyfloats</bdi></a> cool… can u mark this issue closed (3 dots to the right of the message that solves if)</p>
]]></description><link>https://forum.magicmirror.builders/post/61713</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61713</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 25 Sep 2019 23:42:44 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror wont start on Wed, 25 Sep 2019 22:33:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  OMG it works!!! Thank you!!!</p>
]]></description><link>https://forum.magicmirror.builders/post/61712</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61712</guid><dc:creator><![CDATA[everybodyfloats]]></dc:creator><pubDate>Wed, 25 Sep 2019 22:33:01 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror wont start on Tue, 24 Sep 2019 02:10:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/everybodyfloats" aria-label="Profile: everybodyfloats">@<bdi>everybodyfloats</bdi></a> try my updated installer.</p>
]]></description><link>https://forum.magicmirror.builders/post/61589</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61589</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 24 Sep 2019 02:10:16 GMT</pubDate></item></channel></rss>
