<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MM won't run, blank screen with cursor showing after updating]]></title><description><![CDATA[<p dir="auto">When i went to go update, it said i had three files that were preventing it from updating, so i deleted them as i said, was package.json, package-lock.json, and vendor/package.json (I think). After updating, i try to run it and it gives a blank screen with the cursor showing and this is what shows in the terminal.</p>
<pre><code>pi@raspberrypi:~/MagicMirror $ npm start
&gt; magicmirror@2.8.0 start /home/pi/MagicMirror
&gt; sh run-start.sh
Starting MagicMirror: v2.8.0
Loading config ...
Loading module helpers ...
WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'rrule'
App threw an error during load
    at Module._resolveFilename (module.js:543:15)
    at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
    at Function.Module._load (module.js:473:25)
    at Module.require (module.js:586:17)
    at require (internal/module.js:11:18)
    at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/node-ical.js:27:13)
    at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/node-ical.js:68:3)
    at Module._compile (module.js:642:30)
    at Object.Module._extensions..js (module.js:653:10)
    at Module.load (module.js:561:32)
{ Error: Cannot find module 'rrule'
    at Module.load (module.js:561:32) code: 'MODULE_NOT_FOUND' }
Launching application.
<p dir="auto">It launched and worked fine beforehand, i was just updating because i was getting an error for some reason with MMM-Voice and thought maybe if i updated it would work.</p>
]]></description><link>https://forum.magicmirror.builders/topic/11244/mm-won-t-run-blank-screen-with-cursor-showing-after-updating</link><generator>RSS for Node</generator><lastBuildDate>Mon, 07 Sep 2026 15:06:11 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11244.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 29 Sep 2019 21:52:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MM won't run, blank screen with cursor showing after updating on Tue, 08 Oct 2019 02:17:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jmartin1009" aria-label="Profile: jmartin1009">@<bdi>jmartin1009</bdi></a> did u make any progress ?</p>
]]></description><link>https://forum.magicmirror.builders/post/62366</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62366</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 08 Oct 2019 02:17:38 GMT</pubDate></item><item><title><![CDATA[Reply to MM won't run, blank screen with cursor showing after updating on Mon, 30 Sep 2019 13:58:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jmartin1009" aria-label="Profile: jmartin1009">@<bdi>jmartin1009</bdi></a>  run this to see if all required libs loaded</p>
<p dir="auto">ldd /usr/local/bin/pocketsphinx_continuous</p>
]]></description><link>https://forum.magicmirror.builders/post/61917</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61917</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 30 Sep 2019 13:58:58 GMT</pubDate></item><item><title><![CDATA[Reply to MM won't run, blank screen with cursor showing after updating on Mon, 30 Sep 2019 02:18:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> same thing in the debug log, so hopefully i’ll get an answer on github, thanks for the help! If you discover anything else or have any other ideas i’ll give them a shot tomorrow, otherwise don’t sweat it. Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/61902</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61902</guid><dc:creator><![CDATA[jmartin1009]]></dc:creator><pubDate>Mon, 30 Sep 2019 02:18:43 GMT</pubDate></item><item><title><![CDATA[Reply to MM won't run, blank screen with cursor showing after updating on Mon, 30 Sep 2019 02:09:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> its installing pocketsphinx again so i wonder if it will change the file we changed with the paths and the plughw and stuff</p>
]]></description><link>https://forum.magicmirror.builders/post/61901</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61901</guid><dc:creator><![CDATA[jmartin1009]]></dc:creator><pubDate>Mon, 30 Sep 2019 02:09:48 GMT</pubDate></item><item><title><![CDATA[Reply to MM won't run, blank screen with cursor showing after updating on Mon, 30 Sep 2019 02:05:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jmartin1009" aria-label="Profile: jmartin1009">@<bdi>jmartin1009</bdi></a> shouldnt</p>
]]></description><link>https://forum.magicmirror.builders/post/61900</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61900</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 30 Sep 2019 02:05:06 GMT</pubDate></item><item><title><![CDATA[Reply to MM won't run, blank screen with cursor showing after updating on Mon, 30 Sep 2019 02:04:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> i thought i did, but i’ll do it again just to be safe, if that won’t mess up anything</p>
]]></description><link>https://forum.magicmirror.builders/post/61899</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61899</guid><dc:creator><![CDATA[jmartin1009]]></dc:creator><pubDate>Mon, 30 Sep 2019 02:04:51 GMT</pubDate></item><item><title><![CDATA[Reply to MM won't run, blank screen with cursor showing after updating on Mon, 30 Sep 2019 02:02:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jmartin1009" aria-label="Profile: jmartin1009">@<bdi>jmartin1009</bdi></a> just one more thing… after u installed MMM-voice, did u run the module/installers/dependencies.sh?</p>
<pre><code>Installation
Clone this repo into ~/MagicMirror/modules directory.
Run command bash dependencies.sh in ~/MagicMirror/modules/MMM-voice/installers directory, to install all dependencies. This will need a couple of minutes.
]]></description><link>https://forum.magicmirror.builders/post/61898</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61898</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 30 Sep 2019 02:02:42 GMT</pubDate></item><item><title><![CDATA[Reply to MM won't run, blank screen with cursor showing after updating on Mon, 30 Sep 2019 01:58:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> no worries! i wish i just could have found a voice control program that didn’t cause me to rip my hair out and give up and try another one by now haha i’ve tried a bunch and they always seem to fail for me.</p>
]]></description><link>https://forum.magicmirror.builders/post/61897</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61897</guid><dc:creator><![CDATA[jmartin1009]]></dc:creator><pubDate>Mon, 30 Sep 2019 01:58:20 GMT</pubDate></item><item><title><![CDATA[Reply to MM won't run, blank screen with cursor showing after updating on Mon, 30 Sep 2019 01:56:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jmartin1009" aria-label="Profile: jmartin1009">@<bdi>jmartin1009</bdi></a> glad I could help…  sorry we couldn’t push it over the line</p>
]]></description><link>https://forum.magicmirror.builders/post/61896</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61896</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 30 Sep 2019 01:56:55 GMT</pubDate></item><item><title><![CDATA[Reply to MM won't run, blank screen with cursor showing after updating on Mon, 30 Sep 2019 01:56:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> done, thank you for all of your help, I appreciate you taking time out of your day to troubleshoot this with me, you’ve helped me with a ton of stuff and i really appreciate it.</p>
]]></description><link>https://forum.magicmirror.builders/post/61895</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61895</guid><dc:creator><![CDATA[jmartin1009]]></dc:creator><pubDate>Mon, 30 Sep 2019 01:56:01 GMT</pubDate></item><item><title><![CDATA[Reply to MM won't run, blank screen with cursor showing after updating on Mon, 30 Sep 2019 01:47:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jmartin1009" aria-label="Profile: jmartin1009">@<bdi>jmartin1009</bdi></a> said in <a href="/post/61893">MM won't run, blank screen with cursor showing after updating</a>:</p>
<p dir="auto">tsphinx_continuous COMPILED ON: Sep 29 2019, AT: 15:24:41<br />
Error opening audio device plughw:1,0 for capture: Invalid argument<br />
FATAL: “continuous.c”, line 245: Failed to open audio device</p>
<p dir="auto">I don’t know…</p>
<p dir="auto">i would open  an  issue on the MMM-voice github repo, with the log file and ask for help .</p>
]]></description><link>https://forum.magicmirror.builders/post/61894</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61894</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 30 Sep 2019 01:47:39 GMT</pubDate></item><item><title><![CDATA[Reply to MM won't run, blank screen with cursor showing after updating on Mon, 30 Sep 2019 01:42:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> ```<br />
INFO: pocketsphinx.c(153): Parsed model-specific feature parameters from /usr/local/share/pocketsphinx/model/en-us/en-us/feat.params<br />
Current configuration:<br />
[NAME]			[DEFLT]		[VALUE]<br />
-agc			none		none<br />
-agcthresh		2.0		2.000000e+00<br />
-allphone				<br />
-allphone_ci		yes		yes<br />
-alpha			0.97		9.700000e-01<br />
-ascale			20.0		2.000000e+01<br />
-aw			1		1<br />
-backtrace		no		no<br />
-beam			1e-48		1.000000e-48<br />
-bestpath		yes		yes<br />
-bestpathlw		9.5		9.500000e+00<br />
-ceplen			13		13<br />
-cmn			live		batch<br />
-cmninit		40,3,-1		41.00,-5.29,-0.12,5.09,2.48,-4.07,-1.37,-1.78,-5.08,-2.05,-6.45,-1.42,1.17<br />
-compallsen		no		no<br />
-dict					/home/pi/MagicMirror/modules/MMM-voice/MMM-voice.dic<br />
-dictcase		no		no<br />
-dither			no		no<br />
-doublebw		no		no<br />
-ds			1		1<br />
-fdict					<br />
-feat			1s_c_d_dd	1s_c_d_dd<br />
-featparams				<br />
-fillprob		1e-8		1.000000e-08<br />
-frate			100		100<br />
-fsg					<br />
-fsgusealtpron		yes		yes<br />
-fsgusefiller		yes		yes<br />
-fwdflat		yes		yes<br />
-fwdflatbeam		1e-64		1.000000e-64<br />
-fwdflatefwid		4		4<br />
-fwdflatlw		8.5		8.500000e+00<br />
-fwdflatsfwin		25		25<br />
-fwdflatwbeam		7e-29		7.000000e-29<br />
-fwdtree		yes		yes<br />
-hmm					/usr/local/share/pocketsphinx/model/en-us/en-us<br />
-input_endian		little		little<br />
-jsgf					<br />
-keyphrase				<br />
-kws					<br />
-kws_delay		10		10<br />
-kws_plp		1e-1		1.000000e-01<br />
-kws_threshold		1e-30		1.000000e-30<br />
-latsize		5000		5000<br />
-lda					<br />
-ldadim			0		0<br />
-lifter			0		22<br />
-lm					/home/pi/MagicMirror/modules/MMM-voice/MMM-voice.lm<br />
-lmctl					<br />
-lmname					<br />
-logbase		1.0001		1.000100e+00<br />
-logfn					<br />
-logspec		no		no<br />
-lowerf			133.33334	1.300000e+02<br />
-lpbeam			1e-40		1.000000e-40<br />
-lponlybeam		7e-29		7.000000e-29<br />
-lw			6.5		6.500000e+00<br />
-maxhmmpf		30000		30000<br />
-maxwpf			-1		-1<br />
-mdef					<br />
-mean					<br />
-mfclogdir				<br />
-min_endfr		0		0<br />
-mixw					<br />
-mixwfloor		0.0000001	1.000000e-07<br />
-mllr					<br />
-mmap			yes		yes<br />
-ncep			13		13<br />
-nfft			512		512<br />
-nfilt			40		25<br />
-nwpen			1.0		1.000000e+00<br />
-pbeam			1e-48		1.000000e-48<br />
-pip			1.0		1.000000e+00<br />
-pl_beam		1e-10		1.000000e-10<br />
-pl_pbeam		1e-10		1.000000e-10<br />
-pl_pip			1.0		1.000000e+00<br />
-pl_weight		3.0		3.000000e+00<br />
-pl_window		5		5<br />
-rawlogdir				<br />
-remove_dc		no		no<br />
-remove_noise		yes		yes<br />
-remove_silence		yes		yes<br />
-round_filters		yes		yes<br />
-samprate		16000		1.600000e+04<br />
-seed			-1		-1<br />
-sendump				<br />
-senlogdir				<br />
-senmgau				<br />
-silprob		0.005		5.000000e-03<br />
-smoothspec		no		no<br />
-svspec					0-12/13-25/26-38<br />
-tmat					<br />
-tmatfloor		0.0001		1.000000e-04<br />
-topn			4		4<br />
-topn_beam		0		0<br />
-toprule				<br />
-transform		legacy		dct<br />
-unit_area		yes		yes<br />
-upperf			6855.4976	6.800000e+03<br />
-uw			1.0		1.000000e+00<br />
-vad_postspeech		50		50<br />
-vad_prespeech		20		20<br />
-vad_startspeech	10		10<br />
-vad_threshold		3.0		3.000000e+00<br />
-var					<br />
-varfloor		0.0001		1.000000e-04<br />
-varnorm		no		no<br />
-verbose		no		no<br />
-warp_params				<br />
-warp_type		inverse_linear	inverse_linear<br />
-wbeam			7e-29		7.000000e-29<br />
-wip			0.65		6.500000e-01<br />
-wlen			0.025625	2.562500e-02</p>
<p dir="auto">INFO: feat.c(715): Initializing feature stream to type: ‘1s_c_d_dd’, ceplen=13, CMN=‘batch’, VARNORM=‘no’, AGC=‘none’<br />
INFO: acmod.c(162): Using subvector specification 0-12/13-25/26-38<br />
INFO: mdef.c(518): Reading model definition: /usr/local/share/pocketsphinx/model/en-us/en-us/mdef<br />
INFO: mdef.c(531): Found byte-order mark BMDF, assuming this is a binary mdef file<br />
INFO: bin_mdef.c(336): Reading binary model definition: /usr/local/share/pocketsphinx/model/en-us/en-us/mdef<br />
INFO: bin_mdef.c(516): 42 CI-phone, 137053 CD-phone, 3 emitstate/phone, 126 CI-sen, 5126 Sen, 29324 Sen-Seq<br />
INFO: tmat.c(149): Reading HMM transition probability matrices: /usr/local/share/pocketsphinx/model/en-us/en-us/transition_matrices<br />
INFO: acmod.c(113): Attempting to use PTM computation module<br />
INFO: ms_gauden.c(127): Reading mixture gaussian parameter: /usr/local/share/pocketsphinx/model/en-us/en-us/means<br />
INFO: ms_gauden.c(242): 42 codebook, 3 feature, size:<br />
INFO: ms_gauden.c(244):  128x13<br />
INFO: ms_gauden.c(127): Reading mixture gaussian parameter: /usr/local/share/pocketsphinx/model/en-us/en-us/variances<br />
INFO: ms_gauden.c(304): 222 variance values floored<br />
INFO: ptm_mgau.c(475): Loading senones from dump file /usr/local/share/pocketsphinx/model/en-us/en-us/sendump<br />
INFO: ptm_mgau.c(499): BEGIN FILE FORMAT DESCRIPTION<br />
INFO: ptm_mgau.c(562): Rows: 128, Columns: 5126<br />
INFO: ptm_mgau.c(594): Using memory-mapped I/O for senones<br />
INFO: ptm_mgau.c(837): Maximum top-N: 4<br />
INFO: phone_loop_search.c(114): State beam -225 Phone exit beam -225 Insertion penalty 0<br />
INFO: dict.c(320): Allocating 4130 * 20 bytes (80 KiB) for word entries<br />
INFO: dict.c(333): Reading main dictionary: /home/pi/MagicMirror/modules/MMM-voice/MMM-voice.dic<br />
INFO: dict.c(213): Dictionary size 29, allocated 0 KiB for strings, 0 KiB for phones<br />
INFO: dict.c(336): 29 words read<br />
INFO: dict.c(358): Reading filler dictionary: /usr/local/share/pocketsphinx/model/en-us/en-us/noisedict<br />
INFO: dict.c(213): Dictionary size 34, allocated 0 KiB for strings, 0 KiB for phones<br />
INFO: dict.c(361): 5 words read<br />
INFO: dict2pid.c(396): Building PID tables for dictionary<br />
INFO: dict2pid.c(406): Allocating 42^3 * 2 bytes (144 KiB) for word-initial triphones<br />
INFO: dict2pid.c(132): Allocated 21336 bytes (20 KiB) for word-final triphones<br />
INFO: dict2pid.c(196): Allocated 21336 bytes (20 KiB) for single-phone word triphones<br />
INFO: ngram_model_trie.c(354): Trying to read LM in trie binary format<br />
INFO: ngram_model_trie.c(365): Header doesn’t match<br />
INFO: ngram_model_trie.c(177): Trying to read LM in arpa format<br />
INFO: ngram_model_trie.c(193): LM of order 3<br />
INFO: ngram_model_trie.c(195): #1-grams: 25<br />
INFO: ngram_model_trie.c(195): #2-grams: 46<br />
INFO: ngram_model_trie.c(195): #3-grams: 23<br />
INFO: lm_trie.c(474): Training quantizer<br />
INFO: lm_trie.c(482): Building LM trie<br />
INFO: ngram_search_fwdtree.c(74): Initializing search tree<br />
INFO: ngram_search_fwdtree.c(101): 28 unique initial diphones<br />
INFO: ngram_search_fwdtree.c(186): Creating search channels<br />
INFO: ngram_search_fwdtree.c(323): Max nonroot chan increased to 157<br />
INFO: ngram_search_fwdtree.c(333): Created 28 root, 29 non-root channels, 5 single-phone words<br />
INFO: ngram_search_fwdflat.c(157): fwdflat: min_ef_width = 4, max_sf_win = 25<br />
INFO: continuous.c(307): pocketsphinx_continuous COMPILED ON: Sep 29 2019, AT: 15:24:41</p>
<p dir="auto">Error opening audio device plughw:1,0 for capture: Invalid argument<br />
<pre><code></code></pre>
]]></description><link>https://forum.magicmirror.builders/post/61893</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61893</guid><dc:creator><![CDATA[jmartin1009]]></dc:creator><pubDate>Mon, 30 Sep 2019 01:42:32 GMT</pubDate></item><item><title><![CDATA[Reply to MM won't run, blank screen with cursor showing after updating on Mon, 30 Sep 2019 01:34:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jmartin1009" aria-label="Profile: jmartin1009">@<bdi>jmartin1009</bdi></a> yeh, only care about the debug log</p>
]]></description><link>https://forum.magicmirror.builders/post/61892</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61892</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 30 Sep 2019 01:34:22 GMT</pubDate></item><item><title><![CDATA[Reply to MM won't run, blank screen with cursor showing after updating on Mon, 30 Sep 2019 01:33:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> just changed those file paths, tried running MM, still getting “ERROR undefined” next to the little microphone</p>
]]></description><link>https://forum.magicmirror.builders/post/61891</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61891</guid><dc:creator><![CDATA[jmartin1009]]></dc:creator><pubDate>Mon, 30 Sep 2019 01:33:38 GMT</pubDate></item><item><title><![CDATA[Reply to MM won't run, blank screen with cursor showing after updating on Mon, 30 Sep 2019 01:30:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> oh yeah, im going to change the file paths in it right now in the one you sent last.</p>
]]></description><link>https://forum.magicmirror.builders/post/61890</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61890</guid><dc:creator><![CDATA[jmartin1009]]></dc:creator><pubDate>Mon, 30 Sep 2019 01:30:03 GMT</pubDate></item><item><title><![CDATA[Reply to MM won't run, blank screen with cursor showing after updating on Mon, 30 Sep 2019 01:30:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jmartin1009" aria-label="Profile: jmartin1009">@<bdi>jmartin1009</bdi></a></p>
<p dir="auto">~/MagicMirror/modules/MMM-voice/node_modules/pocketsphinx_continuous/index.js</p>
<p dir="auto">same file u just showed me</p>
]]></description><link>https://forum.magicmirror.builders/post/61889</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61889</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 30 Sep 2019 01:30:13 GMT</pubDate></item><item><title><![CDATA[Reply to MM won't run, blank screen with cursor showing after updating on Mon, 30 Sep 2019 01:27:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> which file? and i’ll go change those right now</p>
]]></description><link>https://forum.magicmirror.builders/post/61888</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61888</guid><dc:creator><![CDATA[jmartin1009]]></dc:creator><pubDate>Mon, 30 Sep 2019 01:27:55 GMT</pubDate></item><item><title><![CDATA[Reply to MM won't run, blank screen with cursor showing after updating on Mon, 30 Sep 2019 01:20:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jmartin1009" aria-label="Profile: jmartin1009">@<bdi>jmartin1009</bdi></a> you have the file with my fixes in it… btw</p>
]]></description><link>https://forum.magicmirror.builders/post/61887</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61887</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 30 Sep 2019 01:20:05 GMT</pubDate></item><item><title><![CDATA[Reply to MM won't run, blank screen with cursor showing after updating on Mon, 30 Sep 2019 01:19:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jmartin1009" aria-label="Profile: jmartin1009">@<bdi>jmartin1009</bdi></a> said in <a href="/post/61885">MM won't run, blank screen with cursor showing after updating</a>:<br />
from your response</p>
<pre><code>&gt; this._psc = spawn('pocketsphinx_continuous', [
&gt;       '-adcdev',
&gt;       mic,
&gt;       '-inmic',
&gt;       'yes',
&gt;       '-lm',
&gt;       `modules/${this.setId}/${this.setId}.lm`,
&gt;       '-dict',
&gt;       `modules/${this.setId}/${this.setId}.dic`
&gt;     ]);
&gt;
<p dir="auto">so, only the path to the files can be wrong…</p>
<p dir="auto">so, change them to (assume u are running as user pi)</p>
<pre><code> this._psc = spawn('pocketsphinx_continuous', [
       '-adcdev',
       mic,
       '-inmic',
       'yes',
       '-lm',
       `/home/pi/MagicMirror/modules/${this.setId}/${this.setId}.lm`,
       '-dict',
       `/home/pi/MagicMirror/modules/${this.setId}/${this.setId}.dic`
]]></description><link>https://forum.magicmirror.builders/post/61886</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61886</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 30 Sep 2019 01:19:15 GMT</pubDate></item><item><title><![CDATA[Reply to MM won't run, blank screen with cursor showing after updating on Mon, 30 Sep 2019 01:14:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> this is the entire index file, didn’t see that anywhere</p>
<pre><code>const spawn = require('child_process').spawn;
const EventEmitter = require('events').EventEmitter;
const util = require('util');
const reservedEvents = {
  close: true,
  error: true,
  data: true,
  end: true,
  readable: true,
  drain: true,
  finish: true,
  pipe: true,
  unpipe: true
function PocketSphinxContinuous(config) {
  this.setId = config.setId;
  this.verbose = config.verbose;
  this.microphone = config.microphone;
  this.autostart = config.autostart;
  if (!config.hasOwnProperty('autostart') || config.autostart === true) {
    this.start();
  EventEmitter.call(this);
PocketSphinxContinuous.prototype.start = function() {
  if (!this.isListening()) {
    let mic = this.microphone;
    // if name starts with number
    if (typeof this.microphone === 'number' || this.microphone.match(/^\d/)) {
      mic = `plughw:${this.microphone}`;
      '-adcdev',
      mic,
      '-inmic',
      'yes',
      '-lm',
      '-dict',
    this._psc.stdout.on('data', data =&gt; {
      const output = data.toString().trim();
      if (output) {
        this.emit('data', output);
      // Also try to emit an event for the actual data, unless of course the
      // event is a reserved one.
      const eventName = output.toLowerCase();
      if (!reservedEvents[eventName]) {
        this.emit(eventName, output);
    this._psc.stderr.on('data', data =&gt; {
      if (this.verbose &amp;&amp; output) {
        this.emit('debug', data);
    this._psc.on('close', code =&gt; {
      this.emit('error', code);
    this._psc.on('error', err =&gt; {
      this.emit('error', err);
PocketSphinxContinuous.prototype.stop = function() {
  if (this.isListening()) {
    this._psc.kill();
PocketSphinxContinuous.prototype.isListening = function() {
  return this._psc &amp;&amp; !this._psc.killed;
util.inherits(PocketSphinxContinuous, EventEmitter);
module.exports = PocketSphinxContinuous;
<p dir="auto">also, both of those files are there.</p>
]]></description><link>https://forum.magicmirror.builders/post/61885</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61885</guid><dc:creator><![CDATA[jmartin1009]]></dc:creator><pubDate>Mon, 30 Sep 2019 01:14:50 GMT</pubDate></item><item><title><![CDATA[Reply to MM won't run, blank screen with cursor showing after updating on Mon, 30 Sep 2019 01:08:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> also, in the node_modules/pocketsphinx_continuous/index.js</p>
<p dir="auto">show me this</p>
<pre><code> var pc = spawn('pocketsphinx_continuous', [
    '-adcdev',
    'plughw:' + this.microphone,
    '-inmic',
    'yes',
    '-lm',
    'modules/MMM-voice/' + this.setId + '.lm',
    '-dict',
    'modules/MMM-voice/' + this.setId + '.dic'
<p dir="auto">also check for the two files in the mmm-voice folder MMM-voice.lm and MMM-voice.dic</p>
]]></description><link>https://forum.magicmirror.builders/post/61884</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61884</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 30 Sep 2019 01:08:39 GMT</pubDate></item><item><title><![CDATA[Reply to MM won't run, blank screen with cursor showing after updating on Mon, 30 Sep 2019 01:05:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<pre><code>ERROR: "cmd_ln.c", line 682: No arguments given, available options are:
Arguments list definition:
[NAME]			[DEFLT]		[DESCR]
-adcdev					Name of audio device to use for input.
-agc			none		Automatic gain control for c0 ('max', 'emax', 'noise', or 'none')
-agcthresh		2.0		Initial threshold for automatic gain control
-allphone				Perform phoneme decoding with phonetic lm
-allphone_ci		yes		Perform phoneme decoding with phonetic lm and context-independent units only
-alpha			0.97		Preemphasis parameter
-argfile				Argument file giving extra arguments.
-ascale			20.0		Inverse of acoustic model scale for confidence score calculation
-aw			1		Inverse weight applied to acoustic scores.
-backtrace		no		Print results and backtraces to log.
-beam			1e-48		Beam width applied to every frame in Viterbi search (smaller values mean wider beam)
-bestpath		yes		Run bestpath (Dijkstra) search over word lattice (3rd pass)
-bestpathlw		9.5		Language model probability weight for bestpath search
-ceplen			13		Number of components in the input feature vector
-cmn			live		Cepstral mean normalization scheme ('live', 'batch', or 'none')
-cmninit		40,3,-1		Initial values (comma-separated) for cepstral mean when 'live' is used
-compallsen		no		Compute all senone scores in every frame (can be faster when there are many senones)
-dict					Main pronunciation dictionary (lexicon) input file
-dictcase		no		Dictionary is case sensitive (NOTE: case insensitivity applies to ASCII characters only)
-dither			no		Add 1/2-bit noise
-doublebw		no		Use double bandwidth filters (same center freq)
-ds			1		Frame GMM computation downsampling ratio
-fdict					Noise word pronunciation dictionary input file
-feat			1s_c_d_dd	Feature stream type, depends on the acoustic model
-featparams				File containing feature extraction parameters.
-fillprob		1e-8		Filler word transition probability
-frate			100		Frame rate
-fsg					Sphinx format finite state grammar file
-fsgusealtpron		yes		Add alternate pronunciations to FSG
-fsgusefiller		yes		Insert filler words at each state.
-fwdflat		yes		Run forward flat-lexicon search over word lattice (2nd pass)
-fwdflatbeam		1e-64		Beam width applied to every frame in second-pass flat search
-fwdflatefwid		4		Minimum number of end frames for a word to be searched in fwdflat search
-fwdflatlw		8.5		Language model probability weight for flat lexicon (2nd pass) decoding
-fwdflatsfwin		25		Window of frames in lattice to search for successor words in fwdflat search
-fwdflatwbeam		7e-29		Beam width applied to word exits in second-pass flat search
-fwdtree		yes		Run forward lexicon-tree search (1st pass)
-hmm					Directory containing acoustic model files.
-infile					Audio file to transcribe.
-inmic			no		Transcribe audio from microphone.
-input_endian		little		Endianness of input data, big or little, ignored if NIST or MS Wav
-jsgf					JSGF grammar file
-keyphrase				Keyphrase to spot
-kws					A file with keyphrases to spot, one per line
-kws_delay		10		Delay to wait for best detection score
-kws_plp		1e-1		Phone loop probability for keyphrase spotting
-kws_threshold		1e-30		Threshold for p(hyp)/p(alternatives) ratio
-latsize		5000		Initial backpointer table size
-lda					File containing transformation matrix to be applied to features (single-stream features only)
-ldadim			0		Dimensionality of output of feature transformation (0 to use entire matrix)
-lifter			0		Length of sin-curve for liftering, or 0 for no liftering.
-lm					Word trigram language model input file
-lmctl					Specify a set of language model
-lmname					Which language model in -lmctl to use by default
-logbase		1.0001		Base in which all log-likelihoods calculated
-logfn					File to write log messages in
-logspec		no		Write out logspectral files instead of cepstra
-lowerf			133.33334	Lower edge of filters
-lpbeam			1e-40		Beam width applied to last phone in words
-lponlybeam		7e-29		Beam width applied to last phone in single-phone words
-lw			6.5		Language model probability weight
-maxhmmpf		30000		Maximum number of active HMMs to maintain at each frame (or -1 for no pruning)
-maxwpf			-1		Maximum number of distinct word exits at each frame (or -1 for no pruning)
-mdef					Model definition input file
-mean					Mixture gaussian means input file
-mfclogdir				Directory to log feature files to
-min_endfr		0		Nodes ignored in lattice construction if they persist for fewer than N frames
-mixw					Senone mixture weights input file (uncompressed)
-mixwfloor		0.0000001	Senone mixture weights floor (applied to data from -mixw file)
-mllr					MLLR transformation to apply to means and variances
-mmap			yes		Use memory-mapped I/O (if possible) for model files
-ncep			13		Number of cep coefficients
-nfft			512		Size of FFT
-nfilt			40		Number of filter banks
-nwpen			1.0		New word transition penalty
-pbeam			1e-48		Beam width applied to phone transitions
-pip			1.0		Phone insertion penalty
-pl_beam		1e-10		Beam width applied to phone loop search for lookahead
-pl_pbeam		1e-10		Beam width applied to phone loop transitions for lookahead
-pl_pip			1.0		Phone insertion penalty for phone loop
-pl_weight		3.0		Weight for phoneme lookahead penalties
-pl_window		5		Phoneme lookahead window size, in frames
-rawlogdir				Directory to log raw audio files to
-remove_dc		no		Remove DC offset from each frame
-remove_noise		yes		Remove noise with spectral subtraction in mel-energies
-remove_silence		yes		Enables VAD, removes silence frames from processing
-round_filters		yes		Round mel filter frequencies to DFT points
-samprate		16000		Sampling rate
-seed			-1		Seed for random number generator; if less than zero, pick our own
-sendump				Senone dump (compressed mixture weights) input file
-senlogdir				Directory to log senone score files to
-senmgau				Senone to codebook mapping input file (usually not needed)
-silprob		0.005		Silence word transition probability
-smoothspec		no		Write out cepstral-smoothed logspectral files
-svspec					Subvector specification (e.g., 24,0-11/25,12-23/26-38 or 0-12/13-25/26-38)
-time			no		Print word times in file transcription.
-tmat					HMM state transition matrix input file
-tmatfloor		0.0001		HMM state transition probability floor (applied to -tmat file)
-topn			4		Maximum number of top Gaussians to use in scoring.
-topn_beam		0		Beam width used to determine top-N Gaussians (or a list, per-feature)
-toprule				Start rule for JSGF (first public rule is default)
-transform		legacy		Which type of transform to use to calculate cepstra (legacy, dct, or htk)
-unit_area		yes		Normalize mel filters to unit area
-upperf			6855.4976	Upper edge of filters
-uw			1.0		Unigram weight
-vad_postspeech		50		Num of silence frames to keep after from speech to silence.
-vad_prespeech		20		Num of speech frames to keep before silence to speech.
-vad_startspeech	10		Num of speech frames to trigger vad from silence to speech.
-vad_threshold		3.0		Threshold for decision between noise and silence frames. Log-ratio between signal level and noise level.
-var					Mixture gaussian variances input file
-varfloor		0.0001		Mixture gaussian variance floor (applied to data from -var file)
-varnorm		no		Variance normalize each utterance (only if CMN == current)
-verbose		no		Show input filenames
-warp_params				Parameters defining the warping function
-warp_type		inverse_linear	Warping function type (or shape)
-wbeam			7e-29		Beam width applied to word exits
-wip			0.65		Word insertion penalty
-wlen			0.025625	Hamming window length
INFO: continuous.c(295): Specify '-infile &lt;file.wav&gt;' to recognize from file or '-inmic yes' to recognize from microphone.
]]></description><link>https://forum.magicmirror.builders/post/61883</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61883</guid><dc:creator><![CDATA[jmartin1009]]></dc:creator><pubDate>Mon, 30 Sep 2019 01:05:28 GMT</pubDate></item><item><title><![CDATA[Reply to MM won't run, blank screen with cursor showing after updating on Mon, 30 Sep 2019 01:03:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jmartin1009" aria-label="Profile: jmartin1009">@<bdi>jmartin1009</bdi></a> if you give it NO parms, it dumps them out…</p>
<p dir="auto">SO, pocketsphinx_continuous 2&gt;somefile</p>
<p dir="auto">to get the list of possible parms</p>
]]></description><link>https://forum.magicmirror.builders/post/61882</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61882</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 30 Sep 2019 01:03:28 GMT</pubDate></item><item><title><![CDATA[Reply to MM won't run, blank screen with cursor showing after updating on Mon, 30 Sep 2019 00:59:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> as a programmer in college right now, i relate lmao any leads or ideas about it?</p>
]]></description><link>https://forum.magicmirror.builders/post/61881</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61881</guid><dc:creator><![CDATA[jmartin1009]]></dc:creator><pubDate>Mon, 30 Sep 2019 00:59:36 GMT</pubDate></item></channel></rss>
