<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[V2.9.0]]></title><description><![CDATA[<p dir="auto"><a href="https://github.com/MichMich/MagicMirror/releases/tag/v2.9.0" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/releases/tag/v2.9.0</a></p>
<p dir="auto">:heart_suit:  <strong>Donate:</strong> Enjoying MagicMirror²? <a href="https://magicmirror.builders/donate" target="_blank" rel="noopener noreferrer nofollow ugc">Please consider a donation!</a> With your help we can continue to improve the MagicMirror² core.</p>
<h2>[2.9.0] - 2019-10-01</h2>
<p dir="auto">:information:  <strong>Note:</strong> This update uses new dependencies. Please update using the following command: <code>git pull &amp;&amp; npm install</code>. If you are having issues running Electron, make sure your <a href="https://www.raspberrypi.org/documentation/raspbian/updating.md" target="_blank" rel="noopener noreferrer nofollow ugc">Raspbian is up to date</a>.</p>
<h3>Added</h3>
<ul>
<li>Spanish translation for “PRECIP”.</li>
<li>Adding a Malay (Malaysian) translation for MagicMirror².</li>
<li>Add test check URLs of vendors 200 and 404 HTTP CODE.</li>
<li>Add tests for new weather module and helper to stub ajax requests.</li>
</ul>
<h3>Updated</h3>
<ul>
<li>Updatenotification module: Display update notification for a limited (configurable) time.</li>
<li>Enabled e2e/vendor_spec.js tests.</li>
<li>The css/custom.css will be rename after the next release. We’ve add into <code>run-start.sh</code> a instruction by GIT to ignore with <code>--skip-worktree</code> and <code>rm --cached</code>. <a href="https://github.com/MichMich/MagicMirror/issues/1540" target="_blank" rel="noopener noreferrer nofollow ugc">#1540</a></li>
<li>Disable sending of notification CLOCK_SECOND when displaySeconds is false.</li>
</ul>
<h3>Fixed</h3>
<ul>
<li>Updatenotification module: Properly handle race conditions, prevent crash.</li>
<li>Send <code>NEWS_FEED</code> notification also for the first news messages which are shown.</li>
<li>Fixed issue where weather module would not refresh data after a network or API outage. <a href="https://github.com/MichMich/MagicMirror/issues/1722" target="_blank" rel="noopener noreferrer nofollow ugc">#1722</a></li>
<li>Fixed weatherforecast module not displaying rain amount on fallback endpoint.</li>
<li>Notifications CLOCK_SECOND &amp; CLOCK_MINUTE being from startup instead of matched against the clock and avoid drifting.</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/topic/11258/v2-9-0</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 04:07:28 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11258.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 01 Oct 2019 17:50:05 GMT</pubDate><ttl>60</ttl></channel></rss>
