<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Problem when installing MagicMirror on Raspbian Buster RPB3+]]></title><description><![CDATA[<p dir="auto">Hey guys,</p>
<p dir="auto">I have an error when I try to install magic mirror on raspbian buster (fresh install) and with raspberry pi 3b+.</p>
<p dir="auto"><a href="https://ibb.co/Y8HVwVG" target="_blank" rel="noopener noreferrer nofollow ugc">https://ibb.co/Y8HVwVG</a></p>
<p dir="auto">Do you have any ideas ?</p>
<p dir="auto">Thank you !</p>
<p dir="auto">Have a good day !</p>
]]></description><link>https://forum.magicmirror.builders/topic/11260/problem-when-installing-magicmirror-on-raspbian-buster-rpb3</link><generator>RSS for Node</generator><lastBuildDate>Fri, 04 Sep 2026 17:39:24 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11260.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 01 Oct 2019 18:32:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Problem when installing MagicMirror on Raspbian Buster RPB3+ on Sun, 13 Oct 2019 15:45:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> thank you for your hard work</p>
]]></description><link>https://forum.magicmirror.builders/post/62606</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62606</guid><dc:creator><![CDATA[bobwilliams]]></dc:creator><pubDate>Sun, 13 Oct 2019 15:45:09 GMT</pubDate></item><item><title><![CDATA[Reply to Problem when installing MagicMirror on Raspbian Buster RPB3+ on Sun, 13 Oct 2019 15:43:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bobwilliams" aria-label="Profile: bobwilliams">@<bdi>bobwilliams</bdi></a> yes, install is good… update still has a problem…</p>
]]></description><link>https://forum.magicmirror.builders/post/62605</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62605</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 13 Oct 2019 15:43:57 GMT</pubDate></item><item><title><![CDATA[Reply to Problem when installing MagicMirror on Raspbian Buster RPB3+ on Sun, 13 Oct 2019 15:42:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> on pi zero also decided … so everything is in order …</p>
]]></description><link>https://forum.magicmirror.builders/post/62604</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62604</guid><dc:creator><![CDATA[bobwilliams]]></dc:creator><pubDate>Sun, 13 Oct 2019 15:42:52 GMT</pubDate></item><item><title><![CDATA[Reply to Problem when installing MagicMirror on Raspbian Buster RPB3+ on Sun, 13 Oct 2019 15:38:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bobwilliams" aria-label="Profile: bobwilliams">@<bdi>bobwilliams</bdi></a> thanks…   your original problem was with update, which is where i see a problem i need to correct</p>
]]></description><link>https://forum.magicmirror.builders/post/62603</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62603</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 13 Oct 2019 15:38:38 GMT</pubDate></item><item><title><![CDATA[Reply to Problem when installing MagicMirror on Raspbian Buster RPB3+ on Sun, 13 Oct 2019 15:37:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Yesterday I installed pi 3 B + on the raspberry, it was installed without problems.</p>
]]></description><link>https://forum.magicmirror.builders/post/62602</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62602</guid><dc:creator><![CDATA[bobwilliams]]></dc:creator><pubDate>Sun, 13 Oct 2019 15:37:48 GMT</pubDate></item><item><title><![CDATA[Reply to Problem when installing MagicMirror on Raspbian Buster RPB3+ on Sun, 13 Oct 2019 15:48:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomaslc" aria-label="Profile: thomaslc">@<bdi>thomaslc</bdi></a> sure… and the output of</p>
<pre><code>pm2 logs --lines=100
<p dir="auto">my email is the same userid as here on gmail…</p>
<p dir="auto">and there is some startup problem… cause pm2 thinks the mirror is running,<br />
and then u do npm start AGAIN…  but you should get output some output…</p>
]]></description><link>https://forum.magicmirror.builders/post/62598</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62598</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 13 Oct 2019 15:48:17 GMT</pubDate></item><item><title><![CDATA[Reply to Problem when installing MagicMirror on Raspbian Buster RPB3+ on Sun, 13 Oct 2019 12:49:25 GMT]]></title><description><![CDATA[<p dir="auto">It’s not working :(</p>
<p dir="auto"><a href="https://ibb.co/4s4GNC2" target="_blank" rel="noopener noreferrer nofollow ugc">https://ibb.co/4s4GNC2</a></p>
<p dir="auto">I can send you the log if you want :)</p>
]]></description><link>https://forum.magicmirror.builders/post/62597</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62597</guid><dc:creator><![CDATA[thomaslc]]></dc:creator><pubDate>Sun, 13 Oct 2019 12:49:25 GMT</pubDate></item><item><title><![CDATA[Reply to Problem when installing MagicMirror on Raspbian Buster RPB3+ on Sat, 05 Oct 2019 11:55:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomaslc" aria-label="Profile: thomaslc">@<bdi>thomaslc</bdi></a> while I test the installer, u could use the pm2 only script</p>
<p dir="auto">see instructions here , fix already added</p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/10907/new-script-to-install-fix-pm2-config-for-start-on-boot">https://forum.magicmirror.builders/topic/10907/new-script-to-install-fix-pm2-config-for-start-on-boot</a></p>
<p dir="auto">installer also tested and restarts on boot…  have to delete the MagicMirror folder again if u go this way</p>
]]></description><link>https://forum.magicmirror.builders/post/62101</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62101</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 05 Oct 2019 11:55:53 GMT</pubDate></item><item><title><![CDATA[Reply to Problem when installing MagicMirror on Raspbian Buster RPB3+ on Thu, 03 Oct 2019 19:30:24 GMT]]></title><description><![CDATA[<p dir="auto">Nice ! Keep me in touch !</p>
]]></description><link>https://forum.magicmirror.builders/post/62100</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62100</guid><dc:creator><![CDATA[thomaslc]]></dc:creator><pubDate>Thu, 03 Oct 2019 19:30:24 GMT</pubDate></item><item><title><![CDATA[Reply to Problem when installing MagicMirror on Raspbian Buster RPB3+ on Thu, 03 Oct 2019 19:28:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomaslc" aria-label="Profile: thomaslc">@<bdi>thomaslc</bdi></a> thanks for the log… found a bug in the installer on buster… testing fix now</p>
]]></description><link>https://forum.magicmirror.builders/post/62099</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62099</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 03 Oct 2019 19:28:53 GMT</pubDate></item><item><title><![CDATA[Reply to Problem when installing MagicMirror on Raspbian Buster RPB3+ on Thu, 03 Oct 2019 18:57:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomaslc" aria-label="Profile: thomaslc">@<bdi>thomaslc</bdi></a> said in <a href="/post/62097">Problem when installing MagicMirror on Raspbian Buster RPB3+</a>:</p>
<p dir="auto">And do you know why the original Magic Mirror link doesnt work ?</p>
<p dir="auto">cause it is old, doesn’t handle a bunch of things… which is why I am doing the updated version…<br />
once tested I will submit mine to replace the one on the MM site</p>
]]></description><link>https://forum.magicmirror.builders/post/62098</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62098</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 03 Oct 2019 18:57:12 GMT</pubDate></item><item><title><![CDATA[Reply to Problem when installing MagicMirror on Raspbian Buster RPB3+ on Thu, 03 Oct 2019 18:56:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> And do you know why the original Magic Mirror link doesnt work ?</p>
]]></description><link>https://forum.magicmirror.builders/post/62097</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62097</guid><dc:creator><![CDATA[thomaslc]]></dc:creator><pubDate>Thu, 03 Oct 2019 18:56:04 GMT</pubDate></item><item><title><![CDATA[Reply to Problem when installing MagicMirror on Raspbian Buster RPB3+ on Thu, 03 Oct 2019 18:51:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> i am building a buster image for myself now</p>
]]></description><link>https://forum.magicmirror.builders/post/62096</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62096</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 03 Oct 2019 18:51:28 GMT</pubDate></item><item><title><![CDATA[Reply to Problem when installing MagicMirror on Raspbian Buster RPB3+ on Thu, 03 Oct 2019 18:42:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomaslc" aria-label="Profile: thomaslc">@<bdi>thomaslc</bdi></a> also, the output says pm2 started MM and it is running , before u typed in your command…</p>
<p dir="auto">can u send me the ~/install.log</p>
<p dir="auto">same userid as here on gmail…</p>
]]></description><link>https://forum.magicmirror.builders/post/62094</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62094</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 03 Oct 2019 18:42:26 GMT</pubDate></item><item><title><![CDATA[Reply to Problem when installing MagicMirror on Raspbian Buster RPB3+ on Thu, 03 Oct 2019 18:40:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/62092">Problem when installing MagicMirror on Raspbian Buster RPB3+</a>:</p>
<p dir="auto">are u doing this over vpn or ssh?</p>
<p dir="auto">Nop without vpn or ssh, last fresh rasbian os and directly connected to my box with rj45 ethernet</p>
]]></description><link>https://forum.magicmirror.builders/post/62093</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62093</guid><dc:creator><![CDATA[thomaslc]]></dc:creator><pubDate>Thu, 03 Oct 2019 18:40:58 GMT</pubDate></item><item><title><![CDATA[Reply to Problem when installing MagicMirror on Raspbian Buster RPB3+ on Thu, 03 Oct 2019 18:29:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomaslc" aria-label="Profile: thomaslc">@<bdi>thomaslc</bdi></a> are u doing this over vpn or ssh?</p>
<p dir="auto">i use ssh, and then the display on my real machine shows the MagicMirror UI, while the ssh session is still active…</p>
]]></description><link>https://forum.magicmirror.builders/post/62092</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62092</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 03 Oct 2019 18:29:51 GMT</pubDate></item><item><title><![CDATA[Reply to Problem when installing MagicMirror on Raspbian Buster RPB3+ on Thu, 03 Oct 2019 18:27:27 GMT]]></title><description><![CDATA[<p dir="auto">Same problem :(</p>
<p dir="auto"><a href="https://ibb.co/DLS9hjm" target="_blank" rel="noopener noreferrer nofollow ugc">https://ibb.co/DLS9hjm</a></p>
]]></description><link>https://forum.magicmirror.builders/post/62091</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62091</guid><dc:creator><![CDATA[thomaslc]]></dc:creator><pubDate>Thu, 03 Oct 2019 18:27:27 GMT</pubDate></item><item><title><![CDATA[Reply to Problem when installing MagicMirror on Raspbian Buster RPB3+ on Thu, 03 Oct 2019 17:15:08 GMT]]></title><description><![CDATA[<p dir="auto">I swear I said yes for the pm2 lol. Oke Im gonna reinstall !</p>
]]></description><link>https://forum.magicmirror.builders/post/62089</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62089</guid><dc:creator><![CDATA[thomaslc]]></dc:creator><pubDate>Thu, 03 Oct 2019 17:15:08 GMT</pubDate></item><item><title><![CDATA[Reply to Problem when installing MagicMirror on Raspbian Buster RPB3+ on Thu, 03 Oct 2019 16:59:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomaslc" aria-label="Profile: thomaslc">@<bdi>thomaslc</bdi></a> easiest thing to do is rename the MagicMirror folder to MagicMirror.save</p>
<p dir="auto">in linux the rename command is mv</p>
<p dir="auto">then run my installer again</p>
<p dir="auto">see <a href="https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer">https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer</a><br />
for the url to use</p>
]]></description><link>https://forum.magicmirror.builders/post/62086</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62086</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 03 Oct 2019 16:59:16 GMT</pubDate></item><item><title><![CDATA[Reply to Problem when installing MagicMirror on Raspbian Buster RPB3+ on Thu, 03 Oct 2019 16:57:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomaslc" aria-label="Profile: thomaslc">@<bdi>thomaslc</bdi></a> during the install, it should have asked you if you wanted pm2 to be used to start the mirror app…</p>
]]></description><link>https://forum.magicmirror.builders/post/62085</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62085</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 03 Oct 2019 16:57:37 GMT</pubDate></item><item><title><![CDATA[Reply to Problem when installing MagicMirror on Raspbian Buster RPB3+ on Thu, 03 Oct 2019 16:53:01 GMT]]></title><description><![CDATA[<p dir="auto">It tells me that the command is not found :</p>
<p dir="auto"><a href="https://ibb.co/FBmcNts" target="_blank" rel="noopener noreferrer nofollow ugc">https://ibb.co/FBmcNts</a></p>
]]></description><link>https://forum.magicmirror.builders/post/62083</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62083</guid><dc:creator><![CDATA[thomaslc]]></dc:creator><pubDate>Thu, 03 Oct 2019 16:53:01 GMT</pubDate></item><item><title><![CDATA[Reply to Problem when installing MagicMirror on Raspbian Buster RPB3+ on Thu, 03 Oct 2019 12:38:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomaslc" aria-label="Profile: thomaslc">@<bdi>thomaslc</bdi></a> my name is Sam (i have that as my signature)</p>
<p dir="auto">i watched your video… very weird…</p>
<p dir="auto">open a terminal window , ctrl-alt-T, and then do<br />
pm2 status,<br />
pm2 logs<br />
u will have to ctrl-c to end that<br />
pm2 stop 0,<br />
pm2 start 0</p>
<p dir="auto">it LOOKS like pm2 starts WHILE still booting… I haven’t seen that on any of my systems…</p>
]]></description><link>https://forum.magicmirror.builders/post/62070</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62070</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 03 Oct 2019 12:38:26 GMT</pubDate></item><item><title><![CDATA[Reply to Problem when installing MagicMirror on Raspbian Buster RPB3+ on Thu, 03 Oct 2019 11:26:34 GMT]]></title><description><![CDATA[<p dir="auto">Hey, thanks for you answers !</p>
<p dir="auto">Sdetweil I tried your installer. When I reboot the Raspberry, magic mirror start but it’s coming back to the rasbian desktop few seconds later. I uploaded what happens on youtube : <a href="https://youtu.be/1dbtU3U5StM" target="_blank" rel="noopener noreferrer nofollow ugc">https://youtu.be/1dbtU3U5StM</a></p>
<p dir="auto">Buzzkc, what do you mean with “Sam’s installer” ? Sdetweil installer ?</p>
]]></description><link>https://forum.magicmirror.builders/post/62069</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62069</guid><dc:creator><![CDATA[thomaslc]]></dc:creator><pubDate>Thu, 03 Oct 2019 11:26:34 GMT</pubDate></item><item><title><![CDATA[Reply to Problem when installing MagicMirror on Raspbian Buster RPB3+ on Thu, 03 Oct 2019 03:50:00 GMT]]></title><description><![CDATA[<p dir="auto">Give Sam’s installer a try. If I recall on Buster I had to apt-get uninstall nodejs and npm, then let the MagicMirror installer install the correct versions of those softwares.</p>
]]></description><link>https://forum.magicmirror.builders/post/62065</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62065</guid><dc:creator><![CDATA[buzzkc]]></dc:creator><pubDate>Thu, 03 Oct 2019 03:50:00 GMT</pubDate></item></channel></rss>
