<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Smartthings]]></title><description><![CDATA[<p dir="auto">This is a module to display status information for devices connected to a Samsung Smartthings hub account.</p>
<p dir="auto"><a href="https://github.com/buzzkc/MMM-Smartthings" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/buzzkc/MMM-Smartthings</a></p>
<p dir="auto"><img src="https://github.com/buzzkc/MMM-Smartthings/blob/master/images/MMM-Smarthings.png?raw=true" alt="MMM-Smartthings" class=" img-fluid img-markdown" /></p>
<p dir="auto">Currently it’s limited to the following device capabilities: “switch”, “contactSensor”, “lock”, “temperatureMeasurement”, “relativeHumidityMeasurement”, &amp; “motionSensor”</p>
<p dir="auto">The frequency you update will depend on the number of devices you have. The api is limited to 250 requests per minute per app or device.</p>
<p dir="auto">If you have issues or want to request additional features, please submit a bug report on the github repository.</p>
<p dir="auto">[card:buzzkc/MMM-Smartthings]</p>
]]></description><link>https://forum.magicmirror.builders/topic/11270/mmm-smartthings</link><generator>RSS for Node</generator><lastBuildDate>Mon, 08 Jun 2026 05:00:42 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11270.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 03 Oct 2019 02:47:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Smartthings on Mon, 07 Oct 2019 19:45:10 GMT]]></title><description><![CDATA[<p dir="auto">I’ve added the temperature icons as well as a couple of config options for low and high temps, tempLowValue &amp; tempHighValue. They default to 65 &amp; 80, so you’ll want to set them to your celsius values. Icons will be green for between low and high (normal), blue when low, and red when high.</p>
<p dir="auto">If you’ve already installed, besides adding the two config options  you just need to change to the ~/MagicMirror/modules/MMM-Smartthings folder and do a git pull</p>
<p dir="auto">No need to run npm install as the dependencies haven’t changed.</p>
]]></description><link>https://forum.magicmirror.builders/post/62348</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62348</guid><dc:creator><![CDATA[buzzkc]]></dc:creator><pubDate>Mon, 07 Oct 2019 19:45:10 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Smartthings on Fri, 04 Oct 2019 10:43:34 GMT]]></title><description><![CDATA[<p dir="auto">VERY awesome!! :)</p>
]]></description><link>https://forum.magicmirror.builders/post/62135</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62135</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Fri, 04 Oct 2019 10:43:34 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Smartthings on Fri, 04 Oct 2019 00:25:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/buzzkc" aria-label="Profile: buzzkc">@<bdi>buzzkc</bdi></a></p>
<p dir="auto">Well done, sir. :thumbsup:</p>
]]></description><link>https://forum.magicmirror.builders/post/62118</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62118</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Fri, 04 Oct 2019 00:25:01 GMT</pubDate></item></channel></rss>
