<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MagicMirror wont start after failed update]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I have not worked with the MagicMirror for too long.<br />
I did an updaet a few days ago and had a power outage at that very moment :umbrella_with_rain_drops: . Although there are backup but unfortunately these are already a few months old :confounded_face: .<br />
Since the power failure Magicmirror does not start anymore. I have again executed the command git pull &amp;&amp; npm install without success.</p>
<p dir="auto">Here’s the npm log:</p>
<p dir="auto">0 info it worked with it ends with ok<br />
1 verbose cli [‘/ usr / bin / node’, ‘/ usr / bin / npm’, ‘start’]<br />
2 info using npm@6.11.3<br />
3 info using node@v10.16.3<br />
4 verbose run-script [‘prestart’, ‘start’, ‘poststart’]<br />
5 info lifecycle magicmirror@2.9.0~prestart: magicmirror@2.9.0<br />
6 info lifecycle magicmirror@2.9.0~start: magicmirror@2.9.0<br />
7 verbose lifecycle magicmirror@2.9.0~start: unsafe-perm in lifecycle true<br />
8 verbose lifecycle magicmirror@2.9.0~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local / sbin: / usr / local / bin: / usr / sbin: / usr / bin: / sbin: / bin: / usr / local / games / usr / games<br />
9 verbose lifecycle magicmirror@2.9.0~start: CWD: / home / pi / MagicMirror<br />
10 silly lifecycle magicmirror@2.9.0~start: Args: [‘-c’, ‘sh <a href="http://run-start.sh" target="_blank" rel="noopener noreferrer nofollow ugc">run-start.sh</a>’]<br />
11 silly lifecycle magicmirror@2.9.0~start: Returned: code: 1 signal: zero<br />
12 info lifecycle magicmirror@2.9.0~start: Failed to exec start script<br />
13 verbose stack Error: magicmirror@2.9.0 start: <code>sh run-start.sh</code><br />
13 verbose stack Exit status 1<br />
13 verbose stack at EventEmitter.  (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)<br />
13 verbose stack at EventEmitter.emit (events.js: 198: 13)<br />
13 verbose stack at ChildProcess.  (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)<br />
13 verbose stack at ChildProcess.emit (events.js: 198: 13)<br />
13 verbose stack at maybeClose (internal / child_process.js: 982: 16)<br />
13 verbose stack at Process.ChildProcess._handle.onexit (internal / child_process.js: 259: 5)<br />
14 verbose pkgid magicmirror@2.9.0<br />
15 verbose cwd / home / pi / MagicMirror<br />
16 verbose Linux 4.19.66-v7 +<br />
17 verbose argv “/ usr / bin / node” “/ usr / bin / npm” “start”<br />
18 verbose node v10.16.3<br />
19 verbose npm v6.11.3<br />
20 error code ELIFECYCLE<br />
21 error errno 1<br />
22 error magicmirror@2.9.0 start: <code>sh run-start.sh</code><br />
22 error Exit status 1<br />
23 error Failed at the magicmirror@2.9.0 start script.<br />
23 error This is probably not a problem with npm. There is likely additional logging output above.<br />
24 verbose exit [1, true]</p>
<p dir="auto">I hope someone can help me.</p>
]]></description><link>https://forum.magicmirror.builders/topic/11272/magicmirror-wont-start-after-failed-update</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 08:20:19 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11272.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 03 Oct 2019 12:17:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MagicMirror wont start after failed update on Thu, 03 Oct 2019 20:09:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/unknownuser26" aria-label="Profile: unknownuser26">@<bdi>unknownuser26</bdi></a> my pleasure</p>
]]></description><link>https://forum.magicmirror.builders/post/62107</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62107</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 03 Oct 2019 20:09:44 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror wont start after failed update on Thu, 03 Oct 2019 20:09:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/62105">MagicMirror wont start after failed update</a>:</p>
<p dir="auto">yes, they added checking for hacker vulnerabilities…<br />
one cannot fix them all… so, run audir fix once, and ignore the rest… they are just warnings</p>
<p dir="auto">Thank you for your help</p>
]]></description><link>https://forum.magicmirror.builders/post/62106</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62106</guid><dc:creator><![CDATA[unknownuser26]]></dc:creator><pubDate>Thu, 03 Oct 2019 20:09:24 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror wont start after failed update on Thu, 03 Oct 2019 23:57:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/unknownuser26" aria-label="Profile: unknownuser26">@<bdi>unknownuser26</bdi></a> yes, they added checking for hacker vulnerabilities…</p>
<p dir="auto">one cannot fix them all… so, run audit fix once, and ignore the rest… they are just warnings</p>
]]></description><link>https://forum.magicmirror.builders/post/62105</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62105</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 03 Oct 2019 23:57:04 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror wont start after failed update on Thu, 03 Oct 2019 20:05:29 GMT]]></title><description><![CDATA[<p dir="auto">Thanks alot. The Magic Mirror starts again.<br />
Unfortunately, I still get this message when I run npm install. Can you ignore the warnings? The instruction npm audit fix could not solve the problem either</p>
<pre><code>pi@magicmirror:~/MagicMirror $ npm install
electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
 node ./download-chromedriver.js
successfully dowloaded and extracted!
 electron@3.0.13 postinstall /home/pi/MagicMirror/node_modules/electron
 node install.js
Downloading tmp-11791-1-SHASUMS256.txt-3.0.13
[============================================&gt;] 100.0% of 4.79 kB (4.79 kB/s)
&gt; magicmirror@2.9.0 install /home/pi/MagicMirror
&gt; cd vendor &amp;&amp; npm install
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
audited 220 packages in 6.3s
found 5 vulnerabilities (4 low, 1 high)
  run `npm audit fix` to fix them, or `npm audit` for details
 magicmirror@2.9.0 postinstall /home/pi/MagicMirror
 sh untrack-css.sh &amp;&amp; sh installers/postinstall/postinstall.sh &amp;&amp; npm run install-fonts
MagicMirror installation successful!
magicmirror@2.9.0 install-fonts /home/pi/MagicMirror
cd fonts &amp;&amp; npm install
audited 1 package in 1.49s
found 0 vulnerabilities
npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dependencies yourself.
npm WARN acorn-jsx@5.0.2 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is installed. You must install peer dependencies yourself.
added 1044 packages from 1317 contributors and audited 3477 packages in 351.357s
]]></description><link>https://forum.magicmirror.builders/post/62103</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62103</guid><dc:creator><![CDATA[unknownuser26]]></dc:creator><pubDate>Thu, 03 Oct 2019 20:05:29 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror wont start after failed update on Thu, 03 Oct 2019 12:20:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/unknownuser26" aria-label="Profile: unknownuser26">@<bdi>unknownuser26</bdi></a> always fun when the lights go out!</p>
<p dir="auto">do</p>
<pre><code>cd ~/MagicMirror
rm -rf node_modules
npm install
<p dir="auto">that should get you back to working</p>
]]></description><link>https://forum.magicmirror.builders/post/62072</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62072</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 03 Oct 2019 12:20:10 GMT</pubDate></item></channel></rss>
