<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Monitor - energy saving]]></title><description><![CDATA[<p dir="auto">Hi there,</p>
<p dir="auto">2 years ago I built my own RIBBA-MagicMirror using a 19" TFT monitor. The monitor`s energy consumption is 25W. This is why I am using a PIR for saving energy. But, is has to switch on many times a day because it is standing on the relatively crowded floor.</p>
<p dir="auto">This I why I would like to ask for a more energy saving idea. At first e-ink displays came to my mind, of MM does not show IP cam feeds or similar.</p>
<p dir="auto">Is there a energy saving MagicMirror out there ?</p>
]]></description><link>https://forum.magicmirror.builders/topic/11298/monitor-energy-saving</link><generator>RSS for Node</generator><lastBuildDate>Fri, 10 Apr 2026 22:40:40 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11298.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 06 Oct 2019 11:51:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Monitor - energy saving on Sun, 06 Oct 2019 12:54:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/blebbens" aria-label="Profile: blebbens">@<bdi>blebbens</bdi></a> If your running the MM2 witohout any twoway mirror in front of the display maybe you could get away with an e-ink display.</p>
<p dir="auto">But the e-ink is not near bright enough to be viable behind a twoway mirror.</p>
<p dir="auto">There is low energy (energy star rated) screens out there, power is directly related to size (obviously), like there is the 24" LG<br />
24MK600M rated use is 14.1W (eco mode). So you could probably get a smaller screen that uses less.</p>
]]></description><link>https://forum.magicmirror.builders/post/62229</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62229</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Sun, 06 Oct 2019 12:54:04 GMT</pubDate></item></channel></rss>
