<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-RemoteCompliments - No Random Compliments]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">I hope you can help me. I tried to get MMM-RandomCompliments working with RandomCompliments. Everything else works fine. I had this fancy issue with a “broken image” icon, but that was easy to fix.<br />
I really have a hard time the get the module running with the random compliments file on my drive.<br />
I just copied the code from MMM-Compliments, so it shouldn’t be a problem with the program itself.</p>
<p dir="auto">Example from my file:</p>
<pre><code>{
    "anytime" : [
        "Hey there sexy!"
    "morning" : [
        "Good morning, sunshine!",
        "Who needs coffee when you have your smile?",
        "Go get 'em, Tiger!"
<p dir="auto">It doesn’t show anything at all of these sentences. Current compliments and scheduled compliments are working fine. Did you experience the same troubles or can you give me any help? Tried debugging the module with the browser console.</p>
<p dir="auto"><img src="/assets/uploads/files/1570369627973-anmerkung-2019-10-06-154222.jpg" alt="0_1570369627726_Anmerkung 2019-10-06 154222.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/11299/mmm-remotecompliments-no-random-compliments</link><generator>RSS for Node</generator><lastBuildDate>Mon, 15 Jun 2026 18:19:59 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11299.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 06 Oct 2019 13:47:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-RemoteCompliments - No Random Compliments on Mon, 07 Oct 2019 13:35:09 GMT]]></title><description><![CDATA[<p dir="auto">Yes, I have set up my google drive. As I said, the other compliment files (current and scheduled) are working fine.</p>
<p dir="auto"><img src="/assets/uploads/files/1570455307524-anmerkung-2019-10-07-153357.jpg" alt="0_1570455306596_Anmerkung 2019-10-07 153357.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/62325</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62325</guid><dc:creator><![CDATA[PottiMc]]></dc:creator><pubDate>Mon, 07 Oct 2019 13:35:09 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-RemoteCompliments - No Random Compliments on Mon, 07 Oct 2019 13:10:40 GMT]]></title><description><![CDATA[<p dir="auto">You have google drive setup?   this module expects to store config info on google drive (only)</p>
]]></description><link>https://forum.magicmirror.builders/post/62323</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62323</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 07 Oct 2019 13:10:40 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-RemoteCompliments - No Random Compliments on Mon, 07 Oct 2019 13:46:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Here is my config text according the module. Not much in there…</p>
<pre><code>{
            module: "MMM-RemoteCompliments",
            header: "MMM-RemoteCompliments",
	position: "middle_center",
                // See below for configurable options
<p dir="auto">Thank you for assisting me!</p>
]]></description><link>https://forum.magicmirror.builders/post/62318</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62318</guid><dc:creator><![CDATA[PottiMc]]></dc:creator><pubDate>Mon, 07 Oct 2019 13:46:11 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-RemoteCompliments - No Random Compliments on Sun, 06 Oct 2019 14:08:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pottimc" aria-label="Profile: PottiMc">@<bdi>PottiMc</bdi></a> can u show the rest of the compliments config from config.js</p>
<p dir="auto">also, can u use the markdown  characters to make the stuff more readable??</p>
]]></description><link>https://forum.magicmirror.builders/post/62238</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62238</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 06 Oct 2019 14:08:11 GMT</pubDate></item></channel></rss>
