<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Pir Sensor not shutting off screen.]]></title><description><![CDATA[<p dir="auto">Re: <a href="PIR/Button">{HowTo} turn on/off your monitor (Time based</a></p>
<p dir="auto">I have followed this tutorial and its great thank you. i installed the pir module and everything works great. the only issue is my screen goes into a no signal screen with an annoying cube in the middle which i cannot disable. So, on a fresh install i tried the manual way and followed all steps to have my screen turn black instead of off when the pir detects motion but nothing happens. i have run my python <a href="http://pir.py" target="_blank" rel="noopener noreferrer nofollow ugc">pir.py</a> and it detects my motions and gives me … everytime i move so i know its working ok. What have i missed? im new to the whole raspberry pi and programming world but im learning fast. I have a fully functional magic mirror with lots of 3rd party modules installed so im quite good with following instructions. Any help would be greatly appriciated.</p>
]]></description><link>https://forum.magicmirror.builders/topic/11322/pir-sensor-not-shutting-off-screen</link><generator>RSS for Node</generator><lastBuildDate>Fri, 08 May 2026 14:48:27 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11322.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 09 Oct 2019 00:03:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Pir Sensor not shutting off screen. on Wed, 09 Oct 2019 01:16:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tinsebayacc" aria-label="Profile: tinsebayacc">@<bdi>tinsebayacc</bdi></a></p>
<p dir="auto">I just added some code to my module to handle PIR_SENSOR sending notice of user around…<br />
so you shouldn’t have to change anything there…   well, stop it from turning off the display</p>
]]></description><link>https://forum.magicmirror.builders/post/62423</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62423</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 09 Oct 2019 01:16:58 GMT</pubDate></item><item><title><![CDATA[Reply to Pir Sensor not shutting off screen. on Wed, 09 Oct 2019 00:47:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tinsebayacc" aria-label="Profile: tinsebayacc">@<bdi>tinsebayacc</bdi></a></p>
<p dir="auto">Modify you script *</p>
]]></description><link>https://forum.magicmirror.builders/post/62422</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62422</guid><dc:creator><![CDATA[tinsebayacc]]></dc:creator><pubDate>Wed, 09 Oct 2019 00:47:31 GMT</pubDate></item><item><title><![CDATA[Reply to Pir Sensor not shutting off screen. on Wed, 09 Oct 2019 00:45:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thank you for your reply</p>
<p dir="auto">This would work for me. As I mentioned I am a beginner in all this. How would I configure your module to work with my pir sensor. Sorry if this seems a daft question, I’m still learning the ropes. Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/62421</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62421</guid><dc:creator><![CDATA[tinsebayacc]]></dc:creator><pubDate>Wed, 09 Oct 2019 00:45:17 GMT</pubDate></item><item><title><![CDATA[Reply to Pir Sensor not shutting off screen. on Wed, 09 Oct 2019 00:15:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tinsebayacc" aria-label="Profile: tinsebayacc">@<bdi>tinsebayacc</bdi></a> some devices do not have the ability to turn to back…  (none of my TV’s do)…</p>
<p dir="auto">I wrote my MMM-SleepWake (on github) module to provide the ability to hide all modules to darken the screen…<br />
its not off, and at night it has a glow (the backlight)…  but its better than nothing…</p>
<p dir="auto">i don’t care how you detect motion, camera, pir, wave, …</p>
<p dir="auto">when you do, call my provided script with ‘started’, and when the motion ends, call it again with ‘ended’<br />
see the readme.</p>
<p dir="auto">set the  “mode” to “hide”<br />
I use a webcam for motion detection</p>
]]></description><link>https://forum.magicmirror.builders/post/62420</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62420</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 09 Oct 2019 00:15:00 GMT</pubDate></item><item><title><![CDATA[Reply to Pir Sensor not shutting off screen. on Wed, 09 Oct 2019 00:06:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tinsebayacc" aria-label="Profile: tinsebayacc">@<bdi>tinsebayacc</bdi></a><br />
This is the tutorial ive been following</p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/6291/howto-turn-on-off-your-monitor-time-based-pir-button-app">https://forum.magicmirror.builders/topic/6291/howto-turn-on-off-your-monitor-time-based-pir-button-app</a></p>
]]></description><link>https://forum.magicmirror.builders/post/62419</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62419</guid><dc:creator><![CDATA[tinsebayacc]]></dc:creator><pubDate>Wed, 09 Oct 2019 00:06:41 GMT</pubDate></item></channel></rss>
