<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM NEST module after the retiring of Works with Nest]]></title><description><![CDATA[<p dir="auto">From september 2019 the service “Works with nest” is no more available, so it is not possible to create the token.<br />
How can i implement the NEST thermostat in MM2 after that?</p>
]]></description><link>https://forum.magicmirror.builders/topic/11334/mmm-nest-module-after-the-retiring-of-works-with-nest</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 09:45:07 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11334.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 10 Oct 2019 13:40:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM NEST module after the retiring of Works with Nest on Wed, 30 Dec 2020 02:18:04 GMT]]></title><description><![CDATA[<p dir="auto">Home-assistant was able to use the new API for it.<br />
<a href="https://www.home-assistant.io/integrations/nest/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.home-assistant.io/integrations/nest/</a></p>
]]></description><link>https://forum.magicmirror.builders/post/86366</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86366</guid><dc:creator><![CDATA[onetwankyfive]]></dc:creator><pubDate>Wed, 30 Dec 2020 02:18:04 GMT</pubDate></item><item><title><![CDATA[Reply to MMM NEST module after the retiring of Works with Nest on Mon, 28 Dec 2020 19:41:04 GMT]]></title><description><![CDATA[<p dir="auto">Sadly, if they’re no longer issuing API tokens, then free modules are no longer supported.</p>
<p dir="auto">This module is effectively dead. :(</p>
]]></description><link>https://forum.magicmirror.builders/post/86259</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86259</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Mon, 28 Dec 2020 19:41:04 GMT</pubDate></item><item><title><![CDATA[Reply to MMM NEST module after the retiring of Works with Nest on Mon, 28 Dec 2020 18:17:06 GMT]]></title><description><![CDATA[<p dir="auto">Anyone get this working?</p>
]]></description><link>https://forum.magicmirror.builders/post/86255</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86255</guid><dc:creator><![CDATA[onetwankyfive]]></dc:creator><pubDate>Mon, 28 Dec 2020 18:17:06 GMT</pubDate></item><item><title><![CDATA[Reply to MMM NEST module after the retiring of Works with Nest on Sun, 23 Aug 2020 22:42:55 GMT]]></title><description><![CDATA[<p dir="auto">Did anyone get NEST Thermostat working?</p>
]]></description><link>https://forum.magicmirror.builders/post/80644</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80644</guid><dc:creator><![CDATA[ardmhacha24]]></dc:creator><pubDate>Sun, 23 Aug 2020 22:42:55 GMT</pubDate></item><item><title><![CDATA[Reply to MMM NEST module after the retiring of Works with Nest on Thu, 14 Nov 2019 20:48:54 GMT]]></title><description><![CDATA[<p dir="auto">Me too. Anyone can help?</p>
]]></description><link>https://forum.magicmirror.builders/post/64446</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64446</guid><dc:creator><![CDATA[tanvir586]]></dc:creator><pubDate>Thu, 14 Nov 2019 20:48:54 GMT</pubDate></item><item><title><![CDATA[Reply to MMM NEST module after the retiring of Works with Nest on Thu, 14 Nov 2019 17:40:34 GMT]]></title><description><![CDATA[<p dir="auto">I too would like to know…</p>
]]></description><link>https://forum.magicmirror.builders/post/64436</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64436</guid><dc:creator><![CDATA[coolva]]></dc:creator><pubDate>Thu, 14 Nov 2019 17:40:34 GMT</pubDate></item></channel></rss>
