<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Exclude certain events from Calendar]]></title><description><![CDATA[<p dir="auto">I am trying to exclude certain events from a calendar.  The event is called Workout.  I have dabbled quite a bit with the excludedEvents command, but have had no luck.  Could someone please help me with the syntax to simply exclude events that contain the word Workout in the title?  I have tried the below and many other combinations with no success.  I put the command in the config.js file within the calendar config.  I have not receive JS errors.  It just does nothing.</p>
<pre><code>excludedEvents [ 'Workout'],
]]></description><link>https://forum.magicmirror.builders/topic/11357/exclude-certain-events-from-calendar</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 02:24:09 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11357.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 14 Oct 2019 18:07:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Exclude certain events from Calendar on Tue, 15 Oct 2019 18:09:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/theaddies" aria-label="Profile: theaddies">@<bdi>theaddies</bdi></a></p>
<pre><code>                 {
                         header: "Work",
                                 maximumEntries: '5',
                                 excludedEvents: [ {filterBy: 'Workout', caseSensitive: false} ],
                                                  url: 'https:www.mywebsite.com',
                                                 symbol: 'briefcase',
                                                 auth: {
                                                         user: 'xxxx',
                                                         pass: 'xxxxxxx',
                                                         method: 'basic'
]]></description><link>https://forum.magicmirror.builders/post/62699</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62699</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Tue, 15 Oct 2019 18:09:39 GMT</pubDate></item><item><title><![CDATA[Reply to Exclude certain events from Calendar on Tue, 15 Oct 2019 17:23:52 GMT]]></title><description><![CDATA[<p dir="auto">Unfortunately that wasn’t it.  I had the : in the code.  It isn’t clear to me whether the command should be in the calendar part of config.js or the default settings of calendar.js.  The code below, that doesn’t work, is from the config.js.</p>
<pre><code>                 {
                         header: "Work",
                                 excludedEvents: ["Workout"],
                                                 symbol: "briefcase", url:https:www.mywebsite.com
                                                 auth: {
                                                         user: 'xxxx',
                                                         pass: 'xxxxxxx',
                                                         method: 'basic'
]]></description><link>https://forum.magicmirror.builders/post/62698</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62698</guid><dc:creator><![CDATA[theaddies]]></dc:creator><pubDate>Tue, 15 Oct 2019 17:23:52 GMT</pubDate></item><item><title><![CDATA[Reply to Exclude certain events from Calendar on Mon, 14 Oct 2019 18:10:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/theaddies" aria-label="Profile: theaddies">@<bdi>theaddies</bdi></a> said in <a href="/post/62661">Exclude certain events from Calendar</a>:</p>
<p dir="auto">excludedEvents [ ‘Workout’],</p>
<p dir="auto">I might be wrong but I think you might be missing a colon.  It should read like this: <code>excludedEvents: [ 'Workout'],</code></p>
]]></description><link>https://forum.magicmirror.builders/post/62662</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62662</guid><dc:creator><![CDATA[mumblebaj]]></dc:creator><pubDate>Mon, 14 Oct 2019 18:10:31 GMT</pubDate></item></channel></rss>
