<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Pi keeps crashing]]></title><description><![CDATA[<p dir="auto">I have a fresh installation of Raspbien ( from noobs) on my pi 3b+. I have installed MM with only default modules and installed Alexa also. everything has been updated. The pi will run for a few minutes, ask Alexa a few questions then it will crash, no response what so ever. Is this too much for the pi to handle? Temperature rises to 75c +</p>
]]></description><link>https://forum.magicmirror.builders/topic/11393/pi-keeps-crashing</link><generator>RSS for Node</generator><lastBuildDate>Thu, 08 Oct 2026 01:00:31 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11393.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 18 Oct 2019 21:51:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Pi keeps crashing on Sun, 20 Oct 2019 09:11:51 GMT]]></title><description><![CDATA[<p dir="auto">Hello, I do not know what your problem is due to, but I recommend that you do not use NOOBS, use better only raspbian. You can download it here: <a href="https://www.raspberrypi.org/downloads/raspbian/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.raspberrypi.org/downloads/raspbian/</a></p>
<p dir="auto">I recommend you the raspbian image with desktop (not the one with recommended software)</p>
]]></description><link>https://forum.magicmirror.builders/post/63011</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63011</guid><dc:creator><![CDATA[qu1que]]></dc:creator><pubDate>Sun, 20 Oct 2019 09:11:51 GMT</pubDate></item></channel></rss>
