<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Bedside clock and info screen]]></title><description><![CDATA[<p dir="auto">Had my own custom screen code running for a few years, but wanted to see if MagicMirror could do it better.</p>
<p dir="auto"><img src="https://i.imgur.com/HwlCTlG.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">it’s currently running<br />
MMM-aqicn<br />
MMM-DarkSkyForecast<br />
MMM-MoonPhase<br />
MMM-network-signal<br />
MMM-Screendimmer<br />
<a href="https://forum.magicmirror.builders/topic/11440/mmm-sunrise-sunset">MMM-Sunrise-Sunset</a> (my own module)<br />
MMM-Tado</p>
<p dir="auto">So far, am rather happy with it. Got MMM-Screendimmer set to turn the brightness down as far as it will go at night and I customised some of the default CSS to change colours and the margins/padding around modules.</p>
]]></description><link>https://forum.magicmirror.builders/topic/11443/bedside-clock-and-info-screen</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Apr 2026 12:59:52 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11443.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 25 Oct 2019 10:42:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Bedside clock and info screen on Mon, 25 Nov 2019 15:29:35 GMT]]></title><description><![CDATA[<p dir="auto">This clock suitable for outdoor? What is the best projection clock with outdoor temperature? Like in this article <a href="https://webproductradar.com/best-projection-clock-with-outdoor-temperature" target="_blank" rel="noopener noreferrer nofollow ugc">Best Projection Clock with Outdoor Temperature | Webproductradar</a></p>
]]></description><link>https://forum.magicmirror.builders/post/64926</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64926</guid><dc:creator><![CDATA[MonteRick]]></dc:creator><pubDate>Mon, 25 Nov 2019 15:29:35 GMT</pubDate></item><item><title><![CDATA[Reply to Bedside clock and info screen on Fri, 25 Oct 2019 20:45:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/buzzkc" aria-label="Profile: buzzkc">@<bdi>buzzkc</bdi></a> I’m not 100% sure. it’s capacitive touch, so it probably does.</p>
]]></description><link>https://forum.magicmirror.builders/post/63313</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63313</guid><dc:creator><![CDATA[vbloke]]></dc:creator><pubDate>Fri, 25 Oct 2019 20:45:53 GMT</pubDate></item><item><title><![CDATA[Reply to Bedside clock and info screen on Fri, 25 Oct 2019 20:34:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vbloke" aria-label="Profile: vbloke">@<bdi>vbloke</bdi></a> Just curious, does the 7" touch support swipe events? I’m assuming it’s a capacitive touch and does, but wasn’t sure.</p>
]]></description><link>https://forum.magicmirror.builders/post/63309</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63309</guid><dc:creator><![CDATA[buzzkc]]></dc:creator><pubDate>Fri, 25 Oct 2019 20:34:01 GMT</pubDate></item><item><title><![CDATA[Reply to Bedside clock and info screen on Fri, 25 Oct 2019 18:06:26 GMT]]></title><description><![CDATA[<p dir="auto">Very nice. I think I may have to consider going up to a larger size on mine. Currently I’m running a 3.5" screen, but there is no dimming ability.</p>
]]></description><link>https://forum.magicmirror.builders/post/63303</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63303</guid><dc:creator><![CDATA[buzzkc]]></dc:creator><pubDate>Fri, 25 Oct 2019 18:06:26 GMT</pubDate></item><item><title><![CDATA[Reply to Bedside clock and info screen on Fri, 25 Oct 2019 10:55:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> if you’re using the mirror as a bedside display, it’s invaluable to stop yourself getting blinded.</p>
]]></description><link>https://forum.magicmirror.builders/post/63278</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63278</guid><dc:creator><![CDATA[vbloke]]></dc:creator><pubDate>Fri, 25 Oct 2019 10:55:46 GMT</pubDate></item><item><title><![CDATA[Reply to Bedside clock and info screen on Fri, 25 Oct 2019 10:49:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vbloke" aria-label="Profile: vbloke">@<bdi>vbloke</bdi></a> nice work…  hadn’t seen ScreenDimmer before</p>
]]></description><link>https://forum.magicmirror.builders/post/63277</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63277</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 25 Oct 2019 10:49:47 GMT</pubDate></item></channel></rss>
