<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MagicMirror won&#x27;t start with newest build]]></title><description><![CDATA[<p dir="auto">after running npm start, I keep getting the following error:</p>
<pre><code>pi@raspberrypi:~/MagicMirror $ npm start
&gt; magicmirror@2.9.0 start /home/pi/MagicMirror
&gt; sh run-start.sh
/home/pi/MagicMirror/node_modules/electron/dist/electron: /lib/arm-linux-gnueabihf/libdbus-1.so.3: no version information available (required by /home/pi/MagicMirror/node_modules/electron/dist/electron)
/home/pi/MagicMirror/node_modules/electron/dist/electron: /usr/lib/arm-linux-gnueabihf/libnss3.so: version `NSS_3.22' not found (required by /home/pi/MagicMirror/node_modules/electron/dist/electron)
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! magicmirror@2.9.0 start: `sh run-start.sh`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the magicmirror@2.9.0 start script.
npm ERR!     /home/pi/.npm/_logs/2019-10-27T15_55_59_428Z-debug.log
<p dir="auto">Not sure where to go from here, any help would be appreciated. Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/topic/11464/magicmirror-won-t-start-with-newest-build</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 06:49:54 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11464.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 27 Oct 2019 16:18:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MagicMirror won&#x27;t start with newest build on Thu, 31 Oct 2019 04:21:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/roooooony" aria-label="Profile: roooooony">@<bdi>roooooony</bdi></a><br />
can you do</p>
<pre><code>ls /usr/lib/arm-linux-gnueabihf/libnss3.so -laF
and
ls /lib/arm-linux-gnueabihf/libdbus-1.so.3 -laF
<p dir="auto">mine are dated aug 22 and Jun 9 (libdbus-1.so.3.19.11) respectively</p>
<p dir="auto">and a thing to test out<br />
rename the ~/MagicMirror/node_modules/electron folder to some other name<br />
then do</p>
<pre><code>cd ~/MagicMirror
npm install electron@6.0.12
<p dir="auto">then try to start MagicMirror</p>
]]></description><link>https://forum.magicmirror.builders/post/63578</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63578</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 31 Oct 2019 04:21:30 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror won&#x27;t start with newest build on Thu, 31 Oct 2019 11:48:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/roooooony" aria-label="Profile: roooooony">@<bdi>roooooony</bdi></a> thanks… I have opened issue <a href="https://github.com/MichMich/MagicMirror/issues/1800" target="_blank" rel="noopener noreferrer nofollow ugc">1800</a>  to document this problem</p>
]]></description><link>https://forum.magicmirror.builders/post/63584</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63584</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 31 Oct 2019 11:48:32 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror won&#x27;t start with newest build on Thu, 31 Oct 2019 04:59:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> This worked! Thank you for the quick reply!</p>
]]></description><link>https://forum.magicmirror.builders/post/63579</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63579</guid><dc:creator><![CDATA[roooooony]]></dc:creator><pubDate>Thu, 31 Oct 2019 04:59:47 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror won&#x27;t start with newest build on Thu, 31 Oct 2019 04:21:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/roooooony" aria-label="Profile: roooooony">@<bdi>roooooony</bdi></a><br />
can you do</p>
and
then do</p>
]]></description><link>https://forum.magicmirror.builders/post/63578</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63578</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 31 Oct 2019 04:21:30 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror won&#x27;t start with newest build on Thu, 31 Oct 2019 03:40:48 GMT]]></title><description><![CDATA[<p dir="auto">I am having the same error, any guidance would be greatly appreciated ( : Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/63577</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63577</guid><dc:creator><![CDATA[roooooony]]></dc:creator><pubDate>Thu, 31 Oct 2019 03:40:48 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror won&#x27;t start with newest build on Sun, 27 Oct 2019 19:55:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/parthp90" aria-label="Profile: parthp90">@<bdi>parthp90</bdi></a> looks like u don’t have some graphics libraries.  So, search Google on the two libs. And install them.</p>
<p dir="auto">What os are your running?<br />
And in graphics mode? Right?</p>
]]></description><link>https://forum.magicmirror.builders/post/63422</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63422</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 27 Oct 2019 19:55:07 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror won&#x27;t start with newest build on Sun, 27 Oct 2019 19:17:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/broberg" aria-label="Profile: broberg">@<bdi>broberg</bdi></a> I did, but I still get the same error. I’ve also tried doing multiple fresh installs including using the updated installer script (<a href="https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer">https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer</a>), but always end up with that same error</p>
]]></description><link>https://forum.magicmirror.builders/post/63420</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63420</guid><dc:creator><![CDATA[parthp90]]></dc:creator><pubDate>Sun, 27 Oct 2019 19:17:49 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror won&#x27;t start with newest build on Sun, 27 Oct 2019 17:19:05 GMT]]></title><description><![CDATA[<p dir="auto">After update, did you run Npm install in the magicmirror folder?</p>
]]></description><link>https://forum.magicmirror.builders/post/63415</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63415</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Sun, 27 Oct 2019 17:19:05 GMT</pubDate></item></channel></rss>
