<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Configured PIR sensor but won&#x27;t trigger]]></title><description><![CDATA[<p dir="auto">Quite new to MM and this is me trying first module.</p>
<p dir="auto">I connected the pins (which I think might be the problem) and added module in config.js too. Now my MM is booting and modules are being displayed but the senor is not turning off the monitor.</p>
<p dir="auto">I strongly believe the issue might be with the pins I have connected, cause I have zero knowledge about these connections.</p>
<p dir="auto"><img src="https://i.imgur.com/pvs9Ngw.jpg" alt="Can you please check these connections?" class=" img-fluid img-markdown" /></p>
<p dir="auto">If not what else could be the problem?</p>
]]></description><link>https://forum.magicmirror.builders/topic/11495/configured-pir-sensor-but-won-t-trigger</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 19:59:05 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11495.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 31 Oct 2019 16:06:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Configured PIR sensor but won&#x27;t trigger on Sat, 02 Nov 2019 06:09:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tinsebayacc" aria-label="Profile: tinsebayacc">@<bdi>tinsebayacc</bdi></a> this is the one <a href="https://github.com/paviro/MMM-PIR-Sensor/blob/master/README.md" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/paviro/MMM-PIR-Sensor/blob/master/README.md</a></p>
]]></description><link>https://forum.magicmirror.builders/post/63633</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63633</guid><dc:creator><![CDATA[Newbie007]]></dc:creator><pubDate>Sat, 02 Nov 2019 06:09:20 GMT</pubDate></item><item><title><![CDATA[Reply to Configured PIR sensor but won&#x27;t trigger on Fri, 01 Nov 2019 15:00:52 GMT]]></title><description><![CDATA[<p dir="auto">What module are you using ?</p>
]]></description><link>https://forum.magicmirror.builders/post/63611</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63611</guid><dc:creator><![CDATA[tinsebayacc]]></dc:creator><pubDate>Fri, 01 Nov 2019 15:00:52 GMT</pubDate></item><item><title><![CDATA[Reply to Configured PIR sensor but won&#x27;t trigger on Fri, 01 Nov 2019 14:15:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/newbie007" aria-label="Profile: Newbie007">@<bdi>Newbie007</bdi></a> said in <a href="/post/63606">Configured PIR sensor but won't trigger</a>:</p>
<p dir="auto">it is working sporadically not sure what is causing that?</p>
<p dir="auto">remember, there is a delay on rearming for next movement</p>
<p dir="auto">as for the lights… PIR sensor ITSELF doesn’t know anything about lights…<br />
it just senses heat…</p>
<p dir="auto">some code would have to turn the event (heat=yes) to action (turn on relay for lights, or set pin to hi/low) depending on what electronics need</p>
]]></description><link>https://forum.magicmirror.builders/post/63608</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63608</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 01 Nov 2019 14:15:46 GMT</pubDate></item><item><title><![CDATA[Reply to Configured PIR sensor but won&#x27;t trigger on Fri, 01 Nov 2019 12:49:08 GMT]]></title><description><![CDATA[<p dir="auto">That was a helpful thread.</p>
<p dir="auto">I noticed mine did work couple of times, it is working sporadically not sure what is causing that?</p>
<p dir="auto">Also, many posts are suggesting to use breadboard why is that? I have never used one so not sure its use. Do you know how can I use same PIR sensor to turn on led lights and which type of led does rpi and pir suport</p>
]]></description><link>https://forum.magicmirror.builders/post/63606</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63606</guid><dc:creator><![CDATA[Newbie007]]></dc:creator><pubDate>Fri, 01 Nov 2019 12:49:08 GMT</pubDate></item><item><title><![CDATA[Reply to Configured PIR sensor but won&#x27;t trigger on Thu, 31 Oct 2019 16:30:41 GMT]]></title><description><![CDATA[<p dir="auto">I think this post may be helpful. <a href="https://forum.magicmirror.builders/topic/6987/mmm-pir-sensor-problems/10">https://forum.magicmirror.builders/topic/6987/mmm-pir-sensor-problems/10</a></p>
<p dir="auto">It appears that you have  wired correctly. Although I would use the Red wire on the VCC for power and the black wire to denote ground and the brown wire as the output wire.  Thats typically the way wiring is denoted.</p>
<p dir="auto">I believe that pin 22 is used for the output so double check that.  There is also a delay setting in the config.js that the previous thread speaks of that may impact your setup.<br />
Give it a read.</p>
]]></description><link>https://forum.magicmirror.builders/post/63586</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63586</guid><dc:creator><![CDATA[BD0G]]></dc:creator><pubDate>Thu, 31 Oct 2019 16:30:41 GMT</pubDate></item></channel></rss>
