<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Help with monitor&#x27;s buttons TIA]]></title><description><![CDATA[<p dir="auto">Hi people, I bought a Fujitsu SL23T-1 monitor ( 2nd hand ) with the intention of making a mirror…  but, after taking the screen out and boards etc, I can’t get these buttons to switch the thing on. ( yes, they did switch it on before I took it all apart)<br />
I’ve little experience of these types of buttons but are the connectors fairly universal? Or control board specific? To be honest I’m not really sure of what they’re called to be able to search for them online<br />
<img src="http://imgur.com/gallery/wjsZp0w" alt="alt text" class=" img-fluid img-markdown" /><br />
Any help and advice is very welcome.</p>
]]></description><link>https://forum.magicmirror.builders/topic/11503/help-with-monitor-s-buttons-tia</link><generator>RSS for Node</generator><lastBuildDate>Mon, 18 May 2026 09:38:32 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11503.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 01 Nov 2019 19:42:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Help with monitor&#x27;s buttons TIA on Sun, 03 Nov 2019 20:59:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thisistheplace" aria-label="Profile: thisistheplace">@<bdi>thisistheplace</bdi></a> Thank you, this is sound advice. I’ll give your suggestions a try after rescuing the bezel from the rubbish bins :) failing that, I’m guessing a cheap Chinese control board is the only option left to try. Thank you again for your time and help :)</p>
]]></description><link>https://forum.magicmirror.builders/post/63755</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63755</guid><dc:creator><![CDATA[sqz0]]></dc:creator><pubDate>Sun, 03 Nov 2019 20:59:52 GMT</pubDate></item><item><title><![CDATA[Reply to Help with monitor&#x27;s buttons TIA on Sun, 03 Nov 2019 17:31:39 GMT]]></title><description><![CDATA[<p dir="auto">Google says that this monitor has touch sensing keys. I think some needed components for the keys is left in the bezel. Maybe glued from the back or infused in the bezel itself. Try to put only the keys on their place in the bezel and see if they work again.</p>
<p dir="auto">I don’t think you can change them to other keys so you might need an other monitor or you try to make the original keys work. Maybe you can cut the needed componentes out of the bezel if you don’t want to reassemble the monitor.</p>
<p dir="auto">Or you setting up the monitor like you need it and hopefully it will keep its setting after a power loss.</p>
]]></description><link>https://forum.magicmirror.builders/post/63744</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63744</guid><dc:creator><![CDATA[thisistheplace]]></dc:creator><pubDate>Sun, 03 Nov 2019 17:31:39 GMT</pubDate></item><item><title><![CDATA[Reply to Help with monitor&#x27;s buttons TIA on Sat, 02 Nov 2019 13:35:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sqz0" aria-label="Profile: sqz0">@<bdi>sqz0</bdi></a> no, sorry, i do not</p>
]]></description><link>https://forum.magicmirror.builders/post/63640</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63640</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 02 Nov 2019 13:35:32 GMT</pubDate></item><item><title><![CDATA[Reply to Help with monitor&#x27;s buttons TIA on Sat, 02 Nov 2019 08:40:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> thanks for your input. Do you have any opinion on the other questions asked? Apologies for the lack of precise details, but would you know if I could purchase a set of actual buttons which could be used control the board? Would you know if these connections are universal or board specific?</p>
]]></description><link>https://forum.magicmirror.builders/post/63634</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63634</guid><dc:creator><![CDATA[sqz0]]></dc:creator><pubDate>Sat, 02 Nov 2019 08:40:17 GMT</pubDate></item><item><title><![CDATA[Reply to Help with monitor&#x27;s buttons TIA on Sat, 02 Nov 2019 04:20:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sqz0" aria-label="Profile: sqz0">@<bdi>sqz0</bdi></a> got no idea</p>
]]></description><link>https://forum.magicmirror.builders/post/63631</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63631</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 02 Nov 2019 04:20:15 GMT</pubDate></item><item><title><![CDATA[Reply to Help with monitor&#x27;s buttons TIA on Fri, 01 Nov 2019 20:29:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sqz0" aria-label="Profile: sqz0">@<bdi>sqz0</bdi></a> flashing state,</p>
]]></description><link>https://forum.magicmirror.builders/post/63625</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63625</guid><dc:creator><![CDATA[sqz0]]></dc:creator><pubDate>Fri, 01 Nov 2019 20:29:08 GMT</pubDate></item><item><title><![CDATA[Reply to Help with monitor&#x27;s buttons TIA on Fri, 01 Nov 2019 20:27:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> the two pictures show the lights illuminated and unilluminated, possibly indicating a psu error. Can you advise?</p>
]]></description><link>https://forum.magicmirror.builders/post/63624</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63624</guid><dc:creator><![CDATA[sqz0]]></dc:creator><pubDate>Fri, 01 Nov 2019 20:27:00 GMT</pubDate></item><item><title><![CDATA[Reply to Help with monitor&#x27;s buttons TIA on Fri, 01 Nov 2019 20:12:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sqz0" aria-label="Profile: sqz0">@<bdi>sqz0</bdi></a> and what are the two.pics?</p>
<p dir="auto">Lit and not lit?</p>
]]></description><link>https://forum.magicmirror.builders/post/63623</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63623</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 01 Nov 2019 20:12:21 GMT</pubDate></item><item><title><![CDATA[Reply to Help with monitor&#x27;s buttons TIA on Fri, 01 Nov 2019 19:58:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Correct, but these switch the monitor on and off.</p>
]]></description><link>https://forum.magicmirror.builders/post/63622</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63622</guid><dc:creator><![CDATA[sqz0]]></dc:creator><pubDate>Fri, 01 Nov 2019 19:58:58 GMT</pubDate></item><item><title><![CDATA[Reply to Help with monitor&#x27;s buttons TIA on Fri, 01 Nov 2019 19:52:55 GMT]]></title><description><![CDATA[<p dir="auto">i see lights… not buttons</p>
]]></description><link>https://forum.magicmirror.builders/post/63621</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63621</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 01 Nov 2019 19:52:55 GMT</pubDate></item><item><title><![CDATA[Reply to Help with monitor&#x27;s buttons TIA on Fri, 01 Nov 2019 19:46:26 GMT]]></title><description><![CDATA[<p dir="auto"><img src="http://imgur.com/gallery/wjsZp0w" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto"><a href="http://imgur.com/gallery/wjsZp0w" target="_blank" rel="noopener noreferrer nofollow ugc">http://imgur.com/gallery/wjsZp0w</a></p>
]]></description><link>https://forum.magicmirror.builders/post/63620</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63620</guid><dc:creator><![CDATA[sqz0]]></dc:creator><pubDate>Fri, 01 Nov 2019 19:46:26 GMT</pubDate></item></channel></rss>
