<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Static text on several lines]]></title><description><![CDATA[<p dir="auto">I want a static text with several lines with the option to choose font and color for different lines.<br />
When I have several lines in config.js then only the last line will appear.<br />
How can that be done ?</p>
]]></description><link>https://forum.magicmirror.builders/topic/1151/static-text-on-several-lines</link><generator>RSS for Node</generator><lastBuildDate>Wed, 13 May 2026 18:31:05 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1151.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 09 Dec 2016 17:38:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Static text on several lines on Sat, 10 Dec 2016 12:31:09 GMT]]></title><description><![CDATA[<p dir="auto">Don’t have any experience of CSS - could you give me an example how I should continue … I checked the CSS documentation but it is HUGE … I guess if I could get some guidelines then I can figure it out …</p>
]]></description><link>https://forum.magicmirror.builders/post/9134</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9134</guid><dc:creator><![CDATA[zkab]]></dc:creator><pubDate>Sat, 10 Dec 2016 12:31:09 GMT</pubDate></item><item><title><![CDATA[Reply to Static text on several lines on Sat, 10 Dec 2016 03:17:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/zkab" aria-label="Profile: zkab">@<bdi>zkab</bdi></a> You should be able to configure the Hello World module to display any text you need. Insert multiple </p><div> entities, each with a named class. You can then configure the custom CSS to display each named class as you see fit.<p></p>
</div>]]></description><link>https://forum.magicmirror.builders/post/9122</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9122</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Sat, 10 Dec 2016 03:17:03 GMT</pubDate></item></channel></rss>
