<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Conversation Error: { Error: 14 UNAVAILABLE: Service unavailable.]]></title><description><![CDATA[<p dir="auto">I have a problem when I start the magic mirror. Everything seems to boot as it should but the google assistant does not listen to me. So I press the widget to start it manually but doesn’t listen either.</p>
<p dir="auto">Here you can see the part of the log where it gets errors:</p>
<p dir="auto">[HOTWORD] begins.<br />
[HOTWORD] Detector starts listening.<br />
[HOTWORD] stops.<br />
[HOTWORD] Final Result: { detected: false }<br />
[AMK2] assistant ready<br />
[AMK2] Conversation starts.<br />
[AMK2] Started with text query: brief today<br />
{ requestId: ‘5dbd29c0-0000-2458-852e-089e08276030’ } { profileFile: ‘default.json’, lang: ‘en-US’ }<br />
[AMK2] Device Action: { requestId: ‘5dbd29c0-0000-2458-852e-089e08276030’ }<br />
[AMK2] Assistant Text Response:<br />
[AMK2] Conversation Completed<br />
[AMK2] Conversation Error: { Error: 14 UNAVAILABLE: Service unavailable.<br />
at Object.exports.createStatusError (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/common.js:91:15)<br />
at ClientDuplexStream._emitStatusIfDone (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client.js:233:26)<br />
at ClientDuplexStream._receiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client.js:211:8)<br />
at Object.onReceiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:1306:15)<br />
at InterceptingListener._callNext (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:568:42)<br />
at InterceptingListener.onReceiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:618:8)<br />
at /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:1123:18<br />
code: 14,<br />
metadata:<br />
Metadata { _internal_repr: { ‘content-disposition’: [Array] }, flags: 0 },<br />
details: ‘Service unavailable.’ }</p>
<p dir="auto"><img src="/assets/uploads/files/1572718841976-captura-de-pantalla-18-resized.png" alt="1_1572718840181_Captura de pantalla (18).png" class=" img-fluid img-markdown" /> <img src="/assets/uploads/files/1572718840952-captura-de-pantalla-17-resized.png" alt="0_1572718840181_Captura de pantalla (17).png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/11511/conversation-error-error-14-unavailable-service-unavailable</link><generator>RSS for Node</generator><lastBuildDate>Tue, 16 Jun 2026 21:58:04 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11511.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 02 Nov 2019 18:23:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Conversation Error: { Error: 14 UNAVAILABLE: Service unavailable. on Mon, 09 Dec 2019 18:35:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/juantata" aria-label="Profile: juantata">@<bdi>juantata</bdi></a></p>
<p dir="auto">Putting sound through hdmi didn’t work for me neither. Only USB and headphone jack worked for me for speakers. The mic has to be a usb one though.</p>
]]></description><link>https://forum.magicmirror.builders/post/65710</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65710</guid><dc:creator><![CDATA[FLOW THE NOOB]]></dc:creator><pubDate>Mon, 09 Dec 2019 18:35:06 GMT</pubDate></item><item><title><![CDATA[Reply to Conversation Error: { Error: 14 UNAVAILABLE: Service unavailable. on Fri, 06 Dec 2019 23:17:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/flow-the-noob" aria-label="Profile: FLOW-THE-NOOB">@<bdi>FLOW-THE-NOOB</bdi></a><br />
Hi. I have the same problem, the only difference is that I have the speakers for HDMI. Any solution?</p>
]]></description><link>https://forum.magicmirror.builders/post/65583</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65583</guid><dc:creator><![CDATA[juantata]]></dc:creator><pubDate>Fri, 06 Dec 2019 23:17:26 GMT</pubDate></item><item><title><![CDATA[Reply to Conversation Error: { Error: 14 UNAVAILABLE: Service unavailable. on Sat, 23 Nov 2019 21:55:38 GMT]]></title><description><![CDATA[<p dir="auto">Oh, ok. That makes sense.</p>
]]></description><link>https://forum.magicmirror.builders/post/65011</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65011</guid><dc:creator><![CDATA[09succotash]]></dc:creator><pubDate>Sat, 23 Nov 2019 21:55:38 GMT</pubDate></item><item><title><![CDATA[Reply to Conversation Error: { Error: 14 UNAVAILABLE: Service unavailable. on Sat, 23 Nov 2019 16:04:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/09succotash" aria-label="Profile: 09succotash">@<bdi>09succotash</bdi></a> Go to your desktop. Right click on the volume icon. Choose your recording and playback devices. Adjust their volumes to max in audio device settings.</p>
<p dir="auto"><img src="/assets/uploads/files/1574525004176-captura-de-pantalla-37.png" alt="0_1574525003718_Captura de pantalla (37).png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/64978</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64978</guid><dc:creator><![CDATA[FLOW THE NOOB]]></dc:creator><pubDate>Sat, 23 Nov 2019 16:04:20 GMT</pubDate></item><item><title><![CDATA[Reply to Conversation Error: { Error: 14 UNAVAILABLE: Service unavailable. on Sat, 23 Nov 2019 01:34:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/flow-the-noob" aria-label="Profile: FLOW-THE-NOOB">@<bdi>FLOW-THE-NOOB</bdi></a> How did you solve it? Im having the same issue, please tell me.</p>
]]></description><link>https://forum.magicmirror.builders/post/64962</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64962</guid><dc:creator><![CDATA[09succotash]]></dc:creator><pubDate>Sat, 23 Nov 2019 01:34:00 GMT</pubDate></item><item><title><![CDATA[Reply to Conversation Error: { Error: 14 UNAVAILABLE: Service unavailable. on Sun, 03 Nov 2019 20:06:56 GMT]]></title><description><![CDATA[<p dir="auto">I solved it!!. The assistant mk2 module now hears to my mic! and answers!</p>
]]></description><link>https://forum.magicmirror.builders/post/63753</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63753</guid><dc:creator><![CDATA[FLOW THE NOOB]]></dc:creator><pubDate>Sun, 03 Nov 2019 20:06:56 GMT</pubDate></item><item><title><![CDATA[Reply to Conversation Error: { Error: 14 UNAVAILABLE: Service unavailable. on Sun, 03 Nov 2019 17:03:15 GMT]]></title><description><![CDATA[<p dir="auto">Still doesn’t work. It shouldn’t be a mic problem because it gets detected and I can record myself.</p>
<p dir="auto">Getting this log:</p>
<p dir="auto">pi@raspberrypi:~ $ cd MagicMirror<br />
pi@raspberrypi:~/MagicMirror $ npm start</p>
<p dir="auto">magicmirror@2.9.0 start /home/pi/MagicMirror<br />
sh <a href="http://run-start.sh" target="_blank" rel="noopener noreferrer nofollow ugc">run-start.sh</a></p>
<p dir="auto">Starting MagicMirror: v2.9.0<br />
Loading config …<br />
Loading module helpers …<br />
No helper found for module: alert.<br />
Initializing new module helper …<br />
Module helper loaded: updatenotification<br />
No helper found for module: clock.<br />
Module helper loaded: calendar<br />
No helper found for module: compliments.<br />
No helper found for module: currentweather.<br />
No helper found for module: weatherforecast.<br />
Module helper loaded: newsfeed<br />
Module helper loaded: MMM-Hotword<br />
Module helper loaded: MMM-AssistantMk2<br />
All module helpers loaded.<br />
Starting server on port 8080 …<br />
Server started …<br />
Connecting socket for: updatenotification<br />
Connecting socket for: calendar<br />
Starting node helper for: calendar<br />
Connecting socket for: newsfeed<br />
Starting module: newsfeed<br />
Connecting socket for: MMM-Hotword<br />
[HOTWORD] MMM-Hotword starts<br />
Connecting socket for: MMM-AssistantMk2<br />
Sockets connected &amp; modules started …<br />
Launching application.<br />
Create new calendar fetcher for url: <a href="http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics</a> - Interval: 300000<br />
Create new news fetcher for url: <a href="http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml</a> - Interval: 300000<br />
[AMK2] Recipe is loaded: hide_and_show_all_modules.js<br />
[AMK2] Recipe is loaded: reboot.js<br />
[AMK2] Recipe is loaded: screen_onoff.js<br />
[AMK2] Recipe is loaded: shutdown.js<br />
[AMK2] Temporal storage directory is clearing.<br />
code: 14,<br />
metadata:<br />
]]></description><link>https://forum.magicmirror.builders/post/63742</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63742</guid><dc:creator><![CDATA[FLOW THE NOOB]]></dc:creator><pubDate>Sun, 03 Nov 2019 17:03:15 GMT</pubDate></item><item><title><![CDATA[Reply to Conversation Error: { Error: 14 UNAVAILABLE: Service unavailable. on Sun, 03 Nov 2019 13:13:27 GMT]]></title><description><![CDATA[<p dir="auto">Remove <code>useWelcomeMessage</code>. It needs more complex configuration. If you don’t need it really, just remove from config.js</p>
]]></description><link>https://forum.magicmirror.builders/post/63733</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63733</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Sun, 03 Nov 2019 13:13:27 GMT</pubDate></item></channel></rss>
