<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[pm2 dosn&#96;t start mm.sh after reboot]]></title><description><![CDATA[<p dir="auto">Hello</p>
<p dir="auto">i have the problem that pm2 dosn`t start <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a> after reboot. it was working with the MM2 Version 2.8.0 but after the update to 2.9.0 its no longer working.<br />
Any Idea?</p>
]]></description><link>https://forum.magicmirror.builders/topic/11537/pm2-dosn-t-start-mm-sh-after-reboot</link><generator>RSS for Node</generator><lastBuildDate>Thu, 18 Jun 2026 11:00:20 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11537.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 05 Nov 2019 12:52:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to pm2 dosn&#96;t start mm.sh after reboot on Wed, 13 Nov 2019 15:04:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/trividar" aria-label="Profile: trividar">@<bdi>trividar</bdi></a>  I’ve added all that to the fixup script… (and the updated install script)</p>
<p dir="auto">so, if u haven’t done this manually, run then script, then restart your mac</p>
]]></description><link>https://forum.magicmirror.builders/post/64338</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64338</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 13 Nov 2019 15:04:18 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 dosn&#96;t start mm.sh after reboot on Wed, 13 Nov 2019 14:19:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/trividar" aria-label="Profile: trividar">@<bdi>trividar</bdi></a> thanks for asking about catalina… I have found the ‘problem’ with pm2 restart…</p>
<p dir="auto">do</p>
<pre><code>sudo nano /Users/$USER/Library/LaunchAgents/pm2.$USER.plist
<p dir="auto">right at the top there is a string ‘UserName’ shown below<br />
the space after the &lt; is because this forum sees the &lt; as a special formatting tag…</p>
<pre><code>      &lt; key&gt;UserName&lt; /key&gt;
      &lt; string&gt;?????&lt; /string&gt;
<p dir="auto">anyhow, delete those two lines<br />
save the file (ctrl-o,enter), and exit, (ctrl-x)</p>
<p dir="auto">then restart (via shell),</p>
<pre><code>sudo shutdown -r now
]]></description><link>https://forum.magicmirror.builders/post/64337</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64337</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 13 Nov 2019 14:19:30 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 dosn&#96;t start mm.sh after reboot on Wed, 13 Nov 2019 13:14:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/trividar" aria-label="Profile: trividar">@<bdi>trividar</bdi></a> execute anywhere, it figures it out</p>
]]></description><link>https://forum.magicmirror.builders/post/64335</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64335</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 13 Nov 2019 13:14:46 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 dosn&#96;t start mm.sh after reboot on Wed, 13 Nov 2019 13:14:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> oooh perfect… I will try it… do i see this right, I should execute it outside from MM?</p>
<pre><code>cd
bash -c  "$(curl -sL  https://www.dropbox.com/s/cy2z7lbkpifcbrk/fixuppm2.sh?dl=0)"
]]></description><link>https://forum.magicmirror.builders/post/64334</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64334</guid><dc:creator><![CDATA[trividar]]></dc:creator><pubDate>Wed, 13 Nov 2019 13:14:07 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 dosn&#96;t start mm.sh after reboot on Wed, 13 Nov 2019 13:05:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/trividar" aria-label="Profile: trividar">@<bdi>trividar</bdi></a> oh, pm2… then use the new script for that<br />
see here<br />
<a href="https://forum.magicmirror.builders/topic/10907/new-script-to-install-fix-pm2-config-for-start-on-boot">https://forum.magicmirror.builders/topic/10907/new-script-to-install-fix-pm2-config-for-start-on-boot</a></p>
<p dir="auto">sometimes it doesn’t restart on boot like I think it should (on catalina, worked great on sierra an high sierra). haven’t found the problem yet</p>
]]></description><link>https://forum.magicmirror.builders/post/64333</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64333</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 13 Nov 2019 13:05:50 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 dosn&#96;t start mm.sh after reboot on Wed, 13 Nov 2019 13:03:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> because I can’t get pm2 to work on my mac mini catalina</p>
]]></description><link>https://forum.magicmirror.builders/post/64332</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64332</guid><dc:creator><![CDATA[trividar]]></dc:creator><pubDate>Wed, 13 Nov 2019 13:03:51 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 dosn&#96;t start mm.sh after reboot on Wed, 13 Nov 2019 13:03:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/trividar" aria-label="Profile: trividar">@<bdi>trividar</bdi></a> no… if u have it running, why do you need to install again?</p>
<p dir="auto">if you don’t have it running, then u need to install…</p>
<p dir="auto">you can copy the config.js to the new system, but you will have to install the modules and make sure to handle the dependencies they require</p>
]]></description><link>https://forum.magicmirror.builders/post/64331</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64331</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 13 Nov 2019 13:03:01 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 dosn&#96;t start mm.sh after reboot on Wed, 13 Nov 2019 13:01:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> OK I found the link…</p>
<pre><code>bash -c "$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)"
<p dir="auto">just a question, I have set up the magicmirror with all my settings etc. can I just execute this without loosing my stuff??</p>
]]></description><link>https://forum.magicmirror.builders/post/64330</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64330</guid><dc:creator><![CDATA[trividar]]></dc:creator><pubDate>Wed, 13 Nov 2019 13:01:25 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 dosn&#96;t start mm.sh after reboot on Wed, 13 Nov 2019 12:58:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/trividar" aria-label="Profile: trividar">@<bdi>trividar</bdi></a> read the instructions at the link I gave,<br />
in a terminal window , use finder to find ‘terminal’</p>
]]></description><link>https://forum.magicmirror.builders/post/64329</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64329</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 13 Nov 2019 12:58:45 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 dosn&#96;t start mm.sh after reboot on Wed, 13 Nov 2019 12:55:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> how can I execute this script?</p>
]]></description><link>https://forum.magicmirror.builders/post/64328</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64328</guid><dc:creator><![CDATA[trividar]]></dc:creator><pubDate>Wed, 13 Nov 2019 12:55:28 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 dosn&#96;t start mm.sh after reboot on Wed, 13 Nov 2019 12:53:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/trividar" aria-label="Profile: trividar">@<bdi>trividar</bdi></a> sure, just use the updated install script, which will be in the next release</p>
<p dir="auto">see<br />
<a href="https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer">https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer</a></p>
]]></description><link>https://forum.magicmirror.builders/post/64327</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64327</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 13 Nov 2019 12:53:51 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 dosn&#96;t start mm.sh after reboot on Wed, 13 Nov 2019 12:52:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Have you a solution for mac osx catalina? THX</p>
]]></description><link>https://forum.magicmirror.builders/post/64326</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64326</guid><dc:creator><![CDATA[trividar]]></dc:creator><pubDate>Wed, 13 Nov 2019 12:52:25 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 dosn&#96;t start mm.sh after reboot on Mon, 11 Nov 2019 13:16:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/63943">pm2 dosn&amp;#x60;t start mm.sh after reboot</a>:</p>
<p dir="auto">sudo env PATH=$PATH:/usr/local/bin pm2 startup systemd -u pi --hp /home/pi</p>
<p dir="auto">thx with this it works fine</p>
]]></description><link>https://forum.magicmirror.builders/post/64170</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64170</guid><dc:creator><![CDATA[Skorpionbird]]></dc:creator><pubDate>Mon, 11 Nov 2019 13:16:31 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 dosn&#96;t start mm.sh after reboot on Mon, 11 Nov 2019 13:46:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/skorpionbird" aria-label="Profile: Skorpionbird">@<bdi>Skorpionbird</bdi></a> in the pm2_setup.log, could you show me the rest of this line</p>
<pre><code>command = sudo env PATH=$PATH:/usr/bin:/bin /usr/lib/node_modules/pm2/bin/pm2 startup sys$
<p dir="auto">and try this</p>
<pre><code>sudo env PATH=$PATH:/usr/local/bin pm2 startup systemd -u pi --hp /home/pi
<p dir="auto">then , make sure MagicMirror is not running</p>
<pre><code>cd ~/MagicMirror
pm2 start installers/pm2_MagicMirror.json
pm2 save
<p dir="auto">then reboot</p>
]]></description><link>https://forum.magicmirror.builders/post/63943</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63943</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 11 Nov 2019 13:46:13 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 dosn&#96;t start mm.sh after reboot on Wed, 06 Nov 2019 13:07:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> its a Rpi 2 with Noobs  Rasbian GNU Linux 10</p>
]]></description><link>https://forum.magicmirror.builders/post/63942</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63942</guid><dc:creator><![CDATA[Skorpionbird]]></dc:creator><pubDate>Wed, 06 Nov 2019 13:07:59 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 dosn&#96;t start mm.sh after reboot on Wed, 06 Nov 2019 11:11:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/skorpionbird" aria-label="Profile: Skorpionbird">@<bdi>Skorpionbird</bdi></a> what system is this?  hardware/os?</p>
<p dir="auto">i have seen a similar problem recently on macOs Catalina…</p>
]]></description><link>https://forum.magicmirror.builders/post/63939</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63939</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 06 Nov 2019 11:11:16 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 dosn&#96;t start mm.sh after reboot on Wed, 06 Nov 2019 08:55:28 GMT]]></title><description><![CDATA[<p dir="auto">any news?</p>
]]></description><link>https://forum.magicmirror.builders/post/63938</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63938</guid><dc:creator><![CDATA[Skorpionbird]]></dc:creator><pubDate>Wed, 06 Nov 2019 08:55:28 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 dosn&#96;t start mm.sh after reboot on Tue, 05 Nov 2019 18:13:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> oh sry here is it<br />
pm2 logs<br />
[PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2<br />
[PM2] PM2 Successfully daemonized<br />
[TAILING] Tailing last 15 lines for [all] processes (change the value with --lines option)<br />
/home/pi/.pm2/pm2.log last 15 lines:<br />
PM2        | 2019-11-05T19:12:24: PM2 log: ===============================================================================<br />
PM2        | 2019-11-05T19:12:24: PM2 log: — New PM2 Daemon started ----------------------------------------------------<br />
PM2        | 2019-11-05T19:12:24: PM2 log: Time                 : Tue Nov 05 2019 19:12:24 GMT+0100 (GMT+01:00)<br />
PM2        | 2019-11-05T19:12:24: PM2 log: PM2 version          : 4.1.2<br />
PM2        | 2019-11-05T19:12:24: PM2 log: Node.js version      : 10.17.0<br />
PM2        | 2019-11-05T19:12:24: PM2 log: Current arch         : arm<br />
PM2        | 2019-11-05T19:12:24: PM2 log: PM2 home             : /home/pi/.pm2<br />
PM2        | 2019-11-05T19:12:24: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid<br />
PM2        | 2019-11-05T19:12:24: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock<br />
PM2        | 2019-11-05T19:12:24: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock<br />
PM2        | 2019-11-05T19:12:24: PM2 log: Application log path : /home/pi/.pm2/logs<br />
PM2        | 2019-11-05T19:12:24: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2<br />
PM2        | 2019-11-05T19:12:24: PM2 log: Concurrent actions   : 2<br />
PM2        | 2019-11-05T19:12:24: PM2 log: SIGTERM timeout      : 1600<br />
PM2        | 2019-11-05T19:12:24: PM2 log: ===============================================================================</p>
]]></description><link>https://forum.magicmirror.builders/post/63868</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63868</guid><dc:creator><![CDATA[Skorpionbird]]></dc:creator><pubDate>Tue, 05 Nov 2019 18:13:04 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 dosn&#96;t start mm.sh after reboot on Tue, 05 Nov 2019 19:40:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/skorpionbird" aria-label="Profile: Skorpionbird">@<bdi>Skorpionbird</bdi></a> I want to see the output of the command</p>
<pre><code>pm2 logs
]]></description><link>https://forum.magicmirror.builders/post/63863</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63863</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 05 Nov 2019 19:40:46 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 dosn&#96;t start mm.sh after reboot on Tue, 05 Nov 2019 16:12:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> when i copy paste ~/MagicMirror/installers/pm2_setup.log</p>
<p dir="auto">Then i recive</p>
<p dir="auto">Connecting to 192.168.1.174 port 22, please wait…<br />
login as: <br />
<a href="mailto:pi@192.168.1.174" target="_blank" rel="noopener noreferrer nofollow ugc">pi@192.168.1.174</a>’s password: <br />
Linux raspberrypi 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l</p>
<p dir="auto">The programs included with the Debian GNU/Linux system are free software;<br />
the exact distribution terms for each program are described in the<br />
individual files in /usr/share/doc/*/copyright.</p>
<p dir="auto">Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent<br />
permitted by applicable law.<br />
Last login: Sun Nov  3 20:42:57 2019 from 192.168.1.9</p>
<p dir="auto">pi@raspberrypi:~ $ ~/MagicMirror/installers/pm2_setup.log<br />
-bash: /home/pi/MagicMirror/installers/pm2_setup.log: Keine Berechtigung <strong>access denied</strong><br />
pi@raspberrypi:~ $</p>
]]></description><link>https://forum.magicmirror.builders/post/63862</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63862</guid><dc:creator><![CDATA[Skorpionbird]]></dc:creator><pubDate>Tue, 05 Nov 2019 16:12:29 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 dosn&#96;t start mm.sh after reboot on Tue, 05 Nov 2019 16:06:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> already postet</p>
]]></description><link>https://forum.magicmirror.builders/post/63861</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63861</guid><dc:creator><![CDATA[Skorpionbird]]></dc:creator><pubDate>Tue, 05 Nov 2019 16:06:52 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 dosn&#96;t start mm.sh after reboot on Tue, 05 Nov 2019 15:17:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/skorpionbird" aria-label="Profile: Skorpionbird">@<bdi>Skorpionbird</bdi></a> what is the output of pm2 logs?</p>
]]></description><link>https://forum.magicmirror.builders/post/63860</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63860</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 05 Nov 2019 15:17:12 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 dosn&#96;t start mm.sh after reboot on Tue, 05 Nov 2019 15:06:00 GMT]]></title><description><![CDATA[<p dir="auto">pm2 setup starting - Di Nov  5 15:55:05 CET 2019<br />
node version v10.17.0<br />
force installing latest npm version via npm<br />
npm version 6.11.3<br />
pm2 installed<br />
pm2 installed, but does not work, uninstalling<br />
pm2 not installed, installing<br />
get the pm2 platform specific startup command<br />
command = sudo env PATH=$PATH:/usr/bin:/bin /usr/lib/node_modules/pm2/bin/pm2 startup sys$<br />
[PM2] Init System found: systemd<br />
Platform systemd<br />
Template<br />
[Unit]<br />
Description=PM2 process manager<br />
Documentation=<a href="https://pm2.keymetrics.io/" target="_blank" rel="noopener noreferrer nofollow ugc">https://pm2.keymetrics.io/</a><br />
After=network.target</p>
<p dir="auto">[Service]<br />
Type=forking<br />
User=pi<br />
LimitNOFILE=infinity<br />
LimitNPROC=infinity<br />
LimitCORE=infinity<br />
Environment=PATH=$PATH:/usr/bin:/bin:/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/b$<br />
Environment=PM2_HOME=/home/pi/.pm2<br />
PIDFile=/home/pi/.pm2/pm2.pid<br />
Restart=on-failure</p>
<p dir="auto">ExecStart=/usr/lib/node_modules/pm2/bin/pm2 resurrect<br />
ExecReload=/usr/lib/node_modules/pm2/bin/pm2 reload all<br />
ExecStop=/usr/lib/node_modules/pm2/bin/pm2 kill</p>
<p dir="auto">[Install]<br />
WantedBy=multi-user.target</p>
<p dir="auto">Target path<br />
/etc/systemd/system/pm2-pi.service<br />
Command list<br />
[ ‘systemctl enable pm2-pi’ ]<br />
[PM2] Writing init configuration in /etc/systemd/system/pm2-pi.service<br />
[PM2] Making script booting at startup…<br />
</p><div class="plugin-markdown"><input type="checkbox" />Executing: systemctl enable pm2-pi…</div><br />
[PM2] [v] Command successfully executed.<br />
±--------------------------------------+<br />
[PM2] Freeze a process list on reboot via:<br />
$ pm2 save<p></p>
<p dir="auto">[PM2] Remove init script via:<br />
$ pm2 unstartup systemd<br />
pm2 startup done<br />
configure the pm2 config file for MagicMirror<br />
start MagicMirror via pm2 now<br />
save MagicMirror pm2 config now<br />
pm2 setup completed - Di Nov  5 15:56:55 CET 2019</p>
]]></description><link>https://forum.magicmirror.builders/post/63857</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63857</guid><dc:creator><![CDATA[Skorpionbird]]></dc:creator><pubDate>Tue, 05 Nov 2019 15:06:00 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 dosn&#96;t start mm.sh after reboot on Tue, 05 Nov 2019 14:54:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/skorpionbird" aria-label="Profile: Skorpionbird">@<bdi>Skorpionbird</bdi></a> can u show me</p>
<pre><code>~/MagicMirror/installers/pm2_setup.log
]]></description><link>https://forum.magicmirror.builders/post/63856</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/63856</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 05 Nov 2019 14:54:15 GMT</pubDate></item></channel></rss>
