<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Black screen without error when using MM modules]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">my rasberry pi3 magic mirror installation works fine with the standard modules.<br />
Although, I tried to add some custom modules, namely the cool fish of the day module  &amp; the dailyXkCD one.<br />
Cloning the most recent repo into the mirror folder works and is successfull. Also, I think there is no error in the config file as I do not get the  “warning screen from Magic mirror” telling me that something must be wrong in the config.</p>
<p dir="auto">However, as soon as the application launches I only see a black screen. That happend for both models. #<br />
At first I thought that I double placed modules on the same position on the screen but even after making sure that this is not the case I get the black screen.</p>
<p dir="auto">The console does not give any error message.</p>
<p dir="auto">Are such problems module related or do I miss dependencies on my pi?</p>
<p dir="auto">Thank you all so much for this awesome project &amp; support</p>
<p dir="auto">TebE</p>
]]></description><link>https://forum.magicmirror.builders/topic/1154/black-screen-without-error-when-using-mm-modules</link><generator>RSS for Node</generator><lastBuildDate>Tue, 15 Sep 2026 03:36:48 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1154.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 10 Dec 2016 01:48:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Black screen without error when using MM modules on Sat, 10 Dec 2016 21:50:09 GMT]]></title><description><![CDATA[<p dir="auto">Issues have been solved: Despite the detailed description I did not place the specific module folders in the “module” folder.<br />
Works now.</p>
<p dir="auto">Thanks a lot - Post can be deleted.</p>
]]></description><link>https://forum.magicmirror.builders/post/9164</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9164</guid><dc:creator><![CDATA[TebE]]></dc:creator><pubDate>Sat, 10 Dec 2016 21:50:09 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen without error when using MM modules on Sat, 10 Dec 2016 03:27:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tebe" aria-label="Profile: TebE">@<bdi>TebE</bdi></a> It sure sounds like there is an error in the  <code>config.js</code> file. If you can, copy your config file and paste it here and we’ll take a look at it. Please remember to 1) remove any API keys or passwords when you paste, and 2) use <a href="https://github.com/adam-p/markdown-here/wiki/Markdown-Cheatsheet#code" target="_blank" rel="noopener noreferrer nofollow ugc">the markdown features</a> (surround it with three back-ticks) to make your config file easier to read.</p>
]]></description><link>https://forum.magicmirror.builders/post/9124</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9124</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Sat, 10 Dec 2016 03:27:51 GMT</pubDate></item></channel></rss>
