<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[why is it so difficult to increase the size of the display moduless]]></title><description><![CDATA[<p dir="auto">this should be easy but all i find is add thi to css file<br />
rehards<br />
geo</p>
]]></description><link>https://forum.magicmirror.builders/topic/11557/why-is-it-so-difficult-to-increase-the-size-of-the-display-moduless</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Jul 2026 02:45:38 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11557.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 08 Nov 2019 11:52:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to why is it so difficult to increase the size of the display moduless on Mon, 11 Nov 2019 19:50:18 GMT]]></title><description><![CDATA[<p dir="auto">hi thx i will give it a try<br />
regards</p>
]]></description><link>https://forum.magicmirror.builders/post/64186</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64186</guid><dc:creator><![CDATA[geo]]></dc:creator><pubDate>Mon, 11 Nov 2019 19:50:18 GMT</pubDate></item><item><title><![CDATA[Reply to why is it so difficult to increase the size of the display moduless on Fri, 08 Nov 2019 21:17:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/geo" aria-label="Profile: geo">@<bdi>geo</bdi></a></p>
<p dir="auto">Here are some key commands that you might find useful, including making the modules larger. However, it will make all the modules larger at the same time.</p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/5619/how-to-find-and-use-key-commands-in-mm-for-absolute-beginners">https://forum.magicmirror.builders/topic/5619/how-to-find-and-use-key-commands-in-mm-for-absolute-beginners</a></p>
]]></description><link>https://forum.magicmirror.builders/post/64041</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64041</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Fri, 08 Nov 2019 21:17:54 GMT</pubDate></item><item><title><![CDATA[Reply to why is it so difficult to increase the size of the display moduless on Fri, 08 Nov 2019 14:11:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/geo" aria-label="Profile: geo">@<bdi>geo</bdi></a> u have to tell the browser to the new size of text.</p>
<p dir="auto">you do that by adding css statements to the custom.css file</p>
<pre><code>cd ~/MagicMirror/css
nano custom.css
]]></description><link>https://forum.magicmirror.builders/post/64028</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64028</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 08 Nov 2019 14:11:37 GMT</pubDate></item></channel></rss>
