<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Monitor goes to sleep within minutes]]></title><description><![CDATA[<p dir="auto">I have installed MM a week back it was all fine however since couple of days my monitor goes to sleep mode within minutes of powering on RPi.</p>
<p dir="auto">Post installing I was playing around with couple of modules but one suspect might be PIR-Sensor though I have it disconnected currently.</p>
<p dir="auto">My setup to disable sleep mode:</p>
<pre><code>sudo nano /etc/xdg/lxsession/LXDE-pi/autostart
<p dir="auto">Added below part</p>
<pre><code>@xset s noblank
@xset s off
@xset -dpms
<p dir="auto">I couldn’t find [SeatDefaults] so as a trial I made changes in Seat Configuration and [Seat : *]</p>
<pre><code>/etc/lightdm/lightdm.conf
<p dir="auto"><img src="https://i.imgur.com/KHLZOQm.png" alt="Config" class="img-markdown  img-fluid" /></p>
<p dir="auto"><img src="https://i.imgur.com/pZQHikH.png" alt="alt text" class="img-markdown  img-fluid" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/11574/monitor-goes-to-sleep-within-minutes</link><generator>RSS for Node</generator><lastBuildDate>Mon, 05 Oct 2026 14:54:42 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11574.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 11 Nov 2019 16:30:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Monitor goes to sleep within minutes on Fri, 15 Nov 2019 07:14:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/64348">Monitor goes to sleep within minutes</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/newbie007" aria-label="Profile: Newbie007">@<bdi>Newbie007</bdi></a> said in <a href="/post/64346">Monitor goes to sleep within minutes</a>:</p>
<p dir="auto">but I followed this method as well and forgot about it.</p>
<p dir="auto">I don’t see a ‘method’ there… its a 4 page topic</p>
<p dir="auto">I thought I linked you to a comment in that thread which details how to use PIR sensor to turn on/off monitor along with LED lights which is apart from PIR-Sensor module.</p>
<p dir="auto">I commented out the module but forgot about the standalone script. Now we are good.</p>
<p dir="auto">Thanks for your help!</p>
]]></description><link>https://forum.magicmirror.builders/post/64473</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64473</guid><dc:creator><![CDATA[Newbie007]]></dc:creator><pubDate>Fri, 15 Nov 2019 07:14:51 GMT</pubDate></item><item><title><![CDATA[Reply to Monitor goes to sleep within minutes on Wed, 13 Nov 2019 17:01:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/newbie007" aria-label="Profile: Newbie007">@<bdi>Newbie007</bdi></a> said in <a href="/post/64346">Monitor goes to sleep within minutes</a>:</p>
]]></description><link>https://forum.magicmirror.builders/post/64348</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64348</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 13 Nov 2019 17:01:49 GMT</pubDate></item><item><title><![CDATA[Reply to Monitor goes to sleep within minutes on Wed, 13 Nov 2019 17:02:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/newbie007" aria-label="Profile: Newbie007">@<bdi>Newbie007</bdi></a> said in <a href="/post/64346">Monitor goes to sleep within minutes</a>:</p>
<p dir="auto">But in mean time how can I disable this?</p>
<p dir="auto">what? the module?  I gave u instructions in the prior post</p>
]]></description><link>https://forum.magicmirror.builders/post/64347</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64347</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 13 Nov 2019 17:02:03 GMT</pubDate></item><item><title><![CDATA[Reply to Monitor goes to sleep within minutes on Wed, 13 Nov 2019 16:59:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/64344">Monitor goes to sleep within minutes</a>:</p>
<p dir="auto">PIR-Sensor</p>
<p dir="auto">Damn! You are right.</p>
<p dir="auto">I commented whole PIR-Sensor in config.js but I followed <a href="https://forum.magicmirror.builders/topic/6048/my-first-mirror-until-now/16?page=2">this method</a> as well and forgot about it.</p>
<p dir="auto">Currently I have unplugged my PIR, let me plug it again and report back to you.</p>
]]></description><link>https://forum.magicmirror.builders/post/64346</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64346</guid><dc:creator><![CDATA[Newbie007]]></dc:creator><pubDate>Wed, 13 Nov 2019 16:59:23 GMT</pubDate></item><item><title><![CDATA[Reply to Monitor goes to sleep within minutes on Wed, 13 Nov 2019 16:52:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/newbie007" aria-label="Profile: Newbie007">@<bdi>Newbie007</bdi></a> PIR-Sensor… is that module still in config.js?</p>
<p dir="auto">you can disable it by adding</p>
<pre><code>  disabled: true,
<p dir="auto">to that module config, after the module: statement</p>
<p dir="auto">note that PIR has some dependencies, which can cause black screen…</p>
]]></description><link>https://forum.magicmirror.builders/post/64344</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64344</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 13 Nov 2019 16:52:19 GMT</pubDate></item><item><title><![CDATA[Reply to Monitor goes to sleep within minutes on Wed, 13 Nov 2019 16:49:23 GMT]]></title><description><![CDATA[<p dir="auto">This is what I got</p>
<pre><code>lxsession screen saver already disabled
]]></description><link>https://forum.magicmirror.builders/post/64343</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64343</guid><dc:creator><![CDATA[Newbie007]]></dc:creator><pubDate>Wed, 13 Nov 2019 16:49:23 GMT</pubDate></item><item><title><![CDATA[Reply to Monitor goes to sleep within minutes on Wed, 13 Nov 2019 16:19:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/newbie007" aria-label="Profile: Newbie007">@<bdi>Newbie007</bdi></a> hm… well, if you reboot it, run my screensaver setup script…<br />
see</p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/11052/new-script-for-screensaver-disable">https://forum.magicmirror.builders/topic/11052/new-script-for-screensaver-disable</a></p>
<p dir="auto">post the log after from</p>
<pre><code>~/screensaver.log
]]></description><link>https://forum.magicmirror.builders/post/64342</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64342</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 13 Nov 2019 16:19:27 GMT</pubDate></item><item><title><![CDATA[Reply to Monitor goes to sleep within minutes on Wed, 13 Nov 2019 16:05:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/64340">Monitor goes to sleep within minutes</a>:</p>
<p dir="auto">MM is showing black screen</p>
<p dir="auto">I actually doubt that cause before going to sleep my monitor shows the default “HDMI” text which is usually shown before boot as well</p>
]]></description><link>https://forum.magicmirror.builders/post/64341</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64341</guid><dc:creator><![CDATA[Newbie007]]></dc:creator><pubDate>Wed, 13 Nov 2019 16:05:02 GMT</pubDate></item><item><title><![CDATA[Reply to Monitor goes to sleep within minutes on Wed, 13 Nov 2019 15:48:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/newbie007" aria-label="Profile: Newbie007">@<bdi>Newbie007</bdi></a> ok, so mouse is shown… and moves…  this is not screen saver…</p>
<p dir="auto">so, it appears MM is showing black screen</p>
<p dir="auto">you need a keyboard to be able to get to the debug info</p>
]]></description><link>https://forum.magicmirror.builders/post/64340</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64340</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 13 Nov 2019 15:48:22 GMT</pubDate></item><item><title><![CDATA[Reply to Monitor goes to sleep within minutes on Wed, 13 Nov 2019 15:46:01 GMT]]></title><description><![CDATA[<p dir="auto">I am not even sure how to wake up the screen, I don’t have keyboard just the mouse moving that doesn’t help</p>
]]></description><link>https://forum.magicmirror.builders/post/64339</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64339</guid><dc:creator><![CDATA[Newbie007]]></dc:creator><pubDate>Wed, 13 Nov 2019 15:46:01 GMT</pubDate></item><item><title><![CDATA[Reply to Monitor goes to sleep within minutes on Tue, 12 Nov 2019 13:02:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> i’ve already issues those commands during mm setup. Once monitor goes to sleep im unable to even wake it up</p>
]]></description><link>https://forum.magicmirror.builders/post/64250</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64250</guid><dc:creator><![CDATA[Newbie007]]></dc:creator><pubDate>Tue, 12 Nov 2019 13:02:01 GMT</pubDate></item><item><title><![CDATA[Reply to Monitor goes to sleep within minutes on Mon, 11 Nov 2019 18:34:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/newbie007" aria-label="Profile: Newbie007">@<bdi>Newbie007</bdi></a> said in <a href="/post/64175">Monitor goes to sleep within minutes</a>:</p>
<p dir="auto">xset s noblank<br />
xset s off<br />
xset -dpms</p>
<p dir="auto">you can issue those commands manually<br />
or you have to reboot to disable screensaver</p>
]]></description><link>https://forum.magicmirror.builders/post/64179</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64179</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 11 Nov 2019 18:34:40 GMT</pubDate></item></channel></rss>
