<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MagicMirror capture.py error]]></title><description><![CDATA[<p dir="auto">I decided to restart the real time facial recong. I’m at the part when I’m testing the tools and I ran the <a href="http://capture.py" target="_blank" rel="noopener noreferrer nofollow ugc">capture.py</a> and got this error.</p>
<pre><code>Traceback (most recent call last):
  File "capture.py", line 18, in &lt;module&gt;
    import lib.capture as capture
  File "/home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/lib/capture.py", line 21, in &lt;module&gt;
    from . import config
  File "/home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/lib/config.py", line 15, in &lt;module&gt;
    (CV_MAJOR_VER, CV_MINOR_VER, mv1, mv2) = cv2.__version__.split(".")
ValueError: not enough values to unpack (expected 4, got 3)
<p dir="auto">For the record, my python is 3.7 and my OpenCV is 4.0</p>
]]></description><link>https://forum.magicmirror.builders/topic/11586/magicmirror-capture-py-error</link><generator>RSS for Node</generator><lastBuildDate>Tue, 16 Jun 2026 09:23:38 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11586.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 12 Nov 2019 18:34:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MagicMirror capture.py error on Fri, 22 Nov 2019 17:40:42 GMT]]></title><description><![CDATA[<p dir="auto">What do you mean, “What is it capturing from?”<br />
Where do you want me to look?</p>
]]></description><link>https://forum.magicmirror.builders/post/64941</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64941</guid><dc:creator><![CDATA[Buncie]]></dc:creator><pubDate>Fri, 22 Nov 2019 17:40:42 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror capture.py error on Mon, 18 Nov 2019 17:36:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/buncie" aria-label="Profile: Buncie">@<bdi>Buncie</bdi></a> no… i am sure I can. but don’t have time right now</p>
<p dir="auto">also not sure what it is capturing from?</p>
]]></description><link>https://forum.magicmirror.builders/post/64673</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64673</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 18 Nov 2019 17:36:09 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror capture.py error on Mon, 18 Nov 2019 17:34:00 GMT]]></title><description><![CDATA[<p dir="auto">Do you know anyone who can fix it?</p>
]]></description><link>https://forum.magicmirror.builders/post/64672</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64672</guid><dc:creator><![CDATA[Buncie]]></dc:creator><pubDate>Mon, 18 Nov 2019 17:34:00 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror capture.py error on Thu, 14 Nov 2019 19:02:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/buncie" aria-label="Profile: Buncie">@<bdi>Buncie</bdi></a> this module setup is a pain… i’m sorry, I don’t know any more on how to fix it.</p>
]]></description><link>https://forum.magicmirror.builders/post/64443</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64443</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 14 Nov 2019 19:02:15 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror capture.py error on Thu, 14 Nov 2019 19:00:40 GMT]]></title><description><![CDATA[<p dir="auto">Now it says this when I do have OpenCV.</p>
  File "/home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/lib/capture.py", line 19, in &lt;module&gt;
    import cv2
ModuleNotFoundError: No module named 'cv2'
]]></description><link>https://forum.magicmirror.builders/post/64442</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64442</guid><dc:creator><![CDATA[Buncie]]></dc:creator><pubDate>Thu, 14 Nov 2019 19:00:40 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror capture.py error on Thu, 14 Nov 2019 18:58:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/buncie" aria-label="Profile: Buncie">@<bdi>Buncie</bdi></a></p>
<p dir="auto">looks like you need to run python3</p>
<pre><code class="language-python3">
Then im tring to sudo pip install future --upgrade,
**I modified the code in config.py**
from CV_MAJOR_VER, CV_MINOR_VER, mv1, mv2 = cv2.version.split(".")
to CV_MAJOR_VER, CV_MINOR_VER, type = cv2.version.split(".")
try: python3 capture.py // python capture.py
]]></description><link>https://forum.magicmirror.builders/post/64441</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64441</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 14 Nov 2019 18:58:56 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror capture.py error on Thu, 14 Nov 2019 18:56:49 GMT]]></title><description><![CDATA[<p dir="auto">I did that and I got a new error.</p>
  File "/home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/lib/capture.py", line 12, in &lt;module&gt;
    from   builtins import input
ImportError: No module named builtins
]]></description><link>https://forum.magicmirror.builders/post/64440</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64440</guid><dc:creator><![CDATA[Buncie]]></dc:creator><pubDate>Thu, 14 Nov 2019 18:56:49 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror capture.py error on Thu, 14 Nov 2019 18:49:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/buncie" aria-label="Profile: Buncie">@<bdi>Buncie</bdi></a> see<br />
<a href="https://forum.magicmirror.builders/topic/10325/capture-py-in-mmm-facial-recognition-tools-error">https://forum.magicmirror.builders/topic/10325/capture-py-in-mmm-facial-recognition-tools-error</a></p>
]]></description><link>https://forum.magicmirror.builders/post/64439</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64439</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 14 Nov 2019 18:49:09 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror capture.py error on Thu, 14 Nov 2019 18:26:13 GMT]]></title><description><![CDATA[<p dir="auto">Is there anyone who can see whats wrong with the code?</p>
]]></description><link>https://forum.magicmirror.builders/post/64438</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64438</guid><dc:creator><![CDATA[Buncie]]></dc:creator><pubDate>Thu, 14 Nov 2019 18:26:13 GMT</pubDate></item></channel></rss>
