<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Best monitor settings?]]></title><description><![CDATA[<p>Hi all,</p>
<p>just assembled my mirror, I used the "<a href="http://www.twowaymirrors.com/smart-mirror"></a><a href="http://www.twowaymirrors.com/smart-mirror">Smart Mirror</a>" (<a href="http://www.twowaymirrors.com/smart-mirror">http://www.twowaymirrors.com/s...</a>). I know trhese mierrors work in a well lit room the best but I was wondering if there is any tweaking that helps keep the bleed coming through? Is turning brightness all the way down best etc?</p>
<p><a href="http://imgur.com/a/O7MAs">http://imgur.com/a/O7MAs</a></p>
<p><a href="http://imgur.com/a/VsJIb">http://imgur.com/a/VsJIb</a></p>
<p>Thanks</p>]]></description><link>https://forum.magicmirror.builders/topic/1159/best-monitor-settings</link><generator>RSS for Node</generator><lastBuildDate>Fri, 12 Jun 2026 08:50:33 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1159.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 10 Dec 2016 19:02:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Best monitor settings? on Fri, 13 Jan 2017 00:04:42 GMT]]></title><description><![CDATA[<p>Any update?</p><p>My plan was to use the same smart mirror as you. Were you able to fix the problem?</p><p>What screen did you use?</p>]]></description><link>https://forum.magicmirror.builders/post/10977</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10977</guid><dc:creator><![CDATA[ZombieDE]]></dc:creator><pubDate>Fri, 13 Jan 2017 00:04:42 GMT</pubDate></item></channel></rss>
